Xbox One-kaféen
Mykje god info her:
http://www.reddit.co...elson_at_e3_and
I just talked to Xbox's Major Nelson at E3 and asked him about DRM & more and here's what he said:
Major Nelson (Larry Hyrb), the community manager for Xbox, said:
• MS understands the current opinion of Xbox and they are working to "educate" the masses but it doesn't sound like they are considering changing the DRM strategy in any way, including the 24 hour check-in.
• The 24 hour check-in was not designed as DRM but as a system to update your game library for when you give games to friends. I pointed out that they're now limiting game trades and asked why would it be a "feature" to update so often? He didn't have a good answer. They don't seem to understand that it doesn't matter WHY they have the check-in, the fact that it exists is a disadvantage to consumers.
• MS will likely implement a system where you can order/buy game discs at any time, and they will "activate" the game on release date, thereby locking down leaks and people playing early.
• MS considers the PS4 an "Xbox 360 version 2" in that the PS4 doesn't have many of the social and multi-tasking features the Xbone does. It doesn't seem like MS really believes they are in competition with Sony at this point. He did say that MS considers this point in time to be a "jump ball" in that neither system is backwards compatible and users may easily switch platforms.
• MS believes that while the PS4 may have slightly faster graphics RAM, the graphics RAM in the PS4 will run hotter and harder to cool. They also believe that the PS4 hardware is not as optimized as the Xbone and thus the systems will be evenly matched or Xbox will perform better.
• MS understands Don Mattrick of MS is making MS sound even worse and they're trying to essentially get him to stop talking.
• Regarding military personnel playing consoles: PS3/PS4 isn't allowed on DoD networks so they're not worried that military members will switch to PS while on overseas deployment.
• I told him that although I love Xbox and XBL, if all my friends move to PSN, I'd be going too. He said they understood that and were going to be working to actively change the messaging and marketing campaigns.
• MS isn't super concerned at this point because they don't think buying decisions are being made yet. Pre-orders, yes, but until people have the consoles, the war won't really start.
• The two free games per month you'll get as an XBL member are yours to keep, unlike the many free games on PSN, which you can't play after you cancel your PSN membership.
• Apparently Major Nelson is now in an interview with Reddit officially, so hopefully we'll soon have more info to augment this.
Let me know if you have questions!
EDIT: I've been in touch with Major Nelson and he made it clear that he didn't understand that the information he gave me was going to be passed along to others. I misunderstood, obviously. He was very gracious and took extra time to provide me additional info about Xbox and XBL. MS is doing some really cool things with cloud processing that I think will very much enhance the abilities of the Xbox One and differentiate it from the PS4.
I asked specifically about the possibility of forgoing the 24-hr check-in if the user has a physical disc. He said he'd do some research and get back to me. I'll update this post with that info when he provides it.
I also attended a pretty cool presentation demoing some new Kinect features for more hardcore games. It included raising or lowering your controller to raise/lower a shield, and physically leaning your body side to side to take cover. This was in addition to all the normal physical buttons. I could actually see myself using Kinect in this capacity where I never used it before (I tried Dance Central but didn't like it and the Kinect has pretty much sat unused since).
After talking to Major Nelson and learning more about the aforementioned new features, I am definitely more excited about the Xbox One and I'm cautiously optimistic that Microsoft will address the issues that the community is currently presenting. Microsoft seems very community focused and my faith is returning in the Xbox platform.
Det var Larry Hyrb som skulle hatt Don Mattrick si rolle i Microsoft. Han er mykje flinkare å kommunisere i alle fall.
Merk: Dette er ein Microsoft ansatt, og hans meiningar og utsakn om PS3/4 kan ein jo prøve å sjå for akkurat det dei er. Det vil ikkje bidra noko særleg å byrje krangle om dei utsakna i denne tråden. Ein kan godt ta det i VS. tråden. Eg kopierte berre reddit innlegget i sin heilhet. Vonaleg kan me fokusere på det Larry Hyrb sa om Xbox One.
Endret av BlastyTrasty
  • Liker 3
@Dore123m
Kanskje fordi Peter Moore ledet Xbox sine pressekonferanser før. Husker godt avsløringen av Halo 2 der han viste frem en "tatovering" av utgivelsesdagen til spillet. Utrolig flink til å prate for seg.
Endret av Potethode
Heldigvis blir slike ting urelevante om MS kommer med en mer offisiell melding med all informasjon. Da vil IT-aviser plukke opp den meldingen og fokusere på det MS selv kommer med. Slik at tåpelige utsagn som er sagt til noe blir borte i vinden. Det er den eneste måten MS kan få vekk alle ryktene og missforståelsen som har oppstått etter E3, og itillegg stoppe twitter-trollene som drar ryktene ut av kontekst og finner på egenskaper, slik som "Du kan ikke selge spill" osv.
Utsagnene til Microsofts "President of interactive entertainment business" blir nok sett på som ganske offisielle..
  • Liker 3
Tenker mest på at om Microsoft kommer med en pressemelding så vil den uansett kunne være en fin melding på hva Xbox One kan og ikke kan osv. At han kommer med utsagn som "Spill 360 isteden" sier seg selv at ikke kan være veldig positivt. Nå skal det sies at plutselig så sitter ingen med internett. Så i realiteten så vil det selvfølgelig være et minimalt problem, men når man må så vil man ikke. Kjent problemstilling.
Så Microsoft sin offisielle melding på: Hva om jeg ikke har internett? Er: Spill Xbox 360?
Endret av Emils.
Etter min mening, så ja. Når du får det direkte fra Don Mattrick så er det faktisk grunn til å tolke det slik. Det er jo forsåvidt også derfor han driter seg ut så til de grader. Som en av Microsofts største representanter når det kommer til Xbox one presterer han å preike så mye piss at noen (ikke alle så klart) ikke får lyst på Xbonen lenger.
Nå er det jo forsåvidt en sannhet i det at man ikke har så mye bruk for Xbone hvis man ikke har tilgang til internett overhodet. Men måten han formidler det på vitner om en holdning som tilsier at han gir blanke faen i folk som er i den problemstillingen.
Folk som har den problemstilling får heller ikke sett klippet av Don Mattrick (om du skjønner hva jeg mener). Men for å være seriøs igjen så er det bare å vente på Major Nelson som snart gir oss svar så vi slipper all missforståelsen.
Jeg lurer også litt på hvilke misforståelser du sikter til. Verken Mattrick og MS' representanter på Twitter var spesielt tvetydige. Nå er det jo klart at en del av problemene ved Xbox One vil være irrelevante for mange, men det blir likevel litt teit å late som om online-krav, bruktspillsperre og høy pris liksom bare er ondsinnede rykter spredd av Sony-fans.
