Lakusland v3 - 1.14.4 endelig
Ettersom den forbanna trappa jeg bomma på (og Skyrim) i Morningwoods vinterbiome tok knekken på meg er jeg helt for å starte ny verden. Men så er jeg vel egentlig ikke på så veldig mye mer så min stemme trenger ikke telle all verdens.
Ja, sånn sett er det dumt at ikke 1.7 kommer nå neste uke. Ingen gidder å logge på når ingen andre er på. Kjenner igjen symptomene. Om det er noen trøst har jeg vært lite online pga ferie frem til nå, men nå er ferien over :p
Har begynt å trille ut småting om 1.7 forresten. Er frmdeles en stund igjen og om det lille de har vist allerede blir en pekepinn kan det bli en del nytt stuff.
Contains biome changes and new biomes, and might contain changes to oceans.[2][3][4]
Improved biome transition/generation.[5] (sannsynligvis slutt på jungel og is-biome rett sidenav hverandre og bedre overganger mellom biomes)
Clay Canyon biome[6] jokingly referred to as "Disco Mountains".[7]
Composed of multiple colored hardened clay.
Dead bushes spawn in this biome.
Redwood Forest biome.[8]
Contains 2x2 Spruce trees.
Will have a grass block variant known as Podzol.[9][10]
Currently obtained only by the silk touch enchantment.[11]
Contains dirt blocks that do not allow grass to grow.
They have a data value of 1.
Only obtainable with /give because there is no visual difference.[12][13]
Moss Stone "boulders" are scattered around in this biome.
Dead Bushes, Mushrooms, and Ferns spawn in this biome.
A cliff technical biome.[14]
Main block is stone.
Like Steep hills, not completely vertical.
Spruce Trees will generate in Extreme Hills biomes.[15]
Snow may now generate depending on Y level, with noise variation.[16]
Biome dependent.[17]
Lighting fixes.
A lot fewer "black spots" in the terrain generator.[18]
Torch bugs in strongholds and mineshafts have been fixed.[19][20]
Changes to fishing mechanics.[21][22][23][24][25]
Possibly Cherry Trees added by Patrick Geuder.[26][27]
They vary "seasonally" by having leaf blocks change color every fourth day for three minutes.[28]
Contain pink saplings.[29]
Redoing the achievements and statistics system.[30]
Will be per world/server.[31]
New scoreboard functions.[32][33][34][35]
New Flowers.
Sunflowers.[36]
Always face East.[37]
What appears to be Lavender.[38]
What appears to be two block tall grass.[39]
Rewrite of one or more option screens.[40]
Rewrote Key Config.[41]
Function and sprint keys can be changed.
Endret av Lakus
I tilfelle nytt map: er det mulig for meg å få lagt over skipene jeg bygger på, samt den svære stargaten? Har vært mye pes med å lage de. Eller blir det fra scratch på alle måter?
Edit: Har avlagt feil stemme, skulle naturligvis stemme på sau. Men for å få med nye biomes er det mer eller mindre nødvendig å få et nytt kart.
Endret av Zetheus
Enten så blir kartet helt wipet, eller så blir det ikke det. Blir neppe noe overføring i og med at det må være rettferdig for alle.
Nå må vi huske at jeg ikke er en av "alle" da, jeg er meg, tihi <3
Endret av SLi
Ser ut som dette bare går en vei *sukk*. Jaja, en annen grunn til at det er lite aktivitet nå er vell fordi det blir litt meningsløst å bygge masse nytt, eller starte på store nye prosjekter vis vi vet at "worlden" skal slettes om ikke så alt for lenge.. :dontgetit:
Men for all del, ser at det kanskje er på tide med en ny verden, spesielt når 1.7 bringer med seg så mye nytt "bios" osv. (Men litt ergelig er det da :( )
Se annerledes på det: tenk hvor mange som er på dersom det blir nytt map! Da tar aktiviteten seg opp igjen, helt sikkert.
Man trenger en forandring en gang i blant, og halvparten av moroa i Minecraft er jo å bygge seg opp en base og flere og flere items etterhvert.
Hvis ikke lakus trenger forslag til nye fylkes-sentre da?
Der er jeg enig, Jeg har kommet til et punkt hvor jeg nærmer meg en dobbelkiste full med diamanter, hvis jeg selger alt av lapiz, blir jeg kanskje 2. rikest på serveren. Jeg har mye av alt...
Den største utfordringen er å få utført alle prosjektene mine...
Endret av Itek
