Lakusland v3 - 1.14.4 endelig
HaHA! Fikk tak i crashreport denne gangen!
Det i blått fanget oppmerksomheten min ettersom dette skjedde da pedvard logget inn.
EDIT: Farge-tags fungerer selvfølgelig ikke i "code-vindu". Men se på den tredje bolken med tekst: Entity being ticked
---- Minecraft Crash Report ----
// I blame Dinnerbone.
Time: 2013-02-16 16:50
Description: Ticking entity
java.lang.NullPointerException
at net.minecraft.server.v1_4_R1.WorldServer.getTileEntities(WorldServer.java:587)
at net.minecraft.server.v1_4_R1.EntityPlayer.j_(EntityPlayer.java:167)
at net.minecraft.server.v1_4_R1.World.entityJoinedWorld(World.java:1332)
at net.minecraft.server.v1_4_R1.WorldServer.entityJoinedWorld(WorldServer.java:548)
at net.minecraft.server.v1_4_R1.World.playerJoinedWorld(World.java:1313)
at net.minecraft.server.v1_4_R1.World.tickEntities(World.java:1191)
at net.minecraft.server.v1_4_R1.WorldServer.tickEntities(WorldServer.java:445)
at net.minecraft.server.v1_4_R1.MinecraftServer.r(MinecraftServer.java:580)
at net.minecraft.server.v1_4_R1.DedicatedServer.r(DedicatedServer.java:224)
at net.minecraft.server.v1_4_R1.MinecraftServer.q(MinecraftServer.java:494)
at net.minecraft.server.v1_4_R1.MinecraftServer.run(MinecraftServer.java:427)
at net.minecraft.server.v1_4_R1.ThreadServerApplication.run(SourceFile:849)
A detailed walkthrough of the error, its code path and all known details is as follows:
-- Head --
Stacktrace:
-- Entity being ticked --
Details:
Entity Type: null (net.minecraft.server.v1_4_R1.EntityPlayer)
Entity ID: 2309962
Exact location: -1985,39, 95,00, -257,41
Block location: World: (-1986,95,-258), Chunk: (at 14,5,14 in -125,-17; contains blocks -2000,0,-272 to -1985,255,-257), Region: (-4,-1; contains chunks -128,-32 to -97,-1, blocks -2048,0,-512 to -1537,255,-1)
Momentum: 0,00, -0,08, 0,00
Stacktrace:
-- Affected level --
Details:
Level name: world
All players: 7 total; [EntityPlayer['Kvitteringen'/707554, l='world', x=2028,15, y=51,50, z=672,80](Kvitteringen at 2028.1531467879126,51.5,672.8000000119209), EntityPlayer['gylve'/831578, l='world', x=-2176,51, y=67,92, z=-390,79](gylve at -2176.51088158463,67.92159999847412,-390.78815804861534), EntityPlayer['Hairymouse'/714446, l='world', x=-2205,32, y=64,00, z=-29,69](Hairymouse at -2205.3210569081366,64.0,-29.692680716853946), EntityPlayer['Hegebanan95'/1694472, l='world', x=-4322,26, y=64,00, z=-916,70](Hegebanan95 at -4322.258761160692,64.0,-916.6999999880791), EntityPlayer['Edgeis'/823045, l='world', x=-2195,50, y=62,00, z=-34,98](Edgeis at -2195.503399744853,62.0,-34.984635524766446), EntityPlayer['hiahs'/1920448, l='world', x=-1939,54, y=69,00, z=-632,70](hiahs at -1939.5379403056418,69.0,-632.6999999880791), EntityPlayer['pedvard123'/2309962, l='world', x=-1985,39, y=95,00, z=-257,41](pedvard123 at -1985.39145286027,95.0,-257.41474999829296)]
Chunk stats: ServerChunkCache: 2369 Drop: 0
Level seed: -6730615617418816148
Level generator: ID 00 - default, ver 1. Features enabled: true
Level generator options:
Level spawn location: World: (-2090,77,-253), Chunk: (at 6,4,3 in -131,-16; contains blocks -2096,0,-256 to -2081,255,-241), Region: (-5,-1; contains chunks -160,-32 to -129,-1, blocks -2560,0,-512 to -2049,255,-1)
Level time: 576135273 game time, 581654686 day time
Level dimension: 0
Level storage version: 0x04ABD - Anvil
Level weather: Rain time: 7206 (now: false), thunder time: 108151 (now: false)
Level game mode: Game mode: survival (ID 0). Hardcore: false. Cheats: false
Stacktrace:
-- System Details --
Details:
Minecraft Version: 1.4.7
Operating System: Windows Server 2008 R2 (amd64) version 6.1
Java Version: 1.7.0, Oracle Corporation
Java VM Version: Java HotSpot(TM) 64-Bit Server VM (mixed mode), Oracle Corporation
Memory: 18179472 bytes (17 MB) / 381157376 bytes (363 MB) up to 2863333376 bytes (2730 MB)
JVM Flags: 1 total; -Xmx3072M
AABB Pool Size: 31034 (1737904 bytes; 1 MB) allocated, 20532 (1149792 bytes; 1 MB) used
Suspicious classes: $Proxy3, $Proxy4, $Proxy12[com.avaje.ebean.EbeanServer], [com.avaje.ebean.config.ServerConfig], [com.avaje.ebean.config.dbplatform.DatabasePlatform, SQLitePlatform], [com.google.common.base.Predicate, Function, Joiner, ...], [com.google.common.cache.CacheLoader, SupplierToCacheLoader, FunctionToCacheLoader, ...], [com.google.common.collect.ImmutableCollection, ImmutableList, Maps, ...], [com.google.common.io.Files, InputSupplier, OutputSupplier], [com.google.common.util.concurrent.UncheckedExecutionException], [com.mysql.jdbc.NonRegisteringDriver, Driver, StringUtils], [net.minecraft.server.v1_4_R1.ICommandListener, IMojangStatistics, IDataManager, ...], [org.apache.commons.lang.Validate, UnhandledException, StringUtils, ...], [