Drunk_Panda Skrevet 21. mai 2012 Del Skrevet 21. mai 2012 La inn en tråd her i går der jeg skal kjøpe meg en ny kraftig bærbar. Derfor vil jeg da prøve å selge de 2 andre jeg har her. En bærbar med følgende specs: Technology type: Intel® Centrino® 2 Processor Technology featuring Intel® Core 2 Duo Processor P8600 Intel® PM45 Express chipset and Intel® WiFi Link 5100 clock speed : 2.40 GHz front side bus : 1066 MHz 2nd level cache : 3 MB Operating System / Platform Genuine Windows Vista® Home Premium 32-bit Edition (pre-installed, Toshiba-HDD recovery) System memory standard : 4,096 (2,048 + 2,048) MB maximum expandability : 8,192 MB technology : DDR3 RAM (1066 MHz) Hard disk capacity : 320 GB certification : S.M.A.R.T. drive rotation : 5,400 rpm DVD Super Multi drive (Double Layer) Display size : 17 " type : Toshiba TruBrite® WXGA+ TFT High Brightness display internal resolution : 1,440 x 900 Graphics adaptor type : NVIDIA® GeForce® 9700M GTS supporting TurboCache technology memory : 512 MB dedicated VRAM (up to 1,791 MB total available graphics memory using TurboCache™ technology with 3 GB system memory) memory type : GDDR3 (800 MHz) Video RAM (resp. Video RAM and system memory combined) connected bus : 16x PCI Express Internal video modes The following internal video modes are supported: resolution : 1,440 x 900 Interfaces 1 × DC-in 1 × RJ-11 1 × RJ-45 1 × i.LINK® (IEEE 1394) 1 × external microphone 1 × RGB 1 × headphone (stereo) 1 × line-in shared with microphone socket 1 × S/PDIF-out (optical) shared with headphone socket 1 × integrated 1.3 Megapixels Web Camera with built-in microphone 1 × HDMI-CEC (REGZA-Link) supporting 1080p signal format 1 (shared with one USB port) × eSATA 1 × line-out shared with headphone socket 1 × 5-in-1 Bridge Media slot (supports SD™ Cards up to 16 GB, Memory Stick® up to 256 MB, Memory Stick Pro™ up to 4 GB, MultiMedia Card™ up to 1 GB and xD-Picture Card™ up to 2 GB) 4 (Left 2, Right 2) × USB 2.0 (supporting USB Sleep-and-Charge) Expansion 2 × memory slots 1 × ExpressCard slot Wireless communication Wireless Technology : Bluetooth® Compliancy : Wi-Fi™ Network Support : 802.11a/g/Draft-N Manufacturer : Intel® Wireless Technology : Wireless LAN (802.11a/g/Draft-N) Wired communication topology : international V.90 modem (V.92 ready) speed : 56 Kbps data and 14.4 Kbps fax topology : Gigabit Ethernet LAN speed : 10BASE-T/100BASE-TX/1000BASE-T Sound system supported audio format : 24-bit stereo speakers : built-in Harman Kardon® stereo speaker system with 2 x bass reflex speakers, 2 x tweeter speakers and 1 x subwoofer technology manufacturer : Toshiba Bass Enhanced Sound System with Dolby® Home Theater™ Keyboard keys : 105 Windows keys : Yes special features : Standard numeric keypad Pointing device type : Touch Pad Battery technology : lithium-ion Special features SM BIOS compliant integrated microphone for Voice over IP Enhanced Intel® SpeedStep® Technology integrated 1.3 Megapixels Web Camera for Video over IP Multimedia Bar with 9 feather-touch Easy Keys (CD/DVD launcher, Play/Pause, Stop, Rewind, Forward, Mute, on/off function of white LEDs, Camera, Dolby) Stasjonære: Intel Core2Duo E8400 3ghz @ 4ghz Crucial DDR3 1333MHz 8GB KIT, CL9 Raptor 10000 RPM 160 GB disk Ellers totalt 2TB disker. DVD Brenner XFX nForce 790i Ultra 3-Way SLI PowerColor Radeon HD 5870 1GB GDDR5 (vet dette ikke støtter 3way SLI) 1000 Watt PSU (sluker ALT) Så hva kunne jeg fått for disse? Har ikke interesse av å selge for skambud... Lenke til kommentar
N o r e n g Skrevet 21. mai 2012 Del Skrevet 21. mai 2012 2000-2500 for den stasjonære Laptopen er jeg ikke sikker på at noen vil kjøpe engang. Kan ikke forestille meg at noen vil være interessert i en laptop med ytelse sammenlignbar med en mid-range APU, stor vekt og sannsynligvis kort batteriliv. Lenke til kommentar
Drunk_Panda Skrevet 22. mai 2012 Forfatter Del Skrevet 22. mai 2012 virkelig så lite for den? den har en 1 KW PSU, en ny slik koster minumum 1400 nå Lenke til kommentar
N o r e n g Skrevet 22. mai 2012 Del Skrevet 22. mai 2012 virkelig så lite for den? den har en 1 KW PSU, en ny slik koster minumum 1400 nå Og så? Den øker ikke ytelsen på systemet, og resten av delene er så gamle at man må oppgradere hovedkort, RAM, CPU, og grafikkort. Med mindre du selger del for del tror jeg ikke du kan forvente noe mer. Lenke til kommentar
MrLee Skrevet 22. mai 2012 Del Skrevet 22. mai 2012 Enig med arni90. en kraftig PSU alene trekker ikke opp systemprisen. De som kan tenkes å være intressert i en PC med de spec's er ikke intressert i om PSUen er 500w eller 1000w. Og de som kanskje kunne brydd seg om PSU'en ville ikke ha kjøpt en PC med de spec's uansett. Lenke til kommentar
