Lakusland v3 - 1.14.4 endelig
Kan forandre på hva slags items de "fester" seg på, og de som her "fester seg pÅ" pickaxes gir ikke mening på en pickaxe etter min mening, så forandrer det sikkert. Spør du meg burde mesteparten egentlig være på sverd/økser.
Liste over defaults:
Adrenaline
Pack: EnchantPotionPack
Items: Leggings
Max Level: 5
Effect: Applies tier 2 strength when hit by an enemy for (0.5 + 0.5 * level) seconds
Angler
Pack: EnchantActivePack
Items: Fishing Rod
Max Level: 5
Effect: Catch one extra fish per enchantment level while fishing
Barrier Trap
Pack: EnchantTrapPack
Items: Shovels
Max Level: 5
Lifespan: (5 + level) seconds*
Cooldown: 20 seconds
Effect: Right click to place a redstone symbol at your feet if there is room. While active, the symbol pushes away all approaching enemies. Right clicking again while inside the trap removes it and refunds 5 seconds of the cooldown. The trap expires after moving more than 50 blocks away, logging out, having the server refresh, or after the lifespan runs out.
Berserking
Items: Axes
Max Level: 5
Effect: Grants bonus damage on hit for (0.5 + 0.5 * level) seconds
Blind
Items: Pickaxes
Max Level: 5
Effect: Applies tier 2 blindness when you hit an enemy for (0.5 + 0.5 * level) seconds
Bomb Trap ===
Items: Shovels
Max Level: 5
Lifespan: infinite
Power: (1.5 + 0.5 * level)
Effect: Right click to place a redstone symbol at your feet if there is room. The trap detonates when an enemy enters it, removing the trap and damaging the enemy. Right clicking again while inside the trap removes it and refunds 5 seconds of the cooldown. The trap expires after moving more than 50 blocks away, logging out, having the server refresh, or after the lifespan runs out.
Brilliance
Items: Helmets
Max Level: 5
Effect: Applies tier 2 blindness to an enemy when they hit you for (0.5 + 0.5 * level) seconds
Cursed
Items: Chestplates
Max Level: 5
Effect: Applies tier 2 wither to an enemy when they hit you for (0.5 + 0.5 * level) seconds
Dash
Items: Swords
Max Level: 5
Effect: Dashes forward upon right click and damages all enemies passed through for 1 damage per level (5 second cooldown)
Demoralizing
Items: Chestplates
Max Level: 5
Effect: Applies tier 2 weakness to an enemy when they hit you for (0.5 + 0.5 * level) seconds
Distortion
Items: Hoes
Max Level: 5
Effect: Grants invisibility for (0.5 + 0.5 * level) seconds on attack
Fervor
Items: Swords
Max Level: 5
Effect: Grants tier 2 bonus movement speed for (0.5 + 0.5 * level) seconds on hit
Fireball
Items: Blaze Rod
Max Level: 10
Cooldown: (21.6 - 1.6 * level) seconds
Fire Trap
Items: Shovels
Max Level: 5
Lifespan: infinite
Power: (1.25 + 0.25 * level)
Effect: Right click to place a redstone symbol at your feet if there is room. The trap detonates when an enemy enters it, removing the trap and damaging the enemy while creating fire around the enemy. Right clicking again while inside the trap removes it and refunds 5 seconds of the cooldown. The trap expires after moving more than 50 blocks away, logging out, having the server refresh, or after the lifespan runs out.
Forceful
Pack: EnchantPassivePack
Items: Axes
Max Level: 6
Effect: On hit, deals 1 damage to all enemies within a (5 + level) block radius of the target and pushes them back slightly
Fried
Items: Fishing Rod
Max Level: 1
Effect: Catch cooked fish instead of raw fish
Frost
Items: Leggings
Max Level: 5
Effect: Applies tier 2 slowness to an enemy when they hit you for (0.5 + 0.5 * level) seconds
Grapple
Items: Fishing Rod
Max Level: 5
Range: (8 + 2 * level) blocks
Effect: Reeling in a bobber within range will grapple you towards the spot where it landed if it was stuck in the ground.
Gravity
Items: Swords
Max Level: 6
Effect: On attack, slightly pulls all enemies within a (4 + level) block radius towards you and deals 1 damage to each one
Heal
Items: Blaze Rod
Max Level: 5
Cooldown: 15 seconds
Effect: Heals yourself for (2 * level) health or heals the target ally for the same amount
Ice Trap
Items: Shovels
Max Level: 5
Lifespan: (4 + level) seconds
Effect: Right click to place a redstone symbol at your feet if there is room. While active, the trap prevents enemies from leaving the area. Right clicking again while inside the trap removes it and refunds 5 seconds of the cooldown. The trap expires after moving more than 50 blocks away, logging out, having the server refresh, or after the lifespan runs out.
Jump
Items: Boots
Max Level: 2
Effect: Grants passive bonus to jumping of a tier matching the enchant level
Knockup
Pack: EnchantPassivePack Items: Swords
Max Level: 4
Effect: Gives a (2.5 + 2.5 * level)% chance to knock the target up in the air on hit
Launch Trap
Items: Shovels
Max Level: 5
Lifespan: infinite
Speed: (2.5 + 0.5 * level)
Effect: Right click to place a redstone symbol at your feet if there is room. The trap launches the first enemy entering the trap up into the air. Right clicking again while inside the trap removes it and refunds 5 seconds of the cooldown. The trap expires after moving more than 50 blocks away, logging out, having the server refresh, or after the lifespan runs out.
