@ndreas Skrevet 28. august 2003 Del Skrevet 28. august 2003 jeg bruker mirc regelmessig, helt til i går da sluttet det plutselig å virke? har prøvd en rekke java chats, men samme feilen der... takknemlig for hjelp -OperServ- The session limit for your host xxxxxxxx-xxx.xxxxxxxx-x.xxxxxxxx.no has been exceeded. - -Bot- For security reasons, all connections to this network are subject to a proxy scan. If your firewall reports a connection attempt from 216.194.70.12, please disregard it as it is the proxy scan in action and not a hack attempt or attack. - * You were killed by OperServ (OperServ (Session limit exceeded)) - Closing Link: xxxxxxxx-xxx.xxxxxxxx-x.xxxxxxxx.no Andreas (Killed (OperServ (Session limit exceeded))) - * Disconnected Lenke til kommentar
b-real Skrevet 28. august 2003 Del Skrevet 28. august 2003 Så vidt så jeg kan se så må du nokk prøve en annen server en den du bruker til vanlig. "((Session limit exceeded)" betyr som oftest at den DNS'en har for mange connections. Prøv en annen server. Lenke til kommentar
