Den offisielle Samsung Galaxy S3 tråden
Telefonen er ny og spørsmålene mange!
Er det noen som vet om hvordan en overfører innholdet fra apps fra gammel telefonen til nytelefonen? de skal ha blitt lagret på sim... men når jeg åpner appsene i ny telefonen, er de tomme...
Hei!
Jeg har skaffet meg en Galaxy s3 og har et lite problem. På S2 var det veldig lett å koble seg til en mac ved bruk av USB. Man gjorde bare telefonen om til en harddisk. S3 er litt verre. Den bare lader batteriet. Jeg får ikke opp ikoner på desktopen. Hvordan får jeg telefonen til å kommunisere med macen via USB?
Comment 179 by [email protected], Oct 16 (2 days ago)
SGS III & Mac OSX 10.6.8
AFT & Mac OSX do not recognise phone when attached via USB
Solution: use Kies (latest firmware).
Having not used Kies in the past thinking it was pants, was forced to find a solution to get files across to my GS3. Didn't fancy using the wifi approach given how many files and folder i had to move across. My phone was already connected via USB cable and i fired-up Kies. If you haven't used it in a while you will need to upgrade to latest version which means disconnecting your phone.
- Once updated, rebooted, connect your phone and start Kies.
- in the top left corner Kies should show you that it is connecting to your phone/device.
- Once connected it will the basic information about your device in the viewing pane to the right.
- The Internal Memory and external memory should be split and shown.
- to the right of each memory is a shaded blue circle with a folder inside it.
- if you click the on that it will bring up all the folders currently in each memory.
- Any files/folders you want transferred to your device can now be simply dragged and dropped.
- Transfer rate is a very respectable speed (took 7mins to transfer 7gb of audio files).
and there you have it problem solved (well it worked for me).
Bottom Line: Kies can and will do the job competently try it you may be surprised (as i was).
Godo Luck.
https://code.google.com/p/android/issues/detail?id=36970&colspec=ID%20Type%20Status%20Owner%20Summary%20Stars
Greia er at internminnet ikke kan aksesseres med MSC (USB MassStorage Class) - kun SDKort
Bare MTP protokoll (Media device Transfer) eller PTP (Picture Transfer Protocol , Camera mode) kan benyttes.
Tidligere kunne man bruke AFT for mac (Android File Transfer) - men denne virker visst ikke langre med siste OSX versjoner og Android 4.0.4.
Prøv Samsung KIES for mac.
Andre alternativer er via WIFI (f.eks KIES Air installert i telefonen)
Når jeg, satt tilbake igjen "valg nr 3" så bruker den ikke H+ lenger.. . H+ er vel raskere nett en vanlig H - HSPA??
Som nevnt. Der hvor jeg bor var forskjellen marginal - det er derfor jeg ikke har problemer med å skru av HSPA. Jeg har derimot problemer innendørs, hvor signalet er akkurat for svakt til å svitjse over på HSPA. Da ligger telefonen og vaker mellom 3G og HSPA, og jeg får "ingen datatilkobling"-feilmelding.
Tester jeg telefonen nå, med kun 3G, så har jeg følgende:
Og det kan jeg leve med.
Batteri er ikke en faktor i dette.
PS: Her er med H+
Endret av unik42
PS: Her er med H+
Ok, greit og vite! Takk :)
Fikk nyttige svar her i forbindelse med bruk av Airplay på S3, så tror nok jeg går for en S3. Nok en gang har jeg 4 spørsmål...
1. Forstår jeg riktig så er det ingen grunn til å vente på Jelly Bean ferdig installert på S3'er, den kan man i alle tilfelle enkelt oppgradere når den kommer?
2. Deksel/beskyttelse: Er interessert i noe som beskytter litt, men som også ikke bygger så mye i størrelse og ser ok ut. Hørt at Chamelon casecrown kan ha noen ok deksler, og ellers synes jeg heldekkende læretui ser ok ut, men er kanskje lite praktisk (man ser ikke når man har meldinger, kjenner kanskje ikke vibreringen ved lydløs osv). Noen erfaringer på dette feltet?
3. Fargevalg: hvit, blå og rød og velge mellom. Rød blir vel litt femi, så da står det mellom hvit og blå. Noen som vet om svart/grun/grå (som jeg tror er eller blir tilgjengelig i feks USA) kommer til Norge snarlig?
