Til alle med MSI HK (klipp & lim fra http://www.the-ctrl-alt
Jon
MSI Bios Updates (fixed)
Anonymous writes " MSI has new Bios updates, most notably for the following models:
K7T266Pro2-RU
K7T266Pro2
Ver. 3.4 Bios Notes taken from MSI's Page:
Fixed AMD Morgan CPU showing message
Hidden "BIOS Protection" item in BIOS setup menu & set default as disable (this means user dont have to set BIOS protection when flashing the BIOS starting from BIOS 3.4)
Set BIOS setup "Wakeup On PME" as disabled
Fixed Matrox G550 AGP card can't install WinXP problem
Fixed that ToolsEvent ViewerSystemACPI error when system enters S1 status under WinXP
Fixed Adaptec SCSI RAID 2100S compatibility issue.
I downloaded this Bios for my K7T266Pro2-RU a couple days ago from the MSI Germany site, and memory scores are much better than the last few versions, comparable to the original 3.0 Bios.
Good luck, and make sure to backup your current Bios before flashing!
Johnny Changs
[email protected]"
Plukkes opp her: http://www.msi.com.tw/