org.apache.commons.lang.exception.Nestable, NestableRuntimeException], [org.bukkit.BlockChangeDelegate, World, Server, ...], [org.bukkit.block.BlockState, BlockFace, Block, ...], [org.bukkit.command.CommandSender, RemoteConsoleCommandSender, CommandException, ...], [org.bukkit.command.defaults.VanillaCommand, SaveCommand, SaveOnCommand, ...], [org.bukkit.configuration.ConfigurationSection, Configuration, MemorySection, ...], [org.bukkit.configuration.file.FileConfiguration, YamlConfiguration, FileConfigurationOptions, ...], [org.bukkit.configuration.serialization.ConfigurationSerializable, ConfigurationSerialization, DelegateDeserialization, ...], [org.bukkit.conversations.Conversable, ConversationCanceller], [org.bukkit.craftbukkit.Main], [org.bukkit.craftbukkit.libs.com.google.gson.JsonDeserializer, JsonParseException, GsonBuilder, ...], [org.bukkit.craftbukkit.libs.com.google.gson.annotations.SerializedName], [org.bukkit.craftbukkit.libs.com.google.gson.internal.Excluder, $Gson$Preconditions, Primitives, ...], [org.bukkit.craftbukkit.libs.com.google.gson.internal.bind.JsonTreeReader, JsonTreeWriter, BigDecimalTypeAdapter, ...], [org.bukkit.craftbukkit.libs.com.google.gson.reflect.TypeToken], [org.bukkit.craftbukkit.libs.com.google.gson.stream.JsonReader, JsonWriter, MalformedJsonException, ...], [org.bukkit.craftbukkit.libs.jline.Terminal, TerminalSupport, UnsupportedTerminal, ...], [org.bukkit.craftbukkit.libs.jline.console.ConsoleReader, CursorBuffer, ConsoleKeys, ...], [org.bukkit.craftbukkit.libs.jline.console.completer.CompletionHandler, CandidateListCompletionHandler], [org.bukkit.craftbukkit.libs.jline.console.history.History, MemoryHistory], [org.bukkit.craftbukkit.libs.jline.internal.InputStreamReader, Configuration, Log], [org.bukkit.craftbukkit.libs.joptsimple.OptionException, OptionParser, OptionSpec, ...], [org.bukkit.craftbukkit.libs.joptsimple.internal.AbbreviationMap, ReflectionException, Reflection, ...], [org.bukkit.craftbukkit.libs.joptsimple.util.KeyValuePair], [org.bukkit.craftbukkit.v1_4_R1.LoggerOutputStream, CraftServer, CraftOfflinePlayer, ...], [org.bukkit.craftbukkit.v1_4_R1.block.CraftBlock, CraftBlockState, CraftSign, ...], [org.bukkit.craftbukkit.v1_4_R1.chunkio.ChunkIOExecutor, ChunkIOProvider, QueuedChunk], [org.bukkit.craftbukkit.v1_4_R1.command.ServerCommandSender, CraftConsoleCommandSender, ColouredConsoleSender], [org.bukkit.craftbukkit.v1_4_R1.conversations.ConversationTracker], [org.bukkit.craftbukkit.v1_4_R1.enchantments.CraftEnchantment], [org.bukkit.craftbukkit.v1_4_R1.entity.CraftEntity, CraftLivingEntity, CraftHumanEntity, ...], [org.bukkit.craftbukkit.v1_4_R1.event.CraftEventFactory], [org.bukkit.craftbukkit.v1_4_R1.generator.InternalChunkGenerator, CustomChunkGenerator, NormalChunkGenerator, ...], [org.bukkit.craftbukkit.v1_4_R1.help.SimpleHelpMap, CommandAliasHelpTopic, HelpYamlReader, ...], [org.bukkit.craftbukkit.v1_4_R1.inventory.CraftItemStack, CraftRecipe, CraftShapedRecipe, ...], [org.bukkit.craftbukkit.v1_4_R1.map.CraftMapView], [org.bukkit.craftbukkit.v1_4_R1.metadata.EntityMetadataStore, PlayerMetadataStore, WorldMetadataStore, ...], [org.bukkit.craftbukkit.v1_4_R1.potion.CraftPotionEffectType, CraftPotionBrewer], [org.bukkit.craftbukkit.v1_4_R1.scheduler.CraftScheduler, CraftTask, CraftAsyncTask, ...], [org.bukkit.craftbukkit.v1_4_R1.updater.AutoUpdater, BukkitDLUpdaterService, DateDeserializer, ...], [org.bukkit.craftbukkit.v1_4_R1.util.Waitable, ServerShutdownThread, TerminalConsoleHandler, ...], [org.bukkit.enchantments.Enchantment, EnchantmentWrapper], [org.bukkit.entity.Entity, Damageable, LivingEntity, ...], [org.bukkit.event.Event, Cancellable, Listener, ...], [org.bukkit.event.block.BlockEvent, BlockFadeEvent, BlockGrowEvent, ...], [org.bukkit.event.enchantment.EnchantItemEvent, PrepareItemEnchantEvent], [org.bukkit.event.entity.EntityEvent, EntityInteractEvent, EntityDamageEvent, ...], [org.bukkit.event.hanging.HangingEvent, HangingPlaceEvent, HangingBreakEvent, ...], [org.bukkit.event.inventory.InventoryType, FurnaceSmeltEvent, FurnaceBurnEvent, ...], [org.bukkit.event.painting.PaintingEvent, PaintingPlaceEvent, PaintingBreakEvent, ...], [org.bukkit.event.player.PlayerEvent, PlayerInteractEvent, PlayerFishEvent, ...], [org.bukkit.event.server.ServerEvent, MapInitializeEvent, ServerCommandEvent, ...], [org.bukkit.event.vehicle.VehicleEvent, VehicleCollisionEvent, VehicleBlockCollisionEvent, ...], [org.bukkit.event.weather.WeatherEvent, WeatherChangeEvent, ThunderChangeEvent, ...], [org.bukkit.event.world.WorldEvent, WorldInitEvent, WorldSaveEvent, ...], [org.bukkit.generator.ChunkGenerator], [org.bukkit.help.HelpMap, HelpTopic, IndexHelpTopic, ...], [org.bukkit.inventory.