internett disconecter Ofte!
hei. har et problem som jeg har hatt så lenge jeg kan huske med internetten, har internett os Canal digital. og internetten kobler seg ut i sån 1-2 sekunder hver 7-8minutt uten grunn, når jeg spiller Counter strike så får jeg Dc hvert 7min. og samme med skype når jeg er i samtaler så får jeg Dc hvert 7min.. noen som har noe peiling på hva som er galt og hvordan man fikser det?
Her er Security loggen hvis det hjelper noe
[2000-01-01 00:00:15]: start Dynamic IP
[2000-01-01 00:00:18]: [sNTP]: connect to TimeServer 192.43.244.18 ...
[2000-01-01 00:00:18]: [sNTP]: connect fail!!
[2000-01-01 00:00:21]: [sNTP]: connect to TimeServer 192.43.244.18 ...
[2000-01-01 00:00:21]: [Firewall]: WAN1 IP is 192.168.81.2
[2000-01-01 00:00:21]: [Firewall]: WAN2 IP is 0.0.0.0
[2000-01-01 00:00:21]: [Firewall]: WAN3 IP is 0.0.0.0
[2000-01-01 00:00:21]: [Firewall]: setting firewall...
[2000-01-01 00:00:31]: [sNTP]: connect fail!!
[2000-01-01 12:30:38]: [sNTP]: connect to TimeServer 192.43.244.18 ...
[2012-04-18 02:30:51]: [sNTP]: connect success!
[2012-04-18 02:30:51]: [sNTP]: set time to 2012-04-18 02:30:51
[2012-04-18 14:58:04]: [sNTP]: connect to TimeServer 192.43.244.18 ...
[2012-04-18 14:58:03]: [sNTP]: connect success!
[2012-04-18 14:58:03]: [sNTP]: set time to 2012-04-18 14:58:03
[2012-04-19 03:27:05]: [sNTP]: connect to TimeServer 192.43.244.18 ...
[2012-04-19 03:27:04]: [sNTP]: connect success!
[2012-04-19 03:27:04]: [sNTP]: set time to 2012-04-19 03:27:04
[2012-04-19 15:54:40]: [sNTP]: connect to TimeServer 192.43.244.18 ...
[2012-04-19 15:54:39]: [sNTP]: connect success!
[2012-04-19 15:54:39]: [sNTP]: set time to 2012-04-19 15:54:39
[2012-04-20 04:23:11]: [sNTP]: connect to TimeServer 192.43.244.18 ...
[2012-04-20 04:23:11]: [sNTP]: connect success!
[2012-04-20 04:23:11]: [sNTP]: set time to 2012-04-20 04:23:11
[2012-04-20 16:51:25]: [sNTP]: connect to TimeServer 192.43.244.18 ...
[2012-04-20 16:51:23]: [sNTP]: connect success!
[2012-04-20 16:51:23]: [sNTP]: set time to 2012-04-20 16:51:23
[2012-04-21 05:20:14]: [sNTP]: connect to TimeServer 192.43.244.18 ...
[2012-04-21 05:20:13]: [sNTP]: connect success!
[2012-04-21 05:20:13]: [sNTP]: set time to 2012-04-21 05:20:13
[2012-04-21 17:49:14]: [sNTP]: connect to TimeServer 192.43.244.18 ...
[2012-04-21 17:49:13]: [sNTP]: connect success!
[2012-04-21 17:49:13]: [sNTP]: set time to 2012-04-21 17:49:13
[2012-04-22 06:18:40]: [sNTP]: connect to TimeServer 192.43.244.18 ...
[2012-04-22 06:18:40]: [sNTP]: connect success!
[2012-04-22 06:18:40]: [sNTP]: set time to 2012-04-22 06:18:40
[2012-04-22 18:47:22]: [sNTP]: connect to TimeServer 192.43.244.18 ...
[2012-04-22 18:47:21]: [sNTP]: connect success!
[2012-04-22 18:47:21]: [sNTP]: set time to 2012-04-22 18:47:21
[2012-04-23 07:17:01]: [sNTP]: connect to TimeServer 192.43.244.18 ...
[2012-04-23 07:17:00]: [sNTP]: connect success!
[2012-04-23 07:17:00]: [sNTP]: set time to 2012-04-23 07:17:00
[2012-04-23 19:44:23]: [sNTP]: connect to TimeServer 192.43.244.18 ...
