Den offisielle Samsung Galaxy S3 tråden
Hvordan kan man se flash-innhold på Galaxy S3? Prøvde å se på nrk på telefonen, men fikk kun beskjed om å laste ned flash. Så vidt jeg vet støttes ikke adobe flash player, men det finnes vel en annen mulighet?
Ja. Last ned flash player manuelt fra 'Arkiv' på adobes hjemmeside, versjon 11.1. Står en guide her på forumet også. Virker bare i enkelte nettlesere ex dolphin.
Så lenge man identifiserer seg som "Android" vil den prøve flash (pr dato).
Prøv å endre "user agent" i nettleser til iPad eller iPhone, så vil den bruke html5.
Her er en fin guide til hvordan man setter opp Google Now og litt tips til hvordan man bruker det:
http://www.androidau...ogle-now-98749/
I’ve noticed that in most development threads there are users complaining about not being able to get Google Now working correctly. I thought I’d share the steps I’ve taken to setup Google Now, and it’s been working perfectly for me.
Before we begin there are two things to clear up. Firstly, in order for Google Now to work properly you are going to need to be OK with easing off on several privacy settings. You will need to enable Web History and Location Sharing; so if you are uncomfortable with this or are a bit of a privacy nut (nothing wrong with that!) then Google Now is not for you, and will never work as intended.
Secondly, Google Now takes time to gather information about you before it will start working as you expect. This means you need to use it! Anytime you are doing a Google search from your phone, use Google Now; when you’re waiting for a bus, open Google Now, etc. After a few hours/days (depending on how much you use it) it will begin to display your Now Cards correctly.
Prerequisites:
1.A Jelly Bean custom ROM (e.g. TeamNDVRu CM10)
2.Google Now enabled (obviously)
3.Google Maps installed
4.At present Google Now will only work correctly when using English as the default language (US/UK both work)
Before using Google Now
Enable Web History:
1.We need to enable ‘Web History’ for our Google searches. From your desktop/laptop go to your Google Account settings (click your username/email address on the Google homepage and go to Account).
2.Select ‘Products’ then scroll down and select ‘Web History’. Ensure this is enabled, if paused click ‘Resume’. Web History is now enabled
Enable Location Sharing:
1.Open Latitude (found in your app drawer). Go to settings.
2.Make sure ‘Location Reporting’ is set to ‘Your location is reported automatically’
3.Make sure ‘Enable Location History’ is ticked. You can set the ‘Check In’ options as you wish, I don’t use this feature myself.
4.Open Google Maps. You should see your Latitude location centred on the screen. Click your avatar (the square pic pointing out your location). Select your name. Select ‘Location Settings from the pop-up menu.
5.Press the menu key and select ‘Change home location’ – enter your home address. Then press the menu key again and select ‘Change work location’ – enter your work location (this can also be your School/University if you want)
6.Location Sharing is now set up for Google Now
Google Now Setup:
1.Open Google Now and follow the on-screen instructions. Select ‘Yes I’m in’ when prompted.
2.Press the menu key, select ‘Settings’
3.Select ‘Now Cards’ – you can set this up as you wish, depending on what features you want to use and how you want to use them. It’s pretty self explanatory.
4.Go back and select ‘Voice’. Set language to ‘English UK’ or ‘English US’ (At present only English as default will work).
5.Select ‘Download offline speech recognition’. Go to the download tab and download ‘English UK’ language if you want to use it (US is default). – it’s a small download
6.Go back and select ‘Privacy and accounts’. Make sure ‘Location and Google Search’ + ‘Show recent searches’ + Search on google.com’ are all ticked.
7.Go back and select ‘Phone search’ – set this as you wish, if you don’t want Google Now to search your contacts for instance, then un-tick it.
8.Google Now is now setup properly, start using it!
Notes/Tips
-If you use Google Apps for Business you will need to perform an extra step. Login and go to Settings, scroll down and select Mobile. There will be a checkbox ‘Use Google Now’, make sure this is ticked.