ItemStack, Recipe, ShapedRecipe, ...], [org.bukkit.inventory.meta.ItemMeta, Repairable, BookMeta, ...], [org.bukkit.map.MapView], [org.bukkit.material.MaterialData, Tree, Directional, ...], [org.bukkit.metadata.Metadatable, MetadataStore, MetadataStoreBase, ...], [org.bukkit.permissions.ServerOperator, Permissible, PermissionDefault, ...], [org.bukkit.plugin.ServicesManager, PluginManager, SimpleServicesManager, ...], [org.bukkit.plugin.java.JavaPluginLoader, PluginClassLoader, JavaPlugin], [org.bukkit.plugin.messaging.PluginMessageRecipient, Messenger, StandardMessenger, ...], [org.bukkit.potion.PotionEffectType, PotionEffectTypeWrapper, PotionBrewer, ...], [org.bukkit.scheduler.BukkitScheduler, BukkitTask, BukkitWorker], [org.bukkit.util.Vector, BlockVector, Java15Compat, ...], [org.bukkit.util.permissions.DefaultPermissions, CommandPermissions, BroadcastPermissions], [org.fusesource.jansi.Ansi, NoAnsi, Color, ...], [org.sqlite.JDBC, Conn, SQLiteConfig, ...], [org.yaml.snakeyaml.DumperOptions, ScalarStyle, FlowStyle, ...], [org.yaml.snakeyaml.composer.Composer, ComposerException], [org.yaml.snakeyaml.constructor.BaseConstructor, SafeConstructor, Constructor, ...], [org.yaml.snakeyaml.emitter.Emitable, Emitter, EmitterException, ...], [org.yaml.snakeyaml.error.YAMLException, MarkedYAMLException, Mark], [org.yaml.snakeyaml.events.Event, NodeEvent, ScalarEvent, ...], [org.yaml.snakeyaml.external.com.google.gdata.util.common.base.Escaper, UnicodeEscaper, PercentEscaper], [org.yaml.snakeyaml.introspector.PropertyUtils, BeanAccess, Property, ...], [org.yaml.snakeyaml.nodes.Node, CollectionNode, MappingNode, ...], [org.yaml.snakeyaml.parser.Parser, ParserImpl, ParserException, ...], [org.yaml.snakeyaml.reader.UnicodeReader, StreamReader, ReaderException], [org.yaml.snakeyaml.representer.BaseRepresenter, SafeRepresenter, Representer, ...], [org.yaml.snakeyaml.resolver.Resolver, ResolverTuple], [org.yaml.snakeyaml.scanner.Scanner, ScannerImpl, ScannerException, ...], [org.yaml.snakeyaml.serializer.Serializer, SerializerException], [org.yaml.snakeyaml.tokens.Token, AliasToken, ScalarToken, ...], [org.yaml.snakeyaml.util.UriEncoder, ArrayStack]
IntCache: cache: 0, tcache: 0, allocated: 1, tallocated: 63
CraftBukkit Information:
  Running: CraftBukkit version git-Bukkit-1.4.7-R1.0-b2624jnks (MC: 1.4.7) (Implementing API version 1.4.7-R1.0) true
  Plugins: { SimpleBackup v1.4 com.exolius.simplebackup.SimpleBackup [], SkyChest v1.0 me.primescore.skychest.skychest [], WorldEdit v5.5.1 com.sk89q.worldedit.bukkit.WorldEditPlugin [], BukkitCompat vr22a com.mcmyadmin.bukkitcompat.BukkitCompat [PhonicUK], PrivateChat v1.2 tk.funnytopia.funny.PrivateChat [i_am_not_funny], CoreProtect v1.75 net.coreprotect.CoreProtect [intelli], Lockette v1.7.9 org.yi.acru.bukkit.Lockette.Lockette [Acru], Stargate v0.7.9.2 net.TheDgtl.Stargate.Stargate [Drakia], Modifyworld v1.19.4 ru.tehkode.modifyworld.bukkit.Modifyworld [t3hk0d3], PermissionsEx v1.19.5 ru.tehkode.permissions.bukkit.PermissionsEx [t3hk0d3], WorldGuard v748-e3dfc6a com.sk89q.worldguard.bukkit.WorldGuardPlugin [], Jail v2.3.0 com.matejdro.bukkit.jail.Jail [matejdro], dynmap v1.3-1468 org.dynmap.bukkit.DynmapPlugin [FrozenCow, mikeprimm], Essentials v2.9.6 com.earth2me.essentials.Essentials [Zenexer, ementalo, Aelux, Brettflan, KimKandor, snowleo, ceulemans, Xeology, KHobbits, md_5, Iaccidentally], WorldBorder v1.6.1 com.wimbli.WorldBorder.WorldBorder [brettflan], ChatManager v1.19.1 ru.tehkode.chatmanager.bukkit.ChatManager [t3hk0d3], EssentialsSpawn v2.9.6 com.earth2me.essentials.spawn.EssentialsSpawn [Zenexer, ementalo, Aelux, Brettflan, KimKandor, snowleo, ceulemans, Xeology, KHobbits], Stargate-DHD v0.3.4 net.TheDgtl.StargateDHD.StargateDHD [Drakia],}
  Warnings: DEFAULT
  Threads: { RUNNABLE pool-3-thread-2 Acceptor0 [email protected]:25566: [sun.nio.ch.ServerSocketChannelImpl.accept0(Native Method), sun.nio.ch.ServerSocketChannelImpl.accept(Unknown Source), org.eclipse.jetty.server.nio.SelectChannelConnector.accept(SelectChannelConnector.java:109), org.eclipse.jetty.server.AbstractConnector$Acceptor.run(AbstractConnector.java:938), java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source), java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source), java.lang.Thread.run(Unknown Source)], WAITING Java2D Disposer: [java.lang.Object.wait(Native Method), java.lang.ref.ReferenceQueue.remove(Unknown Source), java.lang.ref.ReferenceQueue.remove(Unknown Source), sun.java2d.Disposer.run(Unknown Source), java.lang.Thread.run(Unknown Source)], TIMED_WAITING Keep-Alive-Timer: [java.lang.Thread.sleep(Native Method), sun.net.www.http.KeepAliveCache.run(Unknown Source), java.lang.Thread.run(Unknown