[2012-04-23 19:44:22]: [sNTP]: connect success!
[2012-04-23 19:44:22]: [sNTP]: set time to 2012-04-23 19:44:22
[2012-04-24 08:12:06]: [sNTP]: connect to TimeServer 192.43.244.18 ...
[2012-04-24 08:12:05]: [sNTP]: connect success!
[2012-04-24 08:12:05]: [sNTP]: set time to 2012-04-24 08:12:05
[2012-04-24 20:39:45]: [sNTP]: connect to TimeServer 192.43.244.18 ...
[2012-04-24 20:39:45]: [sNTP]: connect success!
[2012-04-24 20:39:45]: [sNTP]: set time to 2012-04-24 20:39:45
[2012-04-25 09:07:05]: [sNTP]: connect to TimeServer 192.43.244.18 ...
[2012-04-25 09:07:04]: [sNTP]: connect success!
[2012-04-25 09:07:04]: [sNTP]: set time to 2012-04-25 09:07:04
[2012-04-25 21:34:42]: [sNTP]: connect to TimeServer 192.43.244.18 ...
[2012-04-25 21:34:40]: [sNTP]: connect success!
[2012-04-25 21:34:40]: [sNTP]: set time to 2012-04-25 21:34:40
[2012-04-26 10:01:59]: [sNTP]: connect to TimeServer 192.43.244.18 ...
[2012-04-26 10:01:59]: [sNTP]: connect success!
[2012-04-26 10:01:59]: [sNTP]: set time to 2012-04-26 10:01:59
[2012-04-26 22:29:43]: [sNTP]: connect to TimeServer 192.43.244.18 ...
[2012-04-26 22:29:43]: [sNTP]: connect success!
[2012-04-26 22:29:43]: [sNTP]: set time to 2012-04-26 22:29:43
[2012-04-27 10:56:59]: [sNTP]: connect to TimeServer 192.43.244.18 ...
[2012-04-27 10:56:57]: [sNTP]: connect success!
[2012-04-27 10:56:57]: [sNTP]: set time to 2012-04-27 10:56:57
[2012-04-27 23:25:27]: [sNTP]: connect to TimeServer 192.43.244.18 ...
[2012-04-27 23:25:27]: [sNTP]: connect success!
[2012-04-27 23:25:27]: [sNTP]: set time to 2012-04-27 23:25:27
[2012-04-28 11:53:14]: [sNTP]: connect to TimeServer 192.43.244.18 ...
[2012-04-28 11:53:13]: [sNTP]: connect success!
[2012-04-28 11:53:13]: [sNTP]: set time to 2012-04-28 11:53:13
[2012-04-28 17:07:17]: start Dynamic IP
[2012-04-28 17:07:20]: [sNTP]: connect to TimeServer 192.43.244.18 ...
[2012-04-28 17:07:20]: [sNTP]: connect fail!!
[2012-04-28 17:07:20]: [DNS]: dns restart ...
[2012-04-28 17:07:21]: [sNTP]: connect to TimeServer 192.43.244.18 ...
[2012-04-28 17:07:21]: [sNTP]: connect success!
[2012-04-28 17:07:21]: [sNTP]: set time to 2012-04-28 17:07:21
[2012-04-28 17:07:21]: [Firewall]: WAN1 IP is 192.168.81.2
[2012-04-28 17:07:21]: [Firewall]: WAN2 IP is 0.0.0.0
[2012-04-28 17:07:21]: [Firewall]: WAN3 IP is 0.0.0.0
[2012-04-28 17:07:21]: [Firewall]: setting firewall...
[2012-04-28 17:09:01]: start Dynamic IP
[2012-04-28 17:09:04]: [sNTP]: connect to TimeServer 192.43.244.18 ...
[2012-04-28 17:09:04]: [sNTP]: connect fail!!
[2012-04-28 17:09:04]: [DNS]: dns restart ...
[2012-04-28 17:09:06]: [sNTP]: connect to TimeServer 192.43.244.18 ...
[2012-04-28 17:09:06]: [sNTP]: connect success!