4. Tenker det blir Netshop for meg. Lav pris i tillegg til hente/leveringsbu i nærheten av Furuset i Oslo (verdi å ha et fysisk sted å forholde seg til).
Det var noen helt sinnsyke hastigheter du fikk der! Selv her i Oslo sentrum sliter jeg med å få over 5 mbps med LTE. Vanlig H+ er sjelden over 1.5-3. 3G er enda dårligere.
1) Du vil få JB raskere ved å ikke vente på på preinstallert JB siden vi får OTA så snart det slippes. Merk bare at hvis du bestiller fra telenor og får en telefon med TEE CSC (nevermind) så kan det ta litt lenger tid.
3) Ingen indikasjoner på det skjer innen nær fremtid (eller før JB), nei.
Endret av Feh
Hey! Min S3 slo seg av idag, men den låg i lomma (jakka hang i skapet på jobb). Og den vil ikkje slå seg på igjenn. Får null respons frå den. Prøvd å plukke den inn i ladder, men fortsatt null response. Noen tips?
Samme med min.
Bare frøs seg i går, LED sto og blinket som om jeg hadde fått en jobb email.
Hadde ett ekstra batteri jeg prøvde også, null respons :(
Hvorfor vil du heller bruke denne? Hva er bedre (og dårligere)?
Har noen hatt problemer med feks doble kalender oppføringer eller sletting av kalender oppføringer etter installert denne i tillegg til standard?
Jeg bruker bare lokal kalender (my calendar) på S3, IKKE google kalenderen, usikker om vil få problemer dersom jeg vil prøve ut denne appen i tillegg til den inkluderte.
jarle
Jeg spurte tidligere om noen hadde problemer med at nettleseren (faktisk irrelevant hvilken - standard, opera, chrome, firefox) hang seg i et par sekunder nå og da.
Oppdaget plutselig at om jeg trykket meg UT av nettleseren, sto mobilen og loadet shell som en dust. Mistenker faktisk at dette er grunnen.
For min del håper jeg INDERLIG at Jellybean fikser dette. Om ikke er det et så stort irritasjonsmoment at jeg først prøver å ta en backup / restore, men hvis ikke kan android brenne og kræsje for min del. Maken til irriterende heng :(
Offtopic - hvor mye større kjennes en Note 2 ut? Jeg har fabelaktig lyst på en ...
PS: Her er med H+
Får forøvrig 11323 kbps med H+ her i Stavanger :)
Min S3 knuste i dag, hvor er et greit sted i oslo å få fikset den?
Ta turen innom underetasjen til FotoVideo i Møllergata 4. De fikser det på en time for 700 spenn.
Lurer på om dette er noe som gjelder flere ganger for ett år, eller er det kun førstegangsknus...?
Mener å huske at så lenge produktet er under ett år gammelt, så spanderer de skjermen for deg og du betaler kun for arbeidet. Vil tro du kan bytte skjerm så ofte du vil egentlig.
Endret av gard.
Orker ikke å lete gjennom utallige poster, men hvis noen kan henvise meg med link og greier så er det bra.
Jeg har spotify, ikke premium, på tlf. Så har jeg lokale filer på pc-en som jeg har i en spilleliste. Jeg har da valgt å dele disse lokale filene over spotify til mobilen, sånn at når jeg oppdaterer på pcen så oppdaterer jeg musikken på mobilen. Veldig greit, gjorde det på SE X10 så burde gå hær også. Men problemet er at musikkspilleren (standard) på tlf, ikke finner noen av sangene som spotify har lagret på telefonen. Noen som vet hvordan jeg kan fikse det? Etter som jeg kan se så er de lagret inne på tlf. har et 8gb, minnekort, men der har jeg bare bilder. Men uansett så burde ikke det ha noe å si (jeg burde jo kunne gjøre dette uten minnekort også)
Også en ting til. når jeg skriver så står det sånn ordforslag på over bokstavene, det er greit, men går det ann å ta på at de ikke automatisk blir brukt, men brukes bare når jeg selv går og trykker på forslaget? jeg har prøvd utallige instillingskombinasjoner, men finner ikke ut av det.
Takk
