GjestAL Skrevet 5. april 2012 Del Skrevet 5. april 2012 (endret) Sitter med Linux og opplever at både ubuntu programvaresenter og Azureus kresjer. Har avinnstallert og innstallert Java. Har også sjekket på javasiden at min versjon fungerer på http://www.java.com/...ad/testjava.jsp Kjører Ubuntu 11.10 minne 1,9 Gb 32 bit system, disk er på 492 Gb ledig plass. Swap filen står i 0. Kjører Firefox 11.0 Feilmeldingen jeg får er: # A fatal error has been detected by the Java Runtime Environment: # # SIGSEGV (0xb) at pc=0x0102c962, pid=2996, tid=2341292912 # # JRE version: 6.0_23-b23 # Java VM: OpenJDK Server VM (20.0-b11 mixed mode linux-x86 ) # Derivative: IcedTea6 1.11pre # Distribution: Ubuntu 11.10, package 6b23~pre11-0ubuntu1.11.10.2 # Problematic frame: # V [libjvm.so+0x39a962] JavaCalls::call_helper(JavaValue*, methodHandle*, JavaCallArguments*, Thread*)+0x2c2 # # If you would like to submit a bug report, please include # instructions how to reproduce the bug and visit: # https://bugs.launchp...urce/openjdk-6/ # --------------- T H R E A D --------------- Current thread (0x8bb47c00): JavaThread "MainRunner" [_thread_in_Java, id=3020, stack(0x8b884000,0x8b8d5000)] siginfo:si_signo=SIGSEGV: si_errno=0, si_code=128 (), si_addr=0x00000000 Registers: EAX=0x8b8d0f5c, EBX=0x014f4ff4, ECX=0x00000002, EDX=0x8b8d1088 ESP=0x8b8d0f14, EBP=0x8b8d114c, ESI=0x08c99ff8, EDI=0x8bb47c00 EIP=0x0102c962, EFLAGS=0x00210246, CR2=0xb77bb000 Top of Stack: (sp=0x8b8d0f14) 0x8b8d0f14: 8b8d0f5c 8b8d114c 0000000b 8c6b33f8 0x8b8d0f24: b475b500 8b8d1084 00000002 8bb47c00 0x8b8d0f34: 08c99ff8 ffffffff 8b8d0f7c 00000002 0x8b8d0f44: b4752381 008d102c b475b500 0000000b 0x8b8d0f54: 014f4ff4 8bb47c00 8bb47c00 8b30d730 0x8b8d0f64: 8c6b33f8 00000000 8b8d12b0 00000000 0x8b8d0f74: 8b8d12dc 8b8d1148 8bb47c00 8bb11fe0 0x8b8d0f84: 08c99f78 08c9a000 08c9a36c 8b8d1740 Instructions: (pc=0x0102c962) 0x0102c942: 4c 24 18 89 44 24 10 8b 06 89 6c 24 04 89 44 24 0x0102c952: 0c 8b 44 24 3c 89 44 24 08 8d 44 24 48 89 04 24 0x0102c962: ff 54 24 30 8b 6f 04 85 ed 8b 54 24 28 74 0f 89 0x0102c972: 14 24 e8 d7 6c fb ff e9 6a fe ff ff 66 90 8b 74 Register to memory mapping: EAX=0x8b8d0f5c is pointing into the stack for thread: 0x8bb47c00 EBX=0x014f4ff4: &--#60;offset 0x862ff4&--#62; in /usr/lib/jvm/java-6-openjdk/jre/lib/i386/server/libjvm.so at 0x00c92000 ECX=0x00000002 is an unknown value EDX=0x8b8d1088 is pointing into the stack for thread: 0x8bb47c00 ESP=0x8b8d0f14 is pointing into the stack for thread: 0x8bb47c00 EBP=0x8b8d114c is pointing into the stack for thread: 0x8bb47c00 ESI=0x08c99ff8 is an unknown value EDI=0x8bb47c00 is a thread Stack: [0x8b884000,0x8b8d5000], sp=0x8b8d0f14, free space=307k Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code) V [libjvm.so+0x39a962] JavaCalls::call_helper(JavaValue*, methodHandle*, JavaCallArguments*, Thread*)+0x2c2 --------------- P R O C E S S --------------- Java Threads: ( =&--#62; current thread ) 0x870f2800 JavaThread "AWT-XAWT" daemon [_thread_in_native, id=3074, stack(0x86e1a000,0x86e6b000)] 0x870cb800 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=3073, stack(0x86e6b000,0x86ebc000)] 0x890e5800 JavaThread "PRUDPPacketHandler:sender" daemon [_thread_blocked, id=3072, stack(0x86ebc000,0x86f0d000)] 0x890f0800 JavaThread "Keep-Alive-Timer" daemon [_thread_blocked, id=3071, stack(0x86f0d000,0x86f5e000)] 0x8823c800 JavaThread "Slidey" daemon [_thread_blocked, id=3070, stack(0x86f5e000,0x86faf000)] 0x8827b800 JavaThread "DiskM:ListenAggregatorDispatcher" daemon [_thread_blocked, id=3069, stack(0x86faf000,0x87000000)] 0x09021000 JavaThread "DiskManager:start[1]" daemon [_thread_in_vm, id=3068, stack(0x8815e000,0x881af000)] 0x88230c00 JavaThread "Simple Timer[22]{StartStop:check}" daemon [_thread_blocked, id=3067, stack(0x881af000,0x88200000)] 0x8822cc00 JavaThread "DHTPlugin.init2" daemon [_thread_blocked, id=3066, stack(0x88334000,0x88385000)] 0x08f27400 JavaThread "TiVo:CtrlListener" daemon [_thread_in_native, id=3065, stack(0x88385000,0x883d6000)] 0x08e34800 JavaThread "TRTrackerServer:accept.loop" daemon [_thread_in_native, id=3064, stack(0x883d6000,0x88427000)] 0x8b302c00 JavaThread "PRUDPPacketReciever:31585" daemon [_thread_in_native, id=3063, stack(0x88427000,0x88478000)] 0x09123800 JavaThread "TrackerServer:timer.loop" daemon [_thread_blocked, id=3062, stack(0x88478000,0x884c9000)] 0x8ad65c00 JavaThread "BuddyPlugin:init" daemon [_thread_blocked, id=3061, stack(0x896ff000,0x89750000)] 0x08f2e800 JavaThread "Local RSS etc.::SSDP:queryLoop" daemon [_thread_blocked, id=3060, stack(0x884c9000,0x8851a000)] 0x0923e400 JavaThread "MCGroup:CtrlListener" daemon [_thread_in_native, id=3059, stack(0x8865e000,0x886af000)] 0x8b08d400 