[2012-04-28 17:09:06]: [sNTP]: set time to 2012-04-28 17:09:06
[2012-04-28 17:09:06]: [Firewall]: WAN1 IP is 192.168.81.2
[2012-04-28 17:09:06]: [Firewall]: WAN2 IP is 0.0.0.0
[2012-04-28 17:09:06]: [Firewall]: WAN3 IP is 0.0.0.0
[2012-04-28 17:09:06]: [Firewall]: setting firewall...
[2012-04-28 17:09:16]: [DNS]: dns restart ...
[2012-04-28 17:09:51]: start Dynamic IP
[2012-04-28 17:09:53]: [sNTP]: connect to TimeServer 192.43.244.18 ...
[2012-04-28 17:09:54]: [sNTP]: connect success!
[2012-04-28 17:09:54]: [sNTP]: set time to 2012-04-28 17:09:54
[2012-04-28 17:09:54]: [Firewall]: WAN1 IP is 192.168.81.2
[2012-04-28 17:09:54]: [Firewall]: WAN2 IP is 0.0.0.0
[2012-04-28 17:09:54]: [Firewall]: WAN3 IP is 0.0.0.0
[2012-04-28 17:09:54]: [Firewall]: setting firewall...
[2012-04-29 05:41:13]: [sNTP]: connect to TimeServer 192.43.244.18 ...
[2012-04-29 05:41:12]: [sNTP]: connect success!
[2012-04-29 05:41:12]: [sNTP]: set time to 2012-04-29 05:41:12
[2012-04-29 18:11:01]: [sNTP]: connect to TimeServer 192.43.244.18 ...
[2012-04-29 18:11:00]: [sNTP]: connect success!
[2012-04-29 18:11:00]: [sNTP]: set time to 2012-04-29 18:11:00
[2012-04-30 06:39:02]: [sNTP]: connect to TimeServer 192.43.244.18 ...
[2012-04-30 06:39:01]: [sNTP]: connect success!
[2012-04-30 06:39:01]: [sNTP]: set time to 2012-04-30 06:39:01
[2012-04-30 19:06:35]: [sNTP]: connect to TimeServer 192.43.244.18 ...
[2012-04-30 19:06:34]: [sNTP]: connect success!
[2012-04-30 19:06:34]: [sNTP]: set time to 2012-04-30 19:06:34
[2012-05-01 07:34:42]: [sNTP]: connect to TimeServer 192.43.244.18 ...
[2012-05-01 07:34:42]: [sNTP]: connect success!
[2012-05-01 07:34:42]: [sNTP]: set time to 2012-05-01 07:34:42
[2012-05-01 20:03:11]: [sNTP]: connect to TimeServer 192.43.244.18 ...
[2012-05-01 20:03:10]: [sNTP]: connect success!
[2012-05-01 20:03:10]: [sNTP]: set time to 2012-05-01 20:03:10
[2012-05-02 08:33:12]: [sNTP]: connect to TimeServer 192.43.244.18 ...
[2012-05-02 08:33:11]: [sNTP]: connect success!
[2012-05-02 08:33:11]: [sNTP]: set time to 2012-05-02 08:33:11
[2012-05-02 21:00:58]: [sNTP]: connect to TimeServer 192.43.244.18 ...
[2012-05-02 21:00:58]: [sNTP]: connect success!
[2012-05-02 21:00:58]: [sNTP]: set time to 2012-05-02 21:00:58
[2012-05-03 09:28:30]: [sNTP]: connect to TimeServer 192.43.244.18 ...
[2012-05-03 09:28:29]: [sNTP]: connect success!
[2012-05-03 09:28:29]: [sNTP]: set time to 2012-05-03 09:28:29
[2012-05-03 21:56:59]: [sNTP]: connect to TimeServer 192.43.244.18 ...
[2012-05-03 21:56:58]: [sNTP]: connect success!
[2012-05-03 21:56:58]: [sNTP]: set time to 2012-05-03 21:56:58
[2012-05-04 10:24:36]: [sNTP]: connect to TimeServer 192.43.244.18 ...
[2012-05-04 10:24:35]: [sNTP]: connect success!
[2012-05-04 10:24:35]: [sNTP]: set time to 2012-05-04 10:24:35
[2012-05-04 22:52:21]: [sNTP]: connect to TimeServer 192.43.244.18 ...
[2012-05-04 22:52:20]: [sNTP]: connect success!
[2012-05-04 22:52:20]: [sNTP]: set time to 2012-05-04 22:52:20
[2012-05-05 11:20:21]: [sNTP]: connect to TimeServer 192.43.244.18 ...