Source)], TIMED_WAITING TimerQueue: [sun.misc.Unsafe.park(Native Method), java.util.concurrent.locks.LockSupport.parkNanos(Unknown Source), java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(Unknown Source), java.util.concurrent.DelayQueue.take(Unknown Source), javax.swing.TimerQueue.run(Unknown Source), java.lang.Thread.run(Unknown Source)], RUNNABLE Signal Dispatcher: [], TIMED_WAITING Connection #273 write thread: [java.lang.Thread.sleep(Native Method), net.minecraft.server.v1_4_R1.NetworkWriterThread.run(NetworkWriterThread.java:38)], TIMED_WAITING Dynmap Render Thread: [sun.misc.Unsafe.park(Native Method), java.util.concurrent.locks.LockSupport.parkNanos(Unknown Source), java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(Unknown Source), java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWorkQueue.take(Unknown Source), java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWorkQueue.take(Unknown Source), java.util.concurrent.ThreadPoolExecutor.getTask(Unknown Source), java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source), java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source), java.lang.Thread.run(Unknown Source)], TIMED_WAITING pool-1-thread-65: [sun.misc.Unsafe.park(Native Method), java.util.concurrent.locks.LockSupport.parkNanos(Unknown Source), java.util.concurrent.SynchronousQueue$TransferStack.awaitFulfill(Unknown Source), java.util.concurrent.SynchronousQueue$TransferStack.transfer(Unknown Source), java.util.concurrent.SynchronousQueue.poll(Unknown Source), java.util.concurrent.ThreadPoolExecutor.getTask(Unknown Source), java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source), java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source), java.lang.Thread.run(Unknown Source)], TIMED_WAITING HashSessionScavenger-0: [java.lang.Object.wait(Native Method), java.util.TimerThread.mainLoop(Unknown Source), java.util.TimerThread.run(Unknown Source)], RUNNABLE AWT-Windows: [sun.awt.windows.WToolkit.eventLoop(Native Method), sun.awt.windows.WToolkit.run(Unknown Source), java.lang.Thread.run(Unknown Source)], WAITING Finalizer: [java.lang.Object.wait(Native Method), java.lang.ref.ReferenceQueue.remove(Unknown Source), java.lang.ref.ReferenceQueue.remove(Unknown Source), java.lang.ref.Finalizer$FinalizerThread.run(Unknown Source)], RUNNABLE Connection #253 read thread: [java.net.SocketInputStream.socketRead0(Native Method), java.net.SocketInputStream.read(Unknown Source), java.net.SocketInputStream.read(Unknown Source), java.io.FilterInputStream.read(Unknown Source), net.minecraft.v1_4_R1.org.bouncycastle.crypto.io.CipherInputStream.a(Unknown Source), net.minecraft.v1_4_R1.org.bouncycastle.crypto.io.CipherInputStream.read(Unknown Source), java.io.FilterInputStream.read(Unknown Source), net.minecraft.server.v1_4_R1.Packet.a(Packet.java:93), net.minecraft.server.v1_4_R1.NetworkManager.i(NetworkManager.java:190), net.minecraft.server.v1_4_R1.NetworkManager.c(NetworkManager.java:344), net.minecraft.server.v1_4_R1.NetworkReaderThread.run(SourceFile:93)], WAITING AWT-EventQueue-0: [sun.misc.Unsafe.park(Native Method), java.util.concurrent.locks.LockSupport.park(Unknown Source), java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.await(Unknown Source), java.awt.EventQueue.getNextEvent(Unknown Source), java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source), java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source), java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source), java.awt.EventDispatchThread.pumpEvents(Unknown Source), java.awt.EventDispatchThread.pumpEvents(Unknown Source), java.awt.EventDispatchThread.run(Unknown Source)], RUNNABLE Dynmap Render Thread: [java.net.DualStackPlainSocketImpl.connect0(Native Method), java.net.DualStackPlainSocketImpl.socketConnect(Unknown Source), java.net.AbstractPlainSocketImpl.doConnect(Unknown Source), java.net.AbstractPlainSocketImpl.connectToAddress(Unknown Source), java.net.AbstractPlainSocketImpl.connect(Unknown Source), java.net.PlainSocketImpl.connect(Unknown Source), java.net.SocksSocketImpl.connect(Unknown Source), java.net.Socket.connect(Unknown Source), java.net.Socket.connect(Unknown Source), sun.net.NetworkClient.doConnect(Unknown Source), sun.net.www.http.HttpClient.openServer(Unknown Source), sun.net.www.http.HttpClient.openServer(Unknown Source), sun.net.www.http.HttpClient.