JavaThread "DHTTrackerPlugin:init" daemon [_thread_blocked, id=3058, stack(0x8851a000,0x8856b000)] 0x08f2d800 JavaThread "NetstatusPlugin:init" daemon [_thread_blocked, id=3057, stack(0x8856b000,0x885bc000)] 0x09128800 JavaThread "MagnetPlugin:init" daemon [_thread_blocked, id=3056, stack(0x885bc000,0x8860d000)] 0x09121000 JavaThread "AsyncDispatcher" daemon [_thread_blocked, id=3055, stack(0x8860d000,0x8865e000)] 0x08fc0800 JavaThread "AZInstanceManager:initialSearch" daemon [_thread_blocked, id=3053, stack(0x886af000,0x88700000)] 0x092ebc00 JavaThread "MCGroup:CtrlListener" daemon [_thread_in_native, id=3052, stack(0x8880d000,0x8885e000)] 0x08fbc800 JavaThread "MCGroup:MCListener" daemon [_thread_in_native, id=3051, stack(0x8885e000,0x888af000)] 0x08efd800 JavaThread "Global Status Checker" [_thread_blocked, id=3050, stack(0x888af000,0x88900000)] 0x08efe000 JavaThread "TRHost::stats.loop" daemon [_thread_blocked, id=3049, stack(0x8940d000,0x8945e000)] 0x08f0a400 JavaThread "Timer:Tracker Timer" daemon [_thread_blocked, id=3048, stack(0x8945e000,0x894af000)] 0x08f09400 JavaThread "GM:ListenDispatcher" daemon [_thread_blocked, id=3047, stack(0x894af000,0x89500000)] 0x08e46400 JavaThread "FMFileManager::closeQueueDispatcher" daemon [_thread_blocked, id=3046, stack(0x8960c000,0x8965d000)] 0x08e10000 JavaThread "DM:ListenAggregatorDispatcher" daemon [_thread_blocked, id=3045, stack(0x8965d000,0x896ae000)] 0x08e0cc00 JavaThread "MagnetURIHandler" daemon [_thread_in_native, id=3044, stack(0x896ae000,0x896ff000)] 0x8ad64000 JavaThread "Utilities:delayedTask" daemon [_thread_blocked, id=3042, stack(0x8994f000,0x899a0000)] 0x8ad43c00 JavaThread "MCGroup:MCListener" daemon [_thread_in_native, id=3037, stack(0x8ab5c000,0x8abad000)] 0x8ad32000 JavaThread "Timer:Process Data Sources" daemon [_thread_blocked, id=3036, stack(0x8ac0d000,0x8ac5e000)] 0x8ad16800 JavaThread "AsyncDispatcher" daemon [_thread_blocked, id=3035, stack(0x8ac5e000,0x8acaf000)] 0x8ad0a000 JavaThread "UI Updater" daemon [_thread_blocked, id=3034, stack(0x8acaf000,0x8ad00000)] 0x8ad0cc00 JavaThread "Timer:v3.PlatformMessenger.queue" daemon [_thread_blocked, id=3033, stack(0x8b25e000,0x8b2af000)] 0x8b300800 JavaThread "Start Server" daemon [_thread_in_native, id=3031, stack(0x8b2af000,0x8b300000)] 0x8b76c000 JavaThread "AsyncDispatcher" daemon [_thread_blocked, id=3030, stack(0x8b427000,0x8b478000)] 0x8b738800 JavaThread "WriteController:WriteSelector" daemon [_thread_blocked, id=3029, stack(0x8b478000,0x8b4c9000)] 0x8b762400 JavaThread "ReadController:ReadSelector" daemon [_thread_blocked, id=3028, stack(0x8b4c9000,0x8b51a000)] 0x8b736000 JavaThread "VServerSelector:port31585" daemon [_thread_in_native, id=3027, stack(0x8b51a000,0x8b56b000)] 0x8b726400 JavaThread "WriteController:WriteProcessor" daemon [_thread_blocked, id=3026, stack(0x8b56b000,0x8b5bc000)] 0x8bbfcc00 JavaThread "ReadController:ReadProcessor" daemon [_thread_blocked, id=3025, stack(0x8b5bc000,0x8b60d000)] 0x8b721400 JavaThread "AEThreadMonitor" daemon [_thread_blocked, id=3024, stack(0x8b60d000,0x8b65e000)] 0x08cfe800 JavaThread "Timer:Simple Timer" daemon [_thread_blocked, id=3023, stack(0x8b65e000,0x8b6af000)] 0x8bbfd800 JavaThread "ConnectDisconnectManager" daemon [_thread_blocked, id=3022, stack(0x8b6af000,0x8b700000)] 0x8bb9a000 JavaThread "SystemTime" daemon [_thread_blocked, id=3021, stack(0x8b81f000,0x8b870000)] 0x8bb3b000 JavaThread "DestroyJavaVM" [_thread_blocked, id=3009, stack(0xb7752000,0xb77a3000)] =&--#62;0x8bb47c00 JavaThread "MainRunner" [_thread_in_Java, id=3020, stack(0x8b884000,0x8b8d5000)] 0x8bb04800 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=3018, stack(0x8ba2e000,0x8ba7f000)] 0x8bb02800 JavaThread "C2 CompilerThread1" daemon [_thread_blocked, id=3017, stack(0x8ba7f000,0x8bb00000)] 0x8bb00800 JavaThread "C2 CompilerThread0" daemon [_thread_blocked, id=3016, stack(0x8bc38000,0x8bcb9000)] 0x08c73000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=3015, stack(0x8bcb9000,0x8bd0a000)] 0x08c63400 JavaThread "Finalizer" daemon [_thread_blocked, id=3014, stack(0x8c07c000,0x8c0cd000)] 0x08c5ec00 JavaThread "Reference Handler" daemon [_thread_blocked, id=3013, stack(0x8c0cd000,0x8c11e000)] Other Threads: 0x08c5ac00 VMThread [stack: 0x8c11e000,0x8c19f000] [id=3012] 0x8bb06400 WatcherThread [stack: 0x8b9ad000,0x8ba2e000] [id=3019] VM state:synchronizing (normal execution) VM Mutex/Monitor currently owned by a thread: ([mutex/lock_event]) [0x08bd3b78] Safepoint_lock - owner thread: 0x08c5ac00 [0x08bd3be0] Threads_lock - owner thread: 0x08c5ac00 Heap PSYoungGen total 34432K, used 31435K [0xa9bf0000, 0xae1f0000, 0xb4690000) eden space 31296K, 90% used [0xa9bf0000,0xab795a70,0xaba80000) from