Life
Items: Chestplates
Max Level: 6
Effect: Grants an extra (5 * level) health when equipped (does not stack)
Lifesteal
Item: Hoes
Max Level: 5
Effect: Heals the user on hit for 1 health (half a heart) per enchant level (5 second cooldown)
Lightning
Items: Axes
Max Level: 5
Effect: Grants a (4 * level)% chance to strike lightning on hit
Lightning Trap
Items: Shovels
Max Level: 5
Lifespan: infinite
Cooldown: (17 - 2 * level) seconds
Effect: Right click to place a redstone symbol at your feet if there is room. The trap strikes lightning on the first enemy that enters it, removing the trap in the process. Right clicking again while inside the trap removes it and refunds 5 seconds of the cooldown. The trap expires after moving more than 50 blocks away, logging out, having the server refresh, or after the lifespan runs out.
Lively
Items: Boots
Max Level: 5
Effect: Applies tier 2 movement speed boost to yourself when hit by an enemy for (0.5 + 0.5 * level) seconds
Night Vision
Items: Helmets
Max Level: 2
Effect: Passively grants night vision of a tier equal to the enchant level
Phantom
Items: Boots
Max Level: 5 Effect: Applies invisibility to yourself when hit by an enemy for (0.5 + 0.5 * level) seconds
Poison
Items: Hoes
Max Level: 5
Effect: Applies tier 2 poison on hit for (0.5 + 0.5 * level) seconds
Poison Trap
Items: Shovels
Max Level: 5
Duration: 7 seconds
Lifespan: (3 + 2 * level) seconds
Effect: Right click to place a redstone symbol at your feet if there is room. While active, all enemies passing through the trap become poisoned. Right clicking again while inside the trap removes it and refunds 5 seconds of the cooldown. The trap expires after moving more than 50 blocks away, logging out, having the server refresh, or after the lifespan runs out.
Pull
Items: Pickaxes
Max Level: 5
Effect: Pulls the target enemy towards you ([10 - level] second cooldown)
Rapid
Items: Bows
Max Level: 5
Effect: Increases the speed of fired arrows by (10 * level)%, increasing damage and accuracy
Reflection
Items: Chestplates
Max Level: 10
Effect: Reflects damage back at attackers equal to (10 * level)% of the damage, rounded down.
Regenerative
Items: Chestplates
Max Level: 3
Effect: Heals you for 1 health every (6 - level) seconds while equipped
Rejuvenating
Items: cooked beef, cooked chicken, cooked fish, cookie, bread, apple, rotten flesh, spider eye, fermented spider eye, carrot, baked potato
Max Level: 5
Effect: Heals yourself for (level) health by eating the item
Repulse
Items: Swords
Max Level: 5
Effect: Pushes away all enemies within 10 blocks ([10 - level] second cooldown)
Shadow Shift
Items: Leggings
Max Level: 5
Effect: has a (5 * level)% chance of teleporting randomly within 5 blocks and blinding all nearby enemies for 3 seconds
Slow
Items: Hoes
Max Level: 5
Effect: Applies tier 2 slow on hit for (0.5 + 0.5 * level) seconds.
Slow Trap
Items: Shovels
Max Level: 5
Duration: 7 Seconds
Effect: Right click to place a redstone symbol at your feet if there is room. While active, all enemies passing through the area are slowed. Right clicking again while inside the trap removes it and refunds 5 seconds of the cooldown. The trap expires after moving more than 50 blocks away, logging out, having the server refresh, or after the lifespan runs out.
Toss
Items: Diamond Sword
Max Level: 5
Effect: Right click to grab the target enemy and start carrying them. Right click again to launch them in the direction you are facing with a speed equal to your level.
Toxic
Items: Chestplates
Max Level: 5
Effect: Applies tier 2 poison to enemies that hit you for (0.5 + 0.5 * level) seconds
Vortex
Items: Pickaxes
Max Level: 5
Effect: Pulls all enemies within 10 blocks towards you ([10 - level] second cooldown)
Weakness
Items: Shovels
Max Level: 5
Effect: Applies tier 2 weakness to enemies you hit for (0.5 + 0.5 * level) seconds
Weakness Trap
Items: Shovels
Max Level: 5
Duration: 7 seconds
Effect: Right click to place a redstone symbol at your feet if there is room. While active, all enemies passing through the area have their damage reduced. Right clicking again while inside the trap removes it and refunds 5 seconds of the cooldown. The trap expires after moving more than 50 blocks away, logging out, having the server refresh, or after the lifespan runs out.
Web Trap
Items: Shovels
Max Level: 5
Lifespan: infinite
Duration: 7 seconds
Effect: Right click to place a redstone symbol at your feet if there is room. The first enemy that enters the trap have 27 webs spawned around them, holding them in place. Right clicking again while inside the trap removes it and refunds 5 seconds of the cooldown. The trap expires after moving more than 50 blocks away, logging out, having the server refresh, or after the lifespan runs out.
Wither
Items: Swords
Max Level: 5
Effect: Applies tier 2 wither to enemies you hit for (0.5 + 0.5 * level) seconds