[2012-05-05 11:20:19]: [sNTP]: connect success!
[2012-05-05 11:20:19]: [sNTP]: set time to 2012-05-05 11:20:19
har windows 7.. stasjonær pc, bruker internett adapter fra d-link for å koble til trådløs ellers så må jeg ha 40-50meter med internett kabel.. har samme problem med den gammle laptopen min, å har byttet ruter/moden mange ganger.. faren min har snakka med canal digital sikkert 100 ganger.. de som har bytta modemet, fått kjappere hastighet.. men ingenting virker
OK, du får prøve å finne ut hvor det svikter. Avstanden til routeren kan jo indikere at signalstyrken er noe svak. Dermed blir du sårbar for støykilder (andre trådløsnett mm).
Videre er ikke Jensen kjent for å være de mest stabile routerne.
Foreslår du laster ned Pingplotter og sjekker den neste gang du faller ut. Da vil du se om forbindelsen faller ut til routeren (192.168.x.x) eller mot selve internett (modem->sentral) som er linje 2 på bildet under.
Foreslår du laster ned Pingplotter og sjekker den neste gang du faller ut. Da vil du se om forbindelsen faller ut til routeren (192.168.x.x) eller mot selve internett (modem-&--#62;sentral) som er linje 2 på bildet under.
uansett hva jeg skriver inn på adress to trace så står det at destination adress unreachable Endret av glenni92
Hei
Du skriver at du vil trenge 40-45m ledning, vil det si at du sitter såpass langt unna ruteren ?
Hvis det er tilfelle så er det nok avstanden + eventuelle andre trådløse nettverk som gjør det trådløse
nettverket utstabilt.
Om det er Jensen ruter du har, så send oss en epost på [email protected] så skal vi sjekke det opp nærmere.
Mvh. Tor
Kan garantere deg at det er avstanden som er problemet om du sitter 40-45 meter fra routern. Prøv med en laaang ledning som det står et par poster over eller flytt pcen bare for å teste.
Med den avstanden så er det vel nok at faren din går forbi routern så ramler du av nettet :p
  • 9 måneder senere...
har samme problemet jeg å men en litt annen variant av oppsett:)
[2012-05-01 20:06:16]: [sNTP]: connect to TimeServer 192.43.244.18 ...
[2012-05-01 20:06:17]: [FIREWALL]: WAN IP is 192.168.100.10 setting firewall...
[2012-05-01 20:06:17]: [FIREWALL]: WAN2 IP is setting firewall...
[2012-05-01 20:06:26]: [sNTP]: connect fail!!
[2012-05-01 20:07:05]: [sNTP]: connect to TimeServer 192.43.244.18 ...
[2012-05-01 20:07:06]: [FIREWALL]: WAN IP is 31.45.90.242 setting firewall...
[2012-05-01 20:07:06]: [FIREWALL]: WAN2 IP is setting firewall...
[2012-05-01 20:07:15]: [sNTP]: connect fail!!
får dette som siste rapport etter siste disconnect.
Hjemme her, så leier vi i kjeller'n, og der er "main router" oppe hos huseiern og vår fungerer som ett access punkt. ingen lang rekkevidde, 5 meter max! :)
Problemet begynte etter huseier'n skifta til en Airlink 3000dg.
da begynte nettet å dette ut, men komme igjen etter noen sekunder (veldig lett å game kan du si)
router'n jeg har nede som er access punkt er en d-link dir-655
Idag har vi prøvd å oppdatere firmware på main-router, reset på den jeg har nede, (fant ikke noe nye firmware update på d-link"
men ingenting hjelper.
Jeg og samboer'n har merka at det er når vi overbelaster nettet en del, da vi begge spiller diablo 3 f.eks... da detter den raskere ut enn når vi bare sitter og surfer nettet....
tenkte jeg skulle prøve i natt å koble bort min router her nede, også gå inn og se på loggen på main-router om det har skjedd noe over natten. Da får vi vel kanskje utelukket at det ikke er min nede? eller? o_O
men som sagt, dette problemet begynte når huseier'n skifta router oppe, før dette funket det bra :) (router'n hans sluttet å fungere visstnok i følge han, gammel mann som ikke er helt inni det nymotens utstyret kan du si)