<init>(Unknown Source), sun.net.www.http.HttpClient.New(Unknown Source), sun.net.www.http.HttpClient.New(Unknown Source), sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(Unknown Source), sun.net.www.protocol.http.HttpURLConnection.plainConnect(Unknown Source), sun.net.www.protocol.http.HttpURLConnection.connect(Unknown Source), sun.net.www.protocol.http.HttpURLConnection.getInputStream(Unknown Source), java.net.URL.openStream(Unknown Source), javax.imageio.ImageIO.read(Unknown Source), org.dynmap.PlayerFaces$LoadPlayerImages.run(PlayerFaces.java:52), org.dynmap.MapManager$DynmapScheduledThreadPoolExecutor$1.run(MapManager.java:180), org.dynmap.MapManager$DynmapScheduledThreadPoolExecutor$2.run(MapManager.java:196), java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source), java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source), java.util.concurrent.FutureTask.run(Unknown Source), java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(Unknown Source), java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source), java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source), java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source), java.lang.Thread.run(Unknown Source)], WAITING Thread-13: [sun.misc.Unsafe.park(Native Method), java.util.concurrent.locks.LockSupport.park(Unknown Source), java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.await(Unknown Source), java.util.concurrent.LinkedBlockingQueue.take(Unknown Source), org.dynmap.AsynchronousQueue.pop(AsynchronousQueue.java:44), org.dynmap.AsynchronousQueue.running(AsynchronousQueue.java:128), org.dynmap.AsynchronousQueue.access$000(AsynchronousQueue.java:9), org.dynmap.AsynchronousQueue$1.run(AsynchronousQueue.java:83), java.lang.Thread.run(Unknown Source)], WAITING Thread-12: [sun.misc.Unsafe.park(Native Method), java.util.concurrent.locks.LockSupport.park(Unknown Source), java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.await(Unknown Source), java.util.concurrent.LinkedBlockingQueue.take(Unknown Source), org.dynmap.AsynchronousQueue.pop(AsynchronousQueue.java:44), org.dynmap.AsynchronousQueue.running(AsynchronousQueue.java:128), org.dynmap.AsynchronousQueue.access$000(AsynchronousQueue.java:9), org.dynmap.AsynchronousQueue$1.run(AsynchronousQueue.java:83), java.lang.Thread.run(Unknown Source)], RUNNABLE Connection #264 read thread: [java.net.SocketInputStream.socketRead0(Native Method), java.net.SocketInputStream.read(Unknown Source), java.net.SocketInputStream.read(Unknown Source), java.io.FilterInputStream.read(Unknown Source), net.minecraft.v1_4_R1.org.bouncycastle.crypto.io.CipherInputStream.a(Unknown Source), net.minecraft.v1_4_R1.org.bouncycastle.crypto.io.CipherInputStream.read(Unknown Source), java.io.FilterInputStream.read(Unknown Source), net.minecraft.server.v1_4_R1.Packet.a(Packet.java:93), net.minecraft.server.v1_4_R1.NetworkManager.i(NetworkManager.java:190), net.minecraft.server.v1_4_R1.NetworkManager.c(NetworkManager.java:344), net.minecraft.server.v1_4_R1.NetworkReaderThread.run(SourceFile:93)], RUNNABLE Connection #4 read thread: [java.net.SocketInputStream.socketRead0(Native Method), java.net.SocketInputStream.read(Unknown Source), java.net.SocketInputStream.read(Unknown Source), java.io.FilterInputStream.read(Unknown Source), net.minecraft.v1_4_R1.org.bouncycastle.crypto.io.CipherInputStream.a(Unknown Source), net.minecraft.v1_4_R1.org.bouncycastle.crypto.io.CipherInputStream.read(Unknown Source), java.io.FilterInputStream.read(Unknown Source), net.minecraft.server.v1_4_R1.Packet.a(Packet.java:93), net.minecraft.server.v1_4_R1.NetworkManager.i(NetworkManager.java:190), net.minecraft.server.v1_4_R1.NetworkManager.c(NetworkManager.java:344), net.minecraft.server.v1_4_R1.NetworkReaderThread.run(SourceFile:93)], TIMED_WAITING Thread-10: [java.lang.Thread.sleep(Native Method), net.coreprotect.Consumer.run(Consumer.java:41), java.lang.Thread.run(Unknown Source)], TIMED_WAITING Connection #200 write thread: [java.lang.Thread.sleep(Native Method), net.minecraft.server.v1_4_R1.NetworkWriterThread.run(NetworkWriterThread.java:38)], RUNNABLE pool-3-thread-1 Selector0: [sun.nio.ch.WindowsSelectorImpl$SubSelector.poll0(Native Method), sun.nio.ch.WindowsSelectorImpl$SubSelector.poll(Unknown Source), sun.nio.ch.WindowsSelectorImpl$SubSelector.access$400(Unknown Source), sun.nio.ch.WindowsSelectorImpl.doSelect(Unknown Source), sun.nio.ch.SelectorImpl.lockAndDoSelect(Unknown Source), sun.nio.ch.SelectorImpl.select(Unknown Source), org.eclipse.jetty.io.nio.SelectorManager$SelectSet.doSelect(SelectorManager.java:569), org.eclipse.jetty.io.nio.SelectorManager$1.run(SelectorManager.java:290), java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source), java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source), java.lang.Thread.run(Unknown Source)], RUNNABLE Thread-19: [java.net.DualStackPlainDatagramSocketImpl.socketReceiveOrPeekData(Native Method), java.net.DualStackPlainDatagramSocketImpl.receive0(Unknown Source), java.net.AbstractPlainDatagramSocketImpl.receive(Unknown