space 3136K, 99% used [0xaba80000,0xabd8d420,0xabd90000) to space 4544K, 0% used [0xadd80000,0xadd80000,0xae1f0000) PSOldGen total 21120K, used 4298K [0x94690000, 0x95b30000, 0xa9bf0000) object space 21120K, 20% used [0x94690000,0x94ac2a90,0x95b30000) PSPermGen total 25088K, used 25005K [0x8c690000, 0x8df10000, 0x94690000) object space 25088K, 99% used [0x8c690000,0x8defb778,0x8df10000) Code Cache [0xb4752000, 0xb4992000, 0xb7752000) total_blobs=505 nmethods=243 adapters=216 free_code_cache=49235904 largest_free_block=12288 Dynamic libraries: 00110000-001ee000 r-xp 00000000 08:01 18619069 /usr/lib/i386-linux-gnu/libstdc++.so.6.0.16 001ee000-001ef000 ---p 000de000 08:01 18619069 /usr/lib/i386-linux-gnu/libstdc++.so.6.0.16 001ef000-001f3000 r--p 000de000 08:01 18619069 /usr/lib/i386-linux-gnu/libstdc++.so.6.0.16 001f3000-001f4000 rw-p 000e2000 08:01 18619069 /usr/lib/i386-linux-gnu/libstdc++.so.6.0.16 001f4000-001fb000 rw-p 00000000 00:00 0 001fb000-00217000 r-xp 00000000 08:01 6295358 /lib/i386-linux-gnu/libgcc_s.so.1 00217000-00218000 r--p 0001b000 08:01 6295358 /lib/i386-linux-gnu/libgcc_s.so.1 00218000-00219000 rw-p 0001c000 08:01 6295358 /lib/i386-linux-gnu/libgcc_s.so.1 00219000-00220000 r-xp 00000000 08:01 18876690 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libzip.so 00220000-00221000 r--p 00006000 08:01 18876690 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libzip.so 00221000-00222000 rw-p 00007000 08:01 18876690 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libzip.so 00222000-00231000 r-xp 00000000 08:01 18876660 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libj2pkcs11.so 00231000-00232000 r--p 0000e000 08:01 18876660 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libj2pkcs11.so 00232000-00233000 rw-p 0000f000 08:01 18876660 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libj2pkcs11.so 00233000-0024a000 r-xp 00000000 08:01 18615352 /usr/lib/i386-linux-gnu/libnssutil3.so 0024a000-0024d000 r--p 00016000 08:01 18615352 /usr/lib/i386-linux-gnu/libnssutil3.so 0024d000-0024e000 rw-p 00019000 08:01 18615352 /usr/lib/i386-linux-gnu/libnssutil3.so 0024e000-00252000 r-xp 00000000 08:01 18615340 /usr/lib/i386-linux-gnu/libplc4.so 00252000-00253000 r--p 00003000 08:01 18615340 /usr/lib/i386-linux-gnu/libplc4.so 00253000-00254000 rw-p 00004000 08:01 18615340 /usr/lib/i386-linux-gnu/libplc4.so 00254000-0028b000 r-xp 00000000 08:01 18615339 /usr/lib/i386-linux-gnu/libnspr4.so 0028b000-0028c000 ---p 00037000 08:01 18615339 /usr/lib/i386-linux-gnu/libnspr4.so 0028c000-0028d000 r--p 00037000 08:01 18615339 /usr/lib/i386-linux-gnu/libnspr4.so 0028d000-0028e000 rw-p 00038000 08:01 18615339 /usr/lib/i386-linux-gnu/libnspr4.so 0028e000-00290000 rw-p 00000000 00:00 0 00290000-00297000 r-xp 00000000 08:01 18876678 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libmanagement.so 00297000-00298000 r--p 00006000 08:01 18876678 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libmanagement.so 00298000-00299000 rw-p 00007000 08:01 18876678 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libmanagement.so 00299000-002a1000 r-xp 00000000 08:01 18876682 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libnio.so 002a1000-002a2000 r--p 00007000 08:01 18876682 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libnio.so 002a2000-002a3000 rw-p 00008000 08:01 18876682 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libnio.so 002a3000-002a4000 r-xp 00000000 08:01 18615902 /usr/lib/i386-linux-gnu/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-svg.so 002a4000-002a5000 r--p 00000000 08:01 18615902 /usr/lib/i386-linux-gnu/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-svg.so 002a5000-002a6000 rw-p 00001000 08:01 18615902 /usr/lib/i386-linux-gnu/gdk-pixbuf-2.0/2.10.0/loaders/libpixbufloader-svg.so 002a6000-002b1000 r-xp 00000000 08:01 18876688 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libverify.so 002b1000-002b2000 ---p 0000b000 08:01 18876688 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libverify.so 002b2000-002b3000 r--p 0000b000 08:01 18876688 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libverify.so 002b3000-002b4000 rw-p 0000c000 08:01 18876688 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libverify.so 002b4000-00307000 r-xp 00000000 08:01 18615343 /usr/lib/i386-linux-gnu/nss/libfreebl3.so 00307000-00308000 r--p 00052000 08:01 18615343 /usr/lib/i386-linux-gnu/nss/libfreebl3.so 00308000-00309000 rw-p 00053000 08:01 18615343 /usr/lib/i386-linux-gnu/nss/libfreebl3.so 00309000-0030d000 rw-p 00000000 00:00 0 0030d000-00322000 r-xp 00000000 08:01 18876680 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libnet.so 00322000-00323000 r--p 00014000 