måling avleses i kontrollrom?
Er innholdet i tanken kjent? Er iallfall klassifikasjonen av innholdet (brannfarlig, eksplosivt, etsende o.l.) kjent? Hvor langt unna tanken er kontrollrommet? Er det mulig å gjøre tanken gjennomsiktig og plassere den slik at man kan se tanken fra kontrollrommet?
Hvis en person leser av tanken og så hopper inn i en av forsvarets sine feltbusser og kjører til kontrollrommet og så skriver ned verdien der så vil man kunne bruke et slikt feltbussystem.
Det jeg prøver å si er at litt mer kontekst rundt spørsmålet hadde vært greit. Hvis ikke så kan man ende opp med mange svar som teknisk sett er riktig slik som dette:
The following concerns a question in a physics degree exam at the
University of Copenhagen:
"Describe how to determine the height of a skyscraper with a barometer."
One student replied:
"You tie a long piece of string to the neck of the barometer, then lower the barometer from the roof of the skyscraper to the ground. The length of the string plus the length of the barometer will equal the height of the building."
This highly original answer so incensed the examiner that the student was failed immediately. The student appealed on the grounds that his answer was indisputably correct, and the university appointed an independent arbiter to decide the case.
The arbiter judged that the answer was indeed correct, but did not display any noticeable knowledge of physics. To resolve the problem it was decided to call the student in and allow him six minutes in which to provide a verbal answer that showed at least a minimal familiarity with the basic principles of physics.
For five minutes the student sat in silence, forehead creased in thought. The arbiter reminded him that time was running out, to which the student replied that he had several extremely relevant answers, but couldn't make up his mind which to use. On being advised to hurry up the student replied as follows:
"Firstly, you could take the barometer up to the roof of the skyscraper, drop it over the edge, and measure the time it takes to reach the ground. The height of the building can then be worked out from the formula H = 0.5g x t squared. But bad luck on the barometer."
"Or if the sun is shining you could measure the height of the barometer, then set it on end and measure the length of its shadow. Then you measure the length of the skyscraper's shadow, and thereafter it is a simple matter of proportional arithmetic to work out the height of the skyscraper."
"But if you wanted to be highly scientific about it, you could tie a short piece of string to the barometer and swing it like a pendulum, first at ground level and then on the roof of the skyscraper. The height is worked out by the difference in the gravitational restoring force T =2 pi sqr root (l /g)."
"Or if the skyscraper has an outside emergency staircase, it would be easier to walk up it and mark off the height of the skyscraper in barometer lengths, then add them up."
"If you merely wanted to be boring and orthodox about it, of course, you could use the barometer to measure the air pressure on the roof of the skyscraper and on the ground, and convert the difference in millibars into feet to give the height of the building."
"But since we are constantly being exhorted to exercise independence of mind and apply scientific methods, undoubtedly the best way would be to knock on the janitor's door and say to him 'If you would like a nice new barometer, I will give you this one if you tell me the height of this skyscraper'."
The student was Niels Bohr, the only Dane to win the Nobel Prize for physics.
Oppgaven er slik:
Du er ansatt i firmaet miljøtank AS, der de oppbevarer og destruerer farlig avfall. avfallet blir oppbevart i tanker som er plassert på firmaets inngjerede område.
Det skal monteres en ny tank som skal inneholde en blanding av forskjellige væsker. egenvekten av væskeblandingen i tanken kan variere og den kan være etsende. det er viktig å måle nivået i den nye tanken.
på området er det et lite kontrollrom hvor alle målingene av tilstanden i tankene kan sees på PC-skjerm.
Din oppgave er å få nivåmålingen i tanken til å kunne avleses i kontrollrommet. du står selv fritt for å velge utstyr.
Sier meg enig med Luske_Ludvig. DP cella er vel ellers standard for nivåmåling, men med variabel egenvekt, så går vel ikke det. Har ikke vært borte i lasermåling til den slags bruk. Mener at en ultralydmålet plassert på toppen av tanken vil være "stanard valg".
Ellers så kan man jo vanligvis koble opp på enkleste måte ved så seriekoble målesensor, en strømforsyning på 24V og et analogt måleinstrument på 4-20 mA. Litt mer avansert så bruker man et eller annet system for (sivil) feltbus og en ditto tilhørende analog til digital converter. (For eksempel en PLS inngang med disse egenskaper.) Hvis inngangen på PLS'en eller converteren skulle kreve spenningssignal (1-5V eller 2-10V) i stedet for signalstrøm, så konverterer man fra strøm til spenning vha en resistans.
Endret av arne22