Source), java.net.DatagramSocket.receive(Unknown Source), net.minecraft.server.v1_4_R1.RemoteStatusListener.run(SourceFile:260), java.lang.Thread.run(Unknown Source)], TIMED_WAITING pool-3-thread-4: [sun.misc.Unsafe.park(Native Method), java.util.concurrent.locks.LockSupport.parkNanos(Unknown Source), java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(Unknown Source), java.util.concurrent.LinkedBlockingQueue.poll(Unknown Source), java.util.concurrent.ThreadPoolExecutor.getTask(Unknown Source), java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source), java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source), java.lang.Thread.run(Unknown Source)], WAITING Dynmap Render Thread: [sun.misc.Unsafe.park(Native Method), java.util.concurrent.locks.LockSupport.park(Unknown Source), java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.await(Unknown Source), java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWorkQueue.take(Unknown Source), java.util.concurrent.ScheduledThreadPoolExecutor$DelayedWorkQueue.take(Unknown Source), java.util.concurrent.ThreadPoolExecutor.getTask(Unknown Source), java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source), java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source), java.lang.Thread.run(Unknown Source)], TIMED_WAITING Connection #212 write thread: [java.lang.Thread.sleep(Native Method), net.minecraft.server.v1_4_R1.NetworkWriterThread.run(NetworkWriterThread.java:38)], RUNNABLE Connection #273 read thread: [java.net.SocketInputStream.socketRead0(Native Method), java.net.SocketInputStream.read(Unknown Source), java.net.SocketInputStream.read(Unknown Source), java.io.FilterInputStream.read(Unknown Source), net.minecraft.v1_4_R1.org.bouncycastle.crypto.io.CipherInputStream.a(Unknown Source), net.minecraft.v1_4_R1.org.bouncycastle.crypto.io.CipherInputStream.read(Unknown Source), java.io.FilterInputStream.read(Unknown Source), net.minecraft.server.v1_4_R1.Packet.a(Packet.java:93), net.minecraft.server.v1_4_R1.NetworkManager.i(NetworkManager.java:190), net.minecraft.server.v1_4_R1.NetworkManager.c(NetworkManager.java:344), net.minecraft.server.v1_4_R1.NetworkReaderThread.run(SourceFile:93)], TIMED_WAITING Snooper Timer: [java.lang.Object.wait(Native Method), java.util.TimerThread.mainLoop(Unknown Source), java.util.TimerThread.run(Unknown Source)], RUNNABLE Server thread: [java.lang.Thread.dumpThreads(Native Method), java.lang.Thread.getAllStackTraces(Unknown Source), org.bukkit.craftbukkit.v1_4_R1.CraftCrashReport.call(CraftCrashReport.java:28), net.minecraft.server.v1_4_R1.CrashReportSystemDetails.a(SourceFile:74), net.minecraft.server.v1_4_R1.CrashReport.h(CrashReport.java:43), net.minecraft.server.v1_4_R1.CrashReport.<init>(CrashReport.java:30), net.minecraft.server.v1_4_R1.CrashReport.a(CrashReport.java:214), net.minecraft.server.v1_4_R1.World.tickEntities(World.java:1193), net.minecraft.server.v1_4_R1.WorldServer.tickEntities(WorldServer.java:445), net.minecraft.server.v1_4_R1.MinecraftServer.r(MinecraftServer.java:580), net.minecraft.server.v1_4_R1.DedicatedServer.r(DedicatedServer.java:224), net.minecraft.server.v1_4_R1.MinecraftServer.q(MinecraftServer.java:494), net.minecraft.server.v1_4_R1.MinecraftServer.run(MinecraftServer.java:427), net.minecraft.server.v1_4_R1.ThreadServerApplication.run(SourceFile:849)], TIMED_WAITING pool-3-thread-3: [sun.misc.Unsafe.park(Native Method), java.util.concurrent.locks.LockSupport.parkNanos(Unknown Source), java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.awaitNanos(Unknown Source), java.util.concurrent.LinkedBlockingQueue.poll(Unknown Source), java.util.concurrent.ThreadPoolExecutor.getTask(Unknown Source), java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source), java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source), java.lang.Thread.run(Unknown Source)], TIMED_WAITING Thread-9: [java.lang.Thread.sleep(Native Method), net.coreprotect.CoreProtect$1BasicThread2.run(CoreProtect.java:219), java.lang.Thread.run(Unknown Source)], RUNNABLE Attach Listener: [], TIMED_WAITING Connection #253 write thread: [java.lang.Thread.sleep(Native Method), net.minecraft.server.v1_4_R1.NetworkWriterThread.run(NetworkWriterThread.java:38)], RUNNABLE Thread-5: [java.io.FileInputStream.readBytes(Native Method), java.io.FileInputStream.read(Unknown Source), java.io.BufferedInputStream.fill(Unknown Source), java.io.BufferedInputStream.read(Unknown Source), java.io.FilterInputStream.read(Unknown