08:01 18876680 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libnet.so 00323000-00324000 rw-p 00015000 08:01 18876680 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libnet.so 00324000-00328000 r-xp 00000000 08:01 18614487 /usr/lib/jni/libswt-gtk-3735.so 00328000-00329000 r--p 00003000 08:01 18614487 /usr/lib/jni/libswt-gtk-3735.so 00329000-0032a000 rw-p 00004000 08:01 18614487 /usr/lib/jni/libswt-gtk-3735.so 0032a000-0032b000 rw-p 00000000 00:00 0 0032b000-00330000 r-xp 00000000 08:01 18612386 /usr/lib/libXtst.so.6.1.0 00330000-00331000 r--p 00004000 08:01 18612386 /usr/lib/libXtst.so.6.1.0 00331000-00332000 rw-p 00005000 08:01 18612386 /usr/lib/libXtst.so.6.1.0 00332000-0033d000 r-xp 00000000 08:01 18621302 /usr/lib/i386-linux-gnu/libpangocairo-1.0.so.0.2903.0 0033d000-0033e000 r--p 0000a000 08:01 18621302 /usr/lib/i386-linux-gnu/libpangocairo-1.0.so.0.2903.0 0033e000-0033f000 rw-p 0000b000 08:01 18621302 /usr/lib/i386-linux-gnu/libpangocairo-1.0.so.0.2903.0 0033f000-00342000 r-xp 00000000 08:01 18612652 /usr/lib/i386-linux-gnu/libgmodule-2.0.so.0.3000.0 00342000-00343000 r--p 00002000 08:01 18612652 /usr/lib/i386-linux-gnu/libgmodule-2.0.so.0.3000.0 00343000-00344000 rw-p 00003000 08:01 18612652 /usr/lib/i386-linux-gnu/libgmodule-2.0.so.0.3000.0 00344000-0034d000 r-xp 00000000 08:01 18614626 /usr/lib/i386-linux-gnu/libXrender.so.1.3.0 0034d000-0034e000 r--p 00008000 08:01 18614626 /usr/lib/i386-linux-gnu/libXrender.so.1.3.0 0034e000-0034f000 rw-p 00009000 08:01 18614626 /usr/lib/i386-linux-gnu/libXrender.so.1.3.0 0034f000-00377000 r-xp 00000000 08:01 6292428 /lib/i386-linux-gnu/libm-2.13.so 00377000-00378000 r--p 00028000 08:01 6292428 /lib/i386-linux-gnu/libm-2.13.so 00378000-00379000 rw-p 00029000 08:01 6292428 /lib/i386-linux-gnu/libm-2.13.so 00379000-00417000 r-xp 00000000 08:01 18618700 /usr/lib/i386-linux-gnu/libsqlite3.so.0.8.6 00417000-00418000 ---p 0009e000 08:01 18618700 /usr/lib/i386-linux-gnu/libsqlite3.so.0.8.6 00418000-00419000 r--p 0009e000 08:01 18618700 /usr/lib/i386-linux-gnu/libsqlite3.so.0.8.6 00419000-0041a000 rw-p 0009f000 08:01 18618700 /usr/lib/i386-linux-gnu/libsqlite3.so.0.8.6 0041a000-0041b000 rw-p 00000000 00:00 0 0041b000-0042c000 r-xp 00000000 08:01 18612249 /usr/lib/i386-linux-gnu/libXext.so.6.4.0 0042c000-0042d000 r--p 00010000 08:01 18612249 /usr/lib/i386-linux-gnu/libXext.so.6.4.0 0042d000-0042e000 rw-p 00011000 08:01 18612249 /usr/lib/i386-linux-gnu/libXext.so.6.4.0 0042e000-00430000 r-xp 00000000 08:01 18615014 /usr/lib/i386-linux-gnu/libXinerama.so.1.0.0 00430000-00431000 r--p 00001000 08:01 18615014 /usr/lib/i386-linux-gnu/libXinerama.so.1.0.0 00431000-00432000 rw-p 00002000 08:01 18615014 /usr/lib/i386-linux-gnu/libXinerama.so.1.0.0 00432000-00434000 r-xp 00000000 08:01 18615004 /usr/lib/i386-linux-gnu/libXcomposite.so.1.0.0 00434000-00435000 r--p 00001000 08:01 18615004 /usr/lib/i386-linux-gnu/libXcomposite.so.1.0.0 00435000-00436000 rw-p 00002000 08:01 18615004 /usr/lib/i386-linux-gnu/libXcomposite.so.1.0.0 00439000-0044c000 r-xp 00000000 08:01 6292372 /lib/i386-linux-gnu/libz.so.1.2.3.4 0044c000-0044d000 r--p 00012000 08:01 6292372 /lib/i386-linux-gnu/libz.so.1.2.3.4 0044d000-0044e000 rw-p 00013000 08:01 6292372 /lib/i386-linux-gnu/libz.so.1.2.3.4 0044e000-004c5000 r-xp 00000000 08:01 18614488 /usr/lib/jni/libswt-pi-gtk-3735.so 004c5000-004c6000 r--p 00076000 08:01 18614488 /usr/lib/jni/libswt-pi-gtk-3735.so 004c6000-004c8000 rw-p 00077000 08:01 18614488 /usr/lib/jni/libswt-pi-gtk-3735.so 004c8000-004c9000 rw-p 00000000 00:00 0 004c9000-004d7000 r-xp 00000000 08:01 18615012 /usr/lib/i386-linux-gnu/libXi.so.6.1.0 004d7000-004d8000 r--p 0000d000 08:01 18615012 /usr/lib/i386-linux-gnu/libXi.so.6.1.0 004d8000-004d9000 rw-p 0000e000 08:01 18615012 /usr/lib/i386-linux-gnu/libXi.so.6.1.0 004dc000-004e4000 r-xp 00000000 08:01 6292431 /lib/i386-linux-gnu/libnss_compat-2.13.so 004e4000-004e5000 r--p 00007000 08:01 6292431 /lib/i386-linux-gnu/libnss_compat-2.13.so 004e5000-004e6000 rw-p 00008000 08:01 6292431 /lib/i386-linux-gnu/libnss_compat-2.13.so 004e6000-004ed000 r-xp 00000000 08:01 18615016 /usr/lib/i386-linux-gnu/libXrandr.so.2.2.0 004ed000-004ee000 r--p 00006000 08:01 18615016 /usr/lib/i386-linux-gnu/libXrandr.so.2.2.0 004ee000-004ef000 rw-p 00007000 08:01 18615016 /usr/lib/i386-linux-gnu/libXrandr.so.2.2.0 004ef000-004f1000 r-xp 00000000 08:01 18614624 /usr/lib/i386-linux-gnu/libxcb-shm.so.0.0.0 004f1000-004f2000 r--p 00001000 08:01 18614624 /usr/lib/i386-linux-gnu/libxcb-shm.so.0.0.0 004f2000-004f3000 rw-p 00002000 08:01 18614624 /usr/lib/i386-linux-gnu/libxcb-shm.so.0.0.0 004f3000-004f5000 r-xp 00000000 08:01 18614616 /usr/lib/i386-linux-gnu/libXau.so.6.0.0 004f5000-004f6000 