Lakusland v3 - 1.14.4 endelig
Bleh..jeg oppdaterte MC og kommer ikke inn nå :p Hvor lang tid trur dere det tar før dere oppdaterer serveren ?
Hey folkens!
Nå har endelig Minecraft versjon 1.4.2 kommet, og om dere vil fortsette å spille på Lakusland nå, kan dere ikke oppdatere til 1.4.2 (Lakusland kjører på 1.3.2). Dere kan, men med mods eller bare bruke forskjellige Minacraft.jars :)
1.4.2 vil mest sannsynlig komme på Lakusland så kjapt Bukkit kommer med en stabil 1.4.2 release og Lakus har tid. Bukkit er det lakusland kjører på.
- Z :)
Edit: Fant denne. Prøv på eget ansvar :p
With the Minecraft 1.4 release date fast approaching, a lot of people are wondering when we will be releasing a CraftBukkit Recommended Build for Minecraft 1.4. We hope this short announcement will answer those questions.
Due to the rapid release of preview builds for the impending 1.4 update, we are unable to guarantee that we'll have a compatible CraftBukkit Recommended Build out in time for the release of Minecraft 1.4.2. Although we started working on the update immediately after the Minecraft 1.4 preview was made available to the public, each new preview build leads to delays in our update process as we, essentially, need to start over with each one.
In the past releasing a Recommended Build has caused apparent confusion within the community, as a result for this release, and moving forward, we will follow the "Dev -> Beta -> Recommended Build" release methodology. We are going to release a Beta build as soon as we can get a stable build devoid of any significant bugs.
As we have done a significant amount of important work on CraftBukkit 1.3.2 builds, we have promoted a new Recommended Build recently. This was done so that people have a reliable, stable build to use until we can get a 1.4 compatible build out and so that everyone who relies on Recommended Builds are able to take advantage of all the fixes, improvements and so on we've done since the last 1.3.2 RB.
Thank you for your patience, understanding and continued support; we greatly appreciate it!
Okei, da. Se introen til denne dokumentaren her, ser for meg mengder av fin sandstone :) eller kanskje stone brick? grønt og frodig?
Har også laget noen sketcher. Tegneferdighetene kunne vært bedre, men jeg tror dere forstår :)
"Fakta":
Diameter: 200 Hvorav: 26 Lava, 52 vann og 122 land
Max høyde fra bedrock til tak: 60 (havoverflaten er 62) Regner med at taket ved veggene blir noe lavere enn i midten der et tempel er plassert.
For moro skyld, ca volum: 1,25 mill blocks..
Ovenfra tegning:
Snitt tegning av radius:
Deretter håper jeg at det kan fylles med bygninger av alle slag :)
Etter mye tenking og litt tid i singleplayer har eg kommert fram til en ny plan.
Trappehusene i noria blir fjernet.
Alle de gamle gangene skal gjøres om. Legger til masse detaljer til en utrolig kjedelig gang.
Har også laget et gulv mønster eg skal bruke et par plasser i hovedrommet.
Mangler ideer for hvordan de nye trappene skal bli.