Source), org.bukkit.craftbukkit.libs.jline.console.ConsoleReader$1.read(ConsoleReader.java:167), org.bukkit.craftbukkit.libs.jline.internal.InputStreamReader.read(InputStreamReader.java:267), org.bukkit.craftbukkit.libs.jline.internal.InputStreamReader.read(InputStreamReader.java:204), org.bukkit.craftbukkit.libs.jline.console.ConsoleReader.readCharacter(ConsoleReader.java:995), org.bukkit.craftbukkit.libs.jline.console.ConsoleReader.readLineSimple(ConsoleReader.java:1506), org.bukkit.craftbukkit.libs.jline.console.ConsoleReader.readLine(ConsoleReader.java:1153), org.bukkit.craftbukkit.libs.jline.console.ConsoleReader.readLine(ConsoleReader.java:1117), org.bukkit.craftbukkit.libs.jline.console.ConsoleReader.readLine(ConsoleReader.java:1105), net.minecraft.server.v1_4_R1.ThreadCommandReader.run(ThreadCommandReader.java:33)], RUNNABLE Connection #200 read thread: [java.net.SocketInputStream.socketRead0(Native Method), java.net.SocketInputStream.read(Unknown Source), java.net.SocketInputStream.read(Unknown Source), java.io.FilterInputStream.read(Unknown Source), net.minecraft.v1_4_R1.org.bouncycastle.crypto.io.CipherInputStream.a(Unknown Source), net.minecraft.v1_4_R1.org.bouncycastle.crypto.io.CipherInputStream.read(Unknown Source), java.io.FilterInputStream.read(Unknown Source), net.minecraft.server.v1_4_R1.Packet.a(Packet.java:93), net.minecraft.server.v1_4_R1.NetworkManager.i(NetworkManager.java:190), net.minecraft.server.v1_4_R1.NetworkManager.c(NetworkManager.java:344), net.minecraft.server.v1_4_R1.NetworkReaderThread.run(SourceFile:93)], RUNNABLE Connection #216 read thread: [java.net.SocketInputStream.socketRead0(Native Method), java.net.SocketInputStream.read(Unknown Source), java.net.SocketInputStream.read(Unknown Source), java.io.FilterInputStream.read(Unknown Source), net.minecraft.v1_4_R1.org.bouncycastle.crypto.io.CipherInputStream.a(Unknown Source), net.minecraft.v1_4_R1.org.bouncycastle.crypto.io.CipherInputStream.read(Unknown Source), java.io.FilterInputStream.read(Unknown Source), net.minecraft.server.v1_4_R1.Packet.a(Packet.java:93), net.minecraft.server.v1_4_R1.NetworkManager.i(NetworkManager.java:190), net.minecraft.server.v1_4_R1.NetworkManager.c(NetworkManager.java:344), net.minecraft.server.v1_4_R1.NetworkReaderThread.run(SourceFile:93)], TIMED_WAITING Connection #196 write thread: [java.lang.Thread.sleep(Native Method), net.minecraft.server.v1_4_R1.NetworkWriterThread.run(NetworkWriterThread.java:38)], RUNNABLE Listen thread: [java.net.DualStackPlainSocketImpl.accept0(Native Method), java.net.DualStackPlainSocketImpl.socketAccept(Unknown Source), java.net.AbstractPlainSocketImpl.accept(Unknown Source), java.net.PlainSocketImpl.accept(Unknown Source), java.net.ServerSocket.implAccept(Unknown Source), java.net.ServerSocket.accept(Unknown Source), net.minecraft.server.v1_4_R1.DedicatedServerConnectionThread.run(DedicatedServerConnectionThread.java:62)], TIMED_WAITING Connection #264 write thread: [java.lang.Thread.sleep(Native Method), net.minecraft.server.v1_4_R1.NetworkWriterThread.run(NetworkWriterThread.java:38)], TIMED_WAITING Connection #4 write thread: [java.lang.Thread.sleep(Native Method), net.minecraft.server.v1_4_R1.NetworkWriterThread.run(NetworkWriterThread.java:38)], WAITING PermissionsEx-Cleaner: [java.lang.Object.wait(Native Method), java.lang.Object.wait(Object.java:503), java.util.TimerThread.mainLoop(Unknown Source), java.util.TimerThread.run(Unknown Source)], TIMED_WAITING Thread-24401: [java.lang.Thread.sleep(Native Method), net.minecraft.server.v1_4_R1.NetworkMasterThread.run(SourceFile:297)], TIMED_WAITING File IO Thread: [java.lang.Thread.sleep(Native Method), net.minecraft.server.v1_4_R1.FileIOThread.b(SourceFile:43), net.minecraft.server.v1_4_R1.FileIOThread.run(SourceFile:22), java.lang.Thread.run(Unknown Source)], WAITING Chunk I/O Executor Thread-1: [sun.misc.Unsafe.park(Native Method), java.util.concurrent.locks.LockSupport.park(Unknown Source), java.util.concurrent.locks.AbstractQueuedSynchronizer$ConditionObject.await(Unknown Source), java.util.concurrent.LinkedBlockingQueue.take(Unknown Source), java.util.concurrent.ThreadPoolExecutor.getTask(Unknown Source), java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source), java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source), java.lang.Thread.run(Unknown Source)], WAITING Reference Handler: [java.lang.Object.wait(Native Method), java.lang.Object.wait(Object.java:503), java.lang.ref.Reference$ReferenceHandler.run(Unknown Source)], TIMED_WAITING Connection #216 write thread: [java.lang.Thread.sleep(Native Method), net.minecraft.server.v1_4_R1.NetworkWriterThread.run(NetworkWriterThread.java:38)], RUNNABLE Connection #212 read thread: [java.net.SocketInputStream.socketRead0(Native Method), java.net.SocketInputStream.read(Unknown Source), java.net.SocketInputStream.read(Unknown Source), java.io.FilterInputStream.read(Unknown