r--p 00001000 08:01 18614616 /usr/lib/i386-linux-gnu/libXau.so.6.0.0 004f6000-004f7000 rw-p 00002000 08:01 18614616 /usr/lib/i386-linux-gnu/libXau.so.6.0.0 004f7000-004fe000 r-xp 00000000 08:01 6292440 /lib/i386-linux-gnu/librt-2.13.so 004fe000-004ff000 r--p 00006000 08:01 6292440 /lib/i386-linux-gnu/librt-2.13.so 004ff000-00500000 rw-p 00007000 08:01 6292440 /lib/i386-linux-gnu/librt-2.13.so 00500000-0051d000 r-xp 00000000 08:01 18618076 /usr/lib/i386-linux-gnu/libatk-1.0.so.0.20209.1 0051d000-0051f000 r--p 0001c000 08:01 18618076 /usr/lib/i386-linux-gnu/libatk-1.0.so.0.20209.1 0051f000-00520000 rw-p 0001e000 08:01 18618076 /usr/lib/i386-linux-gnu/libatk-1.0.so.0.20209.1 00520000-00529000 r-xp 00000000 08:01 18615008 /usr/lib/i386-linux-gnu/libXcursor.so.1.0.2 00529000-0052a000 r--p 00008000 08:01 18615008 /usr/lib/i386-linux-gnu/libXcursor.so.1.0.2 0052a000-0052b000 rw-p 00009000 08:01 18615008 /usr/lib/i386-linux-gnu/libXcursor.so.1.0.2 0052b000-00533000 r-xp 00000000 08:01 18614622 /usr/lib/i386-linux-gnu/libxcb-render.so.0.0.0 00533000-00534000 r--p 00007000 08:01 18614622 /usr/lib/i386-linux-gnu/libxcb-render.so.0.0.0 00534000-00535000 rw-p 00008000 08:01 18614622 /usr/lib/i386-linux-gnu/libxcb-render.so.0.0.0 00535000-00539000 rwxp 00000000 00:00 0 00539000-0055f000 r-xp 00000000 08:01 18876665 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libjava.so 0055f000-00560000 r--p 00025000 08:01 18876665 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libjava.so 00560000-00562000 rw-p 00026000 08:01 18876665 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libjava.so 00562000-0069e000 r-xp 00000000 08:01 18615353 /usr/lib/i386-linux-gnu/libnss3.so 0069e000-006a1000 r--p 0013b000 08:01 18615353 /usr/lib/i386-linux-gnu/libnss3.so 006a1000-006a3000 rw-p 0013e000 08:01 18615353 /usr/lib/i386-linux-gnu/libnss3.so 006a3000-006c1000 r-xp 00000000 08:01 18615489 /usr/lib/i386-linux-gnu/libgdk_pixbuf-2.0.so.0.2400.0 006c1000-006c2000 r--p 0001d000 08:01 18615489 /usr/lib/i386-linux-gnu/libgdk_pixbuf-2.0.so.0.2400.0 006c2000-006c3000 rw-p 0001e000 08:01 18615489 /usr/lib/i386-linux-gnu/libgdk_pixbuf-2.0.so.0.2400.0 006c3000-006ee000 r-xp 00000000 08:01 18621303 /usr/lib/i386-linux-gnu/libpangoft2-1.0.so.0.2903.0 006ee000-006ef000 r--p 0002a000 08:01 18621303 /usr/lib/i386-linux-gnu/libpangoft2-1.0.so.0.2903.0 006ef000-006f0000 rw-p 0002b000 08:01 18621303 /usr/lib/i386-linux-gnu/libpangoft2-1.0.so.0.2903.0 006f0000-006f4000 r-xp 00000000 08:01 18622144 /usr/lib/libcanberra-gtk.so.0.1.8 006f4000-006f5000 r--p 00003000 08:01 18622144 /usr/lib/libcanberra-gtk.so.0.1.8 006f5000-006f6000 rw-p 00004000 08:01 18622144 /usr/lib/libcanberra-gtk.so.0.1.8 006f6000-006f9000 r-xp 00000000 08:01 18615341 /usr/lib/i386-linux-gnu/libplds4.so 006f9000-006fa000 r--p 00002000 08:01 18615341 /usr/lib/i386-linux-gnu/libplds4.so 006fa000-006fb000 rw-p 00003000 08:01 18615341 /usr/lib/i386-linux-gnu/libplds4.so 006fb000-00700000 r-xp 00000000 08:01 18620839 /usr/lib/i386-linux-gnu/libffi.so.6.0.0 00700000-00701000 r--p 00004000 08:01 18620839 /usr/lib/i386-linux-gnu/libffi.so.6.0.0 00701000-00702000 rw-p 00005000 08:01 18620839 /usr/lib/i386-linux-gnu/libffi.so.6.0.0 00702000-00707000 r-xp 00000000 08:01 18614618 /usr/lib/i386-linux-gnu/libXdmcp.so.6.0.0 00707000-00708000 r--p 00004000 08:01 18614618 /usr/lib/i386-linux-gnu/libXdmcp.so.6.0.0 00708000-00709000 rw-p 00005000 08:01 18614618 /usr/lib/i386-linux-gnu/libXdmcp.so.6.0.0 00709000-0071e000 r-xp 00000000 08:01 6292430 /lib/i386-linux-gnu/libnsl-2.13.so 0071e000-0071f000 r--p 00015000 08:01 6292430 /lib/i386-linux-gnu/libnsl-2.13.so 0071f000-00720000 rw-p 00016000 08:01 6292430 /lib/i386-linux-gnu/libnsl-2.13.so 00720000-00722000 rw-p 00000000 00:00 0 00722000-00769000 r-xp 00000000 08:01 18621301 /usr/lib/i386-linux-gnu/libpango-1.0.so.0.2903.0 00769000-0076a000 r--p 00047000 08:01 18621301 /usr/lib/i386-linux-gnu/libpango-1.0.so.0.2903.0 0076a000-0076b000 rw-p 00048000 08:01 18621301 /usr/lib/i386-linux-gnu/libpango-1.0.so.0.2903.0 0076b000-00770000 r-xp 00000000 08:01 18617268 /usr/lib/gtk-2.0/modules/libcanberra-gtk-module.so 00770000-00771000 r--p 00004000 08:01 18617268 /usr/lib/gtk-2.0/modules/libcanberra-gtk-module.so 00771000-00772000 rw-p 00005000 08:01 18617268 /usr/lib/gtk-2.0/modules/libcanberra-gtk-module.so 00772000-00774000 r-xp 00000000 08:01 18621308 /usr/lib/i386-linux-gnu/pango/1.6.0/modules/pango-basic-fc.so 00774000-00775000 r--p 00001000 08:01 18621308 /usr/lib/i386-linux-gnu/pango/1.6.0/modules/pango-basic-fc.so 00775000-00776000 rw-p 00002000 08:01 18621308 /usr/lib/i386-linux-gnu/pango/1.6.0/modules/pango-basic-fc.so 00779000-007b9000 r-xp 00000000 08:01 18615344 /usr/lib/i386-linux-gnu/nss/libsoftokn3.so 007b9000-007ba000 r--p 0003f000 08:01 18615344 /usr/lib/i386-linux-gnu/nss/libsoftokn3.so 007ba000-007bb000 rw-p 00040000 08:01 18615344 /usr/lib/i386-linux-gnu/nss/libsoftokn3.so 007bb000-007d8000 r-xp 00000000 08:01 18614620 /usr/lib/i386-linux-gnu/libxcb.so.1.1.0 007d8000-007d9000 r--p 0001c000 08:01 18614620 /usr/lib/i386-linux-gnu/libxcb.so.1.1.0 007d9000-007da000 rw-p 0001d000 08:01 18614620 /usr/lib/i386-linux-gnu/libxcb.so.1.1.0 007da000-007e8000 r-xp 00000000 08:01 18616441 /usr/lib/liboverlay-scrollbar-0.2.so.0.0.11 007e8000-007e9000 r--p 0000d000 08:01 18616441 /usr/lib/liboverlay-scrollbar-0.2.so.0.0.11 007e9000-007ea000 rw-p 0000e000 08:01 18616441 /usr/lib/liboverlay-scrollbar-0.2.so.0.0.11 007ed000-007f8000 r-xp 00000000 08:01 6292433 /lib/i386-linux-gnu/libnss_files-2.13.so 007f8000-007f9000 r--p 0000a000 08:01 6292433 /lib/i386-linux-gnu/libnss_files-2.13.so 007f9000-007fa000 rw-p 0000b000 08:01 6292433 /lib/i386-linux-gnu/libnss_files-2.13.so 007fa000-008a5000 r-xp 00000000 08:01 18613493 /usr/lib/i386-linux-gnu/libgdk-x11-2.0.so.0.2400.6 008a5000-008a7000 r--p 000ab000 08:01 18613493 /usr/lib/i386-linux-gnu/libgdk-x11-2.0.so.0.2400.6 008a7000-008a8000 rw-p 000ad000 08:01 18613493 /usr/lib/i386-linux-gnu/libgdk-x11-2.0.so.0.2400.6 008a8000-008b7000 r-xp 00000000 08:01 18614994 /usr/lib/libcanberra.so.0.2.5 008b7000-008b8000 r--p 0000e000 08:01 18614994 /usr/lib/libcanberra.so.0.2.5 008b8000-008b9000 rw-p 0000f000 08:01 18614994 /usr/lib/libcanberra.so.0.2.5 008b9000-008ba000 r-xp 00000000 00:00 0 [vdso] 008ba000-008ec000 r-xp 00000000 08:01 18612438 /usr/lib/i386-linux-gnu/libfontconfig.so.1.4.4 008ec000-008ed000 ---p 00032000 08:01 18612438 /usr/lib/i386-linux-gnu/libfontconfig.so.1.4.4 008ed000-008ee000 r--p 00032000 08:01 18612438 /usr/lib/i386-linux-gnu/libfontconfig.so.1.4.4 008ee000-008ef000 rw-p 00033000 08:01 18612438 /usr/lib/i386-linux-gnu/libfontconfig.so.1.4.4 008ef000-008f3000 r-xp 00000000 08:01 18615006 /usr/lib/i386-linux-gnu/libXfixes.so.3.1.0 008f3000-008f4000 r--p 00003000 08:01 18615006 /usr/lib/i386-linux-gnu/libXfixes.so.3.1.0 008f4000-008f5000 rw-p 00004000 08:01 18615006 /usr/lib/i386-linux-gnu/libXfixes.so.3.1.0 008f5000-00942000 r-xp 00000000 08:01 18612630 /usr/lib/i386-linux-gnu/libgobject-2.0.so.0.3000.0 00942000-00943000 r--p 0004d000 08:01 18612630 /usr/lib/i386-linux-gnu/libgobject-2.0.so.0.3000.0 00943000-00944000 rw-p 0004e000 08:01 18612630 /usr/lib/i386-linux-gnu/libgobject-2.0.so.0.3000.0 00944000-0096c000 r-xp 00000000 08:01 6291545 /lib/i386-linux-gnu/libpng12.so.0.46.0 0096c000-0096d000 r--p 00027000 08:01 6291545 /lib/i386-linux-gnu/libpng12.so.0.46.0 0096d000-0096e000 rw-p 00028000 08:01 6291545 /lib/i386-linux-gnu/libpng12.so.0.46.0 0096e000-0098a000 r-xp 00000000 08:01 6292300 /lib/i386-linux-gnu/libselinux.so.1 0098a000-0098b000 r--p 0001b000 08:01 6292300 /lib/i386-linux-gnu/libselinux.so.1 0098b000-0098c000 rw-p 0001c000 08:01 6292300 /lib/i386-linux-gnu/libselinux.so.1 0098c000-0099f000 r-xp 00000000 08:01 6292439 /lib/i386-linux-gnu/libresolv-2.13.so 0099f000-009a0000 r--p 00012000 08:01 6292439 /lib/i386-linux-gnu/libresolv-2.13.so 009a0000-009a1000 rw-p 00013000 08:01 6292439 /lib/i386-linux-gnu/libresolv-2.13.so 009a1000-009a3000 rw-p 00000000 00:00 0 009a3000-00b1b000 r-xp 00000000 08:01 6291939 /lib/i386-linux-gnu/libc-2.13.so 00b1b000-00b1d000 r--p 00178000 08:01 6291939 /lib/i386-linux-gnu/libc-2.13.so 00b1d000-00b1e000 rw-p 0017a000 08:01 6291939 /lib/i386-linux-gnu/libc-2.13.so 00b1e000-00b21000 rw-p 00000000 00:00 0 00b21000-00b47000 r-xp 00000000 08:01 6292312 /lib/i386-linux-gnu/libexpat.so.1.5.2 00b47000-00b48000 ---p 00026000 08:01 6292312 /lib/i386-linux-gnu/libexpat.so.1.5.2 00b48000-00b4a000 r--p 00026000 08:01 6292312 /lib/i386-linux-gnu/libexpat.so.1.5.2 00b4a000-00b4b000 rw-p 00028000 08:01 6292312 /lib/i386-linux-gnu/libexpat.so.1.5.2 00b4b000-00b53000 r-xp 00000000 08:01 18612262 /usr/lib/i386-linux-gnu/libvorbisfile.so.3.3.4 00b53000-00b54000 r--p 00007000 08:01 18612262 /usr/lib/i386-linux-gnu/libvorbisfile.so.3.3.4 00b54000-00b55000 rw-p 00008000 08:01 18612262 /usr/lib/i386-linux-gnu/libvorbisfile.so.3.3.4 00b58000-00b6f000 r-xp 00000000 08:01 6292438 /lib/i386-linux-gnu/libpthread-2.13.so 00b6f000-00b70000 r--p 00016000 08:01 6292438 /lib/i386-linux-gnu/libpthread-2.13.so 00b70000-00b71000 rw-p 00017000 08:01 6292438 /lib/i386-linux-gnu/libpthread-2.13.so 00b71000-00b73000 rw-p 00000000 00:00 0 00b73000-00b7b000 r-xp 00000000 08:01 18621670 /usr/lib/libltdl.so.7.3.0 00b7b000-00b7c000 r--p 00008000 08:01 18621670 /usr/lib/libltdl.so.7.3.0 00b7c000-00b7d000 rw-p 00009000 08:01 18621670 /usr/lib/libltdl.so.7.3.0 