nytt online spill trenger spillere
hei alle sammen. Jeg og noen kompiser har laget ett lite online multiplayer
spill som foregår i chicago i 1930 årene der du styrer en oppadstormende
mafia familie. Spillet er nå mer eller mindre færdig i sin første utgave og vi trenger spillere. Vi har skrivi ett lite sammendrag av spillet og sånt på engelsk (for aa naa saa mange spillere som mulig) og
jeg legger det ved her slik at de av dere som har lyst til å teste det kan gjøre det. bare merk at spillet kanskje ikke passer for de aller minste..
kanskje ikke noe problem da alt er på engelsk uansett :)
følg linken nerderst for å teste spillet.
kennethj
Hi everybody, me and a couple of friends have created an online
multiplayer game. Based in chicago in the 1930's. It is now almost
complete and we need players to test it. That is, we have tested the
game for bugs, etc, but now we need a couple of hundred players to
verify that our design and game idea is sound. You as a player are in
charge of a small mob family and you need to fight your way to the top
using tooth and nail.. (well, concrete and assassinations might be a
better term :) Lead your family to the top by hiring con-men,
prostitutes and gunmen and get your neighbour before he gets you.
The first turn starts tomorrow at 09.00 GMT / 10.00 local time
(Central European Time, used in Germany, Norway, Sweden, Iceland,
Spain, Nigeria, etc), which is 03.00am US/central for those of you on
the wrong side of the atlantic :) If you are in doubt, just go to the
link below and check how many hours until the next tick :)
It might be a good idea to register and insert your first orders at
the below address before ya all go to bed tonight.
Some technical specs:
turn based (4 hour turns for now)
you need to enable cookies in your browser
your browser must be able to view frames and tables.
You must have a valid email address.
The visual aspects of the game was developed using mostly mozilla and
netscape. IE and opera works as well, but konquerer is not working
properly at the moment. As the game is written entirely on our spare time
there will be no commercials :)
PS: We added stuff from various sources, and the resulting game is by no
means historical correct.
Anyways. the link is: http://mobster.td.org.uit.no/mobster/
ah..ok.. jeg skjoenner... vell.. hva skal jeg si... vi har med vilje holdt oss unna alt som lukter
av javascript, flash, andre ting som ikke stoettes orntli i mozilla, opera og netscape.
resultatet er da det dere ser, enkelt og greit :).. haaper jo at innholdet er det som er viktig :)
naar det er sakt saa er det ogsaa en annen grunn.. dette prosjekte begynte i det smaa og
blei deretter stoerre og stoerre, med det resultatet at det er en del ugrei kode som ikke
er helt trivielt aa rote med :roll:
vi faar se hva som skjer fremover
kennethj
satt på jobb med UTF-8 på linux.... :-?
har du noen spm så kan du enten logge deg inn på irc.student.uit.no
kanal #mobster og sjekke der eller prøve forumet vårt på spill siden.
er alltid motakelig for forslag kritikk (konstruktiv sådan :) )
kennethj
hm.. da jeg aldri har hørt om idlepimps så da kan det umulig være en klone.. men jeg skal sjekke det ut nuh.. kan jo være veldig likt
(selv om jeg tviler litt på det...synes vi har hatt mange orginale ideer :woot: )
kennethj