Source), net.minecraft.v1_4_R1.org.bouncycastle.crypto.io.CipherInputStream.a(Unknown Source), net.minecraft.v1_4_R1.org.bouncycastle.crypto.io.CipherInputStream.read(Unknown Source), java.io.FilterInputStream.read(Unknown Source), net.minecraft.server.v1_4_R1.Packet.a(Packet.java:93), net.minecraft.server.v1_4_R1.NetworkManager.i(NetworkManager.java:190), net.minecraft.server.v1_4_R1.NetworkManager.c(NetworkManager.java:344), net.minecraft.server.v1_4_R1.NetworkReaderThread.run(SourceFile:93)], RUNNABLE DestroyJavaVM: [], TIMED_WAITING AWT-Shutdown: [java.lang.Object.wait(Native Method), sun.awt.AWTAutoShutdown.run(Unknown Source), java.lang.Thread.run(Unknown Source)], TIMED_WAITING Thread-4: [java.lang.Thread.sleep(Native Method), net.minecraft.server.v1_4_R1.ThreadSleepForever.run(SourceFile:52)], TIMED_WAITING pool-1-thread-63: [sun.misc.Unsafe.park(Native Method), java.util.concurrent.locks.LockSupport.parkNanos(Unknown Source), java.util.concurrent.SynchronousQueue$TransferStack.awaitFulfill(Unknown Source), java.util.concurrent.SynchronousQueue$TransferStack.transfer(Unknown Source), java.util.concurrent.SynchronousQueue.poll(Unknown Source), java.util.concurrent.ThreadPoolExecutor.getTask(Unknown Source), java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source), java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source), java.lang.Thread.run(Unknown Source)], RUNNABLE Connection #196 read thread: [java.net.SocketInputStream.socketRead0(Native Method), java.net.SocketInputStream.read(Unknown Source), java.net.SocketInputStream.read(Unknown Source), java.io.FilterInputStream.read(Unknown Source), net.minecraft.v1_4_R1.org.bouncycastle.crypto.io.CipherInputStream.a(Unknown Source), net.minecraft.v1_4_R1.org.bouncycastle.crypto.io.CipherInputStream.read(Unknown Source), java.io.FilterInputStream.read(Unknown Source), net.minecraft.server.v1_4_R1.Packet.a(Packet.java:93), net.minecraft.server.v1_4_R1.NetworkManager.i(NetworkManager.java:190), net.minecraft.server.v1_4_R1.NetworkManager.c(NetworkManager.java:344), net.minecraft.server.v1_4_R1.NetworkReaderThread.run(SourceFile:93)],}
  Recent tasks from 816267-816297{Essentials:com.earth2me.essentials.spawn.EssentialsSpawnPlayerListener$1@816327,Essentials:com.earth2me.essentials.EssentialsPlayerListener$1@816327,}
Profiler Position: N/A (disabled)
Vec3 Pool Size: ~~ERROR~~ NoSuchFieldError: worldServer
Player Count: 8 / 80; [EntityPlayer['Kvitteringen'/707554, l='world', x=2028,15, y=51,50, z=672,80](Kvitteringen at 2028.1531467879126,51.5,672.8000000119209), EntityPlayer['gylve'/831578, l='world', x=-2176,51, y=67,92, z=-390,79](gylve at -2176.51088158463,67.92159999847412,-390.78815804861534), EntityPlayer['Hairymouse'/714446, l='world', x=-2205,32, y=64,00, z=-29,69](Hairymouse at -2205.3210569081366,64.0,-29.692680716853946), EntityPlayer['Hegebanan95'/1694472, l='world', x=-4322,26, y=64,00, z=-916,70](Hegebanan95 at -4322.258761160692,64.0,-916.6999999880791), EntityPlayer['Edgeis'/823045, l='world', x=-2195,50, y=62,00, z=-34,98](Edgeis at -2195.503399744853,62.0,-34.984635524766446), EntityPlayer['hiahs'/1920448, l='world', x=-1939,54, y=69,00, z=-632,70](hiahs at -1939.5379403056418,69.0,-632.6999999880791), EntityPlayer['MrZz'/1166, l='world_the_end', x=-304,25, y=6,00, z=5,68](MrZz at -304.2526010636241,6.0,5.6795906379741155), EntityPlayer['pedvard123'/2309962, l='world', x=-1985,39, y=95,00, z=-257,41](pedvard123 at -1985.39145286027,95.0,-257.41474999829296)]
Is Modded: Definitely; Server brand changed to 'craftbukkit'
Type: Dedicated Server (map_server.txt)
Endret av Lakus
Okei, som Netrum foreslo og hosten vår bekreftet så er verdenen korrupt. Når en eller flere går inn i en del av mappet stopper serveren på sekundet. For å fikse dette er jeg nødt til å laste ned kartet og fikse det offline. Derfor har jeg store planer om å få lastet opp det nye kartet i natt eller i morgen slik at jeg om noen dager kan midlertidig ta bort kartet vi har nå. Når verdenen er reparert laster jeg det opp igjen.
Det er bare så spille som vanlig, men i løpet av helgen (forhåpentligvis) vil det nye kartet dukke opp og da er det bra om folk migrerer med seg litt materialer og verktøy over dit sånn at dere har stæsj frem til den nåværende verdenen er tilbake. Når den nåværende verdenen er fikset laster jeg den opp igjen og vi vil fremover ha to kart. For funs.
Om noen har spørsmål så spør i vei :p
Ja, gjøør det nå!
Venta hele uken på dette, få det gjort nå så kan vi flytte alt over på 30 min eller noe, så reparerer du denne verdenen.
Vi kan da ikke tillate at den krasjer, derfor er det bra å bytte verden nå, dra deg inngame lakus! :)
Forresten, hvordan var prosjektoren?
Endret av LithitiumS
