Xbox One-kaféen
Dette er dårlig grafikk, men det er bare min mening. Det ser sikkert ikke så mye bedre ut på PC eller PS4, men rart at ikke alle plattformene takler 1080p på dette.
Tror muligens det er pga gammel grafikkmotor som ikke er optimalisert for flerkjerneprossessorer, Xbox One har lav klokkefrekvens på sine 8 kjerner.
ps4 har jo problemer med masse framedrops i sin versjon, så spillet er ikke helt optimalisert virker det som
Det var snakk om COD. Hvem bryr seg om COD uansett? Både xbone og ps4 vil kjøre spill MYE bedre etter en stund. Vent 1-2 år ;)
Det er helt elendig ja. Men det ser jo skikkelig nille ut uansett, 1080p eller ei.
Some Xbox One's running an old dashboard experience bad lag with snapped apps. This is the source of the rumors with the dashboard. The latest dashboard built on October 30th is a lot smoother with no signs of this type of lag.
Veldig bra.
Edit: Her er hva Tom Warren selv skriver om det i tråden om det på neogaf:
Tom here. I'm not 100% sure it's fixed so I said better. Basically there's a variety of dashboards on offer at these Xbox One Tour events. There's an August one, September one, and an October 30th one that powers Battlefield 4. Battlefield 4 is the only one that has the latest dashboard. I'm not sure why that is, but the dash seems pretty fast on that one. I also managed to run YouTube side-by-side on the September dash and it didn't experience the type of lag that's in that video.
I haven't been able to test the apps on the October 30th dashboard as there's a requirement to sign-in (probably because they're finalizing the bits). To sign-in you need to use an @xboxtest.com account. Just navigating around the latest dashboard and launching apps (without testing them fully) seems a lot better though.
Either way, it's understandable why there were rumors around the performance of the dashboard and apps. It was clearly an issue a few months ago.
Endret av Admiral Necrolamedor
Ser for det meste bra ut, men mye lav FPS når spillet blir krevende, og åpenbare bugs.
For bugs er det aldri i spill før de blir lansert, de kan i det minste fikses med patcher. FPS drops er verre. Nå har eg ikke sett video siden eg liker å se minst mulig før eg kjøper spillet.
Etter å ha sett en ganske lang video av CoD Ghost. Kan ikke skjønne hvorfor Xbox one ikke kjøre dette i 1080p når spillet ser helt foferdelig ut. Og dette er pc gameplay eg har sett på der kravene er skyhøye og det ser absolutt ikke bra ut. Grafikken i Bf4 er 2 ganger så bra. Ryse som ser så utrolig mye bedre ut kjører i 900p. Ghost må være ekstremt dårlig optimalisert.