00b7d000-00b83000 r-xp 00000000 08:01 18614910 /usr/lib/i386-linux-gnu/libogg.so.0.7.1 00b83000-00b84000 r--p 00005000 08:01 18614910 /usr/lib/i386-linux-gnu/libogg.so.0.7.1 00b84000-00b85000 rw-p 00006000 08:01 18614910 /usr/lib/i386-linux-gnu/libogg.so.0.7.1 00b85000-00b8e000 r-xp 00000000 08:01 18875346 /usr/lib/i386-linux-gnu/gtk-2.0/2.10.0/engines/libpixmap.so 00b8e000-00b8f000 r--p 00008000 08:01 18875346 /usr/lib/i386-linux-gnu/gtk-2.0/2.10.0/engines/libpixmap.so 00b8f000-00b90000 rw-p 00009000 08:01 18875346 /usr/lib/i386-linux-gnu/gtk-2.0/2.10.0/engines/libpixmap.so 00b90000-00b92000 r-xp 00000000 08:01 6291524 /lib/libnss_mdns4_minimal.so.2 00b92000-00b93000 r--p 00001000 08:01 6291524 /lib/libnss_mdns4_minimal.so.2 00b93000-00b94000 rw-p 00002000 08:01 6291524 /lib/libnss_mdns4_minimal.so.2 00b97000-00b9a000 r-xp 00000000 08:01 6292426 /lib/i386-linux-gnu/libdl-2.13.so 00b9a000-00b9b000 r--p 00002000 08:01 6292426 /lib/i386-linux-gnu/libdl-2.13.so 00b9b000-00b9c000 rw-p 00003000 08:01 6292426 /lib/i386-linux-gnu/libdl-2.13.so 00b9c000-00bd9000 r-xp 00000000 08:01 6292351 /lib/i386-linux-gnu/libpcre.so.3.12.1 00bd9000-00bda000 r--p 0003c000 08:01 6292351 /lib/i386-linux-gnu/libpcre.so.3.12.1 00bda000-00bdb000 rw-p 0003d000 08:01 6292351 /lib/i386-linux-gnu/libpcre.so.3.12.1 00bdb000-00be0000 r-xp 00000000 08:01 6292432 /lib/i386-linux-gnu/libnss_dns-2.13.so 00be0000-00be1000 r--p 00004000 08:01 6292432 /lib/i386-linux-gnu/libnss_dns-2.13.so 00be1000-00be2000 rw-p 00005000 08:01 6292432 /lib/i386-linux-gnu/libnss_dns-2.13.so 00be2000-00be6000 r-xp 00000000 08:01 18616278 /usr/lib/gtk-2.0/2.10.0/menuproxies/libappmenu.so 00be6000-00be7000 r--p 00004000 08:01 18616278 /usr/lib/gtk-2.0/2.10.0/menuproxies/libappmenu.so 00be7000-00be8000 rw-p 00005000 08:01 18616278 /usr/lib/gtk-2.0/2.10.0/menuproxies/libappmenu.so 00be8000-00bf4000 r-xp 00000000 08:01 18614490 /usr/lib/jni/libswt-cairo-gtk-3735.so 00bf4000-00bf5000 r--p 0000c000 08:01 18614490 /usr/lib/jni/libswt-cairo-gtk-3735.so 00bf5000-00bf6000 rw-p 0000d000 08:01 18614490 /usr/lib/jni/libswt-cairo-gtk-3735.so 00bf7000-00bf9000 r-xp 00000000 08:01 18615010 /usr/lib/i386-linux-gnu/libXdamage.so.1.1.0 00bf9000-00bfa000 r--p 00001000 08:01 18615010 /usr/lib/i386-linux-gnu/libXdamage.so.1.1.0 00bfa000-00bfb000 rw-p 00002000 08:01 18615010 /usr/lib/i386-linux-gnu/libXdamage.so.1.1.0 00bfd000-00c01000 r-xp 00000000 08:01 18876646 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/jli/libjli.so 00c01000-00c02000 r--p 00003000 08:01 18876646 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/jli/libjli.so 00c02000-00c03000 rw-p 00004000 08:01 18876646 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/jli/libjli.so 00c03000-00c08000 r-xp 00000000 08:01 19008948 /usr/lib/i386-linux-gnu/gtk-2.0/2.10.0/immodules/im-ibus.so 00c08000-00c09000 ---p 00005000 08:01 19008948 /usr/lib/i386-linux-gnu/gtk-2.0/2.10.0/immodules/im-ibus.so 00c09000-00c0a000 r--p 00005000 08:01 19008948 /usr/lib/i386-linux-gnu/gtk-2.0/2.10.0/immodules/im-ibus.so 00c0a000-00c0b000 rw-p 00006000 08:01 19008948 /usr/lib/i386-linux-gnu/gtk-2.0/2.10.0/immodules/im-ibus.so 00c10000-00c21000 r-xp 00000000 08:01 18614922 /usr/lib/i386-linux-gnu/libtdb.so.1.2.9 00c21000-00c22000 r--p 00010000 08:01 18614922 /usr/lib/i386-linux-gnu/libtdb.so.1.2.9 00c22000-00c23000 rw-p 00011000 08:01 18614922 /usr/lib/i386-linux-gnu/libtdb.so.1.2.9 00c2d000-00c31000 r-xp 00000000 08:01 18612657 /usr/lib/i386-linux-gnu/libgthread-2.0.so.0.3000.0 00c31000-00c32000 r--p 00003000 08:01 18612657 /usr/lib/i386-linux-gnu/libgthread-2.0.so.0.3000.0 00c32000-00c33000 rw-p 00004000 08:01 18612657 /usr/lib/i386-linux-gnu/libgthread-2.0.so.0.3000.0 00c33000-00c43000 r-xp 00000000 08:01 18616276 /usr/lib/libdbusmenu-gtk.so.4.0.5 00c43000-00c44000 ---p 00010000 08:01 18616276 /usr/lib/libdbusmenu-gtk.so.4.0.5 00c44000-00c45000 r--p 00010000 08:01 18616276 /usr/lib/libdbusmenu-gtk.so.4.0.5 00c45000-00c46000 rw-p 00011000 08:01 18616276 /usr/lib/libdbusmenu-gtk.so.4.0.5 00c4e000-00c58000 r-xp 00000000 08:01 6292435 /lib/i386-linux-gnu/libnss_nis-2.13.so 00c58000-00c59000 r--p 00009000 08:01 6292435 /lib/i386-linux-gnu/libnss_nis-2.13.so 00c59000-00c5a000 rw-p 0000a000 08:01 6292435 /lib/i386-linux-gnu/libnss_nis-2.13.so 00c5a000-00c66000 r-xp 00000000 08:01 18614485 /usr/lib/jni/libswt-atk-gtk-3735.so 00c66000-00c67000 r--p 0000b000 08:01 18614485 /usr/lib/jni/libswt-atk-gtk-3735.so 00c67000-00c68000 rw-p 0000c000 08:01 18614485 /usr/lib/jni/libswt-atk-gtk-3735.so 00c72000-00c90000 r-xp 00000000 08:01 6291936 /lib/i386-linux-gnu/ld-2.13.so 00c90000-00c91000 r--p 0001d000 08:01 6291936 /lib/i386-linux-gnu/ld-2.13.so 00c91000-00c92000 rw-p 