Xbox One-kaféen
Vel, hvis den blir bedre av å vente så er jo det en positiv ting. PS4 sin får jo kritikk for å streame så lav kvalitet, altså under 720p uavhengig av hvor bra linje du har.
Tror de snakket om 360p eller noe sånt jeg de som er vant med å streame. Så de fortsetter å streame via PC for det er mye bedre bildekvalitet.
Bruksanvisningen fra Xbox One-versjonen til BF4 ligger på nett, med ny info om Kinect-funksjonene, bla. a:
"If you are a Squad Leader, and there is a Commander, you can say “Request Order” when your squad is ready for duty. Let your Commander know what you need by saying “Request Scan”, “Request Vehicle”, or “Request Supply”. When you are in the Deploy screen you can deploy by saying “Spawn”. During gameplay you can plan what classyou should deploy as, next time you deploy, by saying “Next time spawn as Medic” or whatever class you choose.The next time you deploy you will be deployed according to your wishes.The full list of Voice Commands can be found under “OPTIONS > KINECT”
LEANING
Using the Kinect, you can lean to look out from behind cover. Use this as a tactic to keep yourself partially behindcover while at the same time being able to shoot at an enemy. You can lean while standing or crouching.To turn Leaning ON/OFF, toggle the setting under “OPTIONS > KINECT > LEANING ENABLED”.
HEAD TRACKING
The Kinect can track your head. When in a vehicle, you can turn your head to look around. This will allow you tokeep driving in one direction but still get a good look at your surroundings.To turn Head Tracking ON/OFF, toggle the setting under “OPTIONS > KINECT > HEADTRACKING ENABLED”."