-To have the Calendar card work properly you will need to set times and locations for your appointments/reminders. E.g. you’re doing an early shift in work, so set your appointment location to your work address, then set the times to the shift start/end times rather than ‘All Day’. The card will popup a few hours before your shift and should bring the Traffic card along with it to tell you how long it might take you t o travel/when to leave to arrive on time.
-Depending on where you live the Public Transport card may not behave as you would expect. In the area of London I live for instance, the Now Card will only show when I’m near major stations/bus stops and will not show for every single one. This may vary around the world, or even in different areas of the same city.
-Some Now Cards may never show, they are all situational (you can set the Weather to always show, but it’s the only one). It depends entirely on how you use Google Now. E.g. if you never search for your football teams results or fixtures, then the Sport Card is never going to show.
-When out and about, turn GPS/WiFi on to get a better fix on your location, helps with the Public Transport card especially.
Hopefully this gets some of you going with Google Now. Some of the steps may be superfluous but, again, this is just what worked for me after many frustrating hours of trying to figure it out!
Betyr dette at jeg må dele posisjonen min offentlig for å kunne bruke Google Now?
mobilen er etter en dag med 4.1.1 plutselig blitt ekstremt treg, henger seg opp hele tiden osv. :@
batteriet tømmes fort selv om mobilen lades...!
Noe har skjedd med batteritiden på min også. Hadde over 50% igjen da jeg la meg, og oppdaget klokka 5 i natt at tlf var skrudd seg av pga at batteriet var tomt!
Noen andre med batteriproblemer etter at de la inn 4.1.1?
La inn root før jeg la meg...kan det ha noe å si da?
...opplever ingen heng enda dog
Endret av Chivas
Jeg oppdaterte min til 4.1.1 tidlig forigge uke, da oppdateringen kom OTA til meg. Batteritiden har blitt betydelig bedret, programmer reagerer raskere og telefonen går generelt mye smidigere.
Merkelig at noen sliter da.
At noen sliter etter oppgraderingen kan komme av mange grunner.. men en av de er nok at oppgraderingen kan få dårlig skrevet apper til å komme i en "state" der de ikke avsluttes ordentlig og hindrer mobilen å gå i dvale osv.. Har mange på kontoret her som har måtte ta en fabrikk reset for å få skikk på mobilen igjen...
Ser at noen har har hatt dårlige erfaringer etter oppdateringen til JB. Jeg må nok stille meg i den køen. Jeg gledet meg veldig til oppdateringen, men jeg har blitt møtt med tilsynelatende dårligere batterilevetid, programmer som fryser og tidvis dårligere respons. Det skjer eksempelvis i blant at det tar så lang tid fra da jeg trykker på låseknappen til skjermen begynner å lyse, at jeg rekker å lure på om jeg i det hele tatt har trykket.
Ikke gøy.
Det er ikke til og legge under en stol at Jelly Bean er en stor skuffelse etter så lang vente tid.. . Jeg hadde nå selv ventet en god del mer av denne oppdateringen enn hva vi fikk + det viser seg jo på min og mange andre sin at det er mye bugs ute og går.. . JB suger rumpe.. . men jeg elsker forsatt min SIII grunnet alle mulighetene jeg har med den og at jeg ikke har noe batteri problemer. Men kommer nok til og bytte den ut til fordel for større skjerm. For min del syntes jeg den faktisk er hakket for liten, så når Note III kommer en gang i fremtiden blir det nok mulig den!? :hmm:
Jeg forsøkte å gå tilbake til 4.0.4 for å se om 4.1.1 OTA fungerte.
Men nå ser det ut til at den har låst seg i oppstart etter å ha flasha 4.0.4 via Odin.
Kan noen sende meg en link med Norsk/nordisk 4.1.1 firmware? Finner den ikke på Sammobile.