0001e000 08:01 6291936 /lib/i386-linux-gnu/ld-2.13.so 00c92000-014b0000 r-xp 00000000 08:01 18876692 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/server/libjvm.so 014b0000-014f5000 r--p 0081e000 08:01 18876692 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/server/libjvm.so 014f5000-01504000 rw-p 00863000 08:01 18876692 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/server/libjvm.so 01504000-0191e000 rw-p 00000000 00:00 0 0191e000-01a4f000 r-xp 00000000 08:01 18613467 /usr/lib/i386-linux-gnu/libX11.so.6.3.0 01a4f000-01a50000 ---p 00131000 08:01 18613467 /usr/lib/i386-linux-gnu/libX11.so.6.3.0 01a50000-01a51000 r--p 00131000 08:01 18613467 /usr/lib/i386-linux-gnu/libX11.so.6.3.0 01a51000-01a53000 rw-p 00132000 08:01 18613467 /usr/lib/i386-linux-gnu/libX11.so.6.3.0 01a53000-01a54000 rw-p 00000000 00:00 0 01a54000-01b4b000 r-xp 00000000 08:01 6291607 /lib/i386-linux-gnu/libglib-2.0.so.0.3000.0 01b4b000-01b4c000 r--p 000f6000 08:01 6291607 /lib/i386-linux-gnu/libglib-2.0.so.0.3000.0 01b4c000-01b4d000 rw-p 000f7000 08:01 6291607 /lib/i386-linux-gnu/libglib-2.0.so.0.3000.0 01b4d000-01b83000 r-xp 00000000 08:01 18615914 /usr/lib/i386-linux-gnu/librsvg-2.so.2.34.1 01b83000-01b84000 r--p 00036000 08:01 18615914 /usr/lib/i386-linux-gnu/librsvg-2.so.2.34.1 01b84000-01b85000 rw-p 00037000 08:01 18615914 /usr/lib/i386-linux-gnu/librsvg-2.so.2.34.1 01b85000-01bb6000 r-xp 00000000 08:01 18615994 /usr/lib/libcroco-0.6.so.3.0.1 01bb6000-01bb7000 r--p 00030000 08:01 18615994 /usr/lib/libcroco-0.6.so.3.0.1 01bb7000-01bb9000 rw-p 00031000 08:01 18615994 /usr/lib/libcroco-0.6.so.3.0.1 01dbe000-01dfd000 r-xp 00000000 08:01 18616048 /usr/lib/libibus-1.0.so.0.0.0 01dfd000-01dfe000 r--p 0003f000 08:01 18616048 /usr/lib/libibus-1.0.so.0.0.0 01dfe000-01dff000 rw-p 00040000 08:01 18616048 /usr/lib/libibus-1.0.so.0.0.0 01fae000-01fd8000 r-xp 00000000 08:01 18616499 /usr/lib/gio/modules/libgvfsdbus.so 01fd8000-01fd9000 r--p 00029000 08:01 18616499 /usr/lib/gio/modules/libgvfsdbus.so 01fd9000-01fda000 rw-p 0002a000 08:01 18616499 /usr/lib/gio/modules/libgvfsdbus.so 02edb000-0333c000 r-xp 00000000 08:01 18613492 /usr/lib/i386-linux-gnu/libgtk-x11-2.0.so.0.2400.6 0333c000-03340000 r--p 00461000 08:01 18613492 /usr/lib/i386-linux-gnu/libgtk-x11-2.0.so.0.2400.6 03340000-03342000 rw-p 00465000 08:01 18613492 /usr/lib/i386-linux-gnu/libgtk-x11-2.0.so.0.2400.6 03342000-03344000 rw-p 00000000 00:00 0 039fd000-03b44000 r-xp 00000000 08:01 18612936 /usr/lib/libxml2.so.2.7.8 03b44000-03b48000 r--p 00147000 08:01 18612936 /usr/lib/libxml2.so.2.7.8 03b48000-03b49000 rw-p 0014b000 08:01 18612936 /usr/lib/libxml2.so.2.7.8 03b49000-03b4a000 rw-p 00000000 00:00 0 03c1c000-03caf000 r-xp 00000000 08:01 18876650 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libawt.so 03caf000-03cb0000 r--p 00092000 08:01 18876650 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libawt.so 03cb0000-03cb7000 rw-p 00093000 08:01 18876650 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libawt.so 03cb7000-03cdb000 rw-p 00000000 00:00 0 03e20000-03e6c000 r-xp 00000000 08:01 18876297 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/xawt/libmawt.so 03e6c000-03e6d000 r--p 0004b000 08:01 18876297 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/xawt/libmawt.so 03e6d000-03e6f000 rw-p 0004c000 08:01 18876297 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/xawt/libmawt.so 03e6f000-03e70000 rw-p 00000000 00:00 0 045f6000-04674000 r-xp 00000000 08:01 18613465 /usr/lib/i386-linux-gnu/libpixman-1.so.0.22.2 04674000-04678000 r--p 0007d000 08:01 18613465 /usr/lib/i386-linux-gnu/libpixman-1.so.0.22.2 04678000-04679000 rw-p 00081000 08:01 18613465 /usr/lib/i386-linux-gnu/libpixman-1.so.0.22.2 04abb000-04ad0000 r-xp 00000000 08:01 18616497 /usr/lib/gvfs/libgvfscommon.so 04ad0000-04ad1000 r--p 00015000 08:01 18616497 /usr/lib/gvfs/libgvfscommon.so 04ad1000-04ad2000 rw-p 00016000 08:01 18616497 /usr/lib/gvfs/libgvfscommon.so 059e7000-05a14000 r-xp 00000000 08:01 18618499 /usr/lib/gtk-2.0/2.10.0/engines/libmurrine.so 05a14000-05a15000 r--p 0002c000 08:01 18618499 /usr/lib/gtk-2.0/2.10.0/engines/libmurrine.so 05a15000-05a16000 rw-p 0002d000 08:01 18618499 /usr/lib/gtk-2.0/2.10.0/engines/libmurrine.so 05a95000-05adc000 r-xp 00000000 08:01 6291480 /lib/i386-linux-gnu/libdbus-1.so.3.5.7 05adc000-05add000 r--p 00046000 08:01 6291480 /lib/i386-linux-gnu/libdbus-1.so.3.5.7 05add000-05ade000 rw-p 00047000 08:01 6291480 /lib/i386-linux-gnu/libdbus-1.so.3.5.7 061da000-062a1000 r-xp 00000000 08:01 18614628 /usr/lib/i386-linux-gnu/libcairo.so.2.11000.2 062a1000-062a2000 r--p 000c7000 08:01 18614628 /usr/lib/i386-linux-gnu/libcairo.so.2.11000.2 062a2000-062a3000 rw-p 000c8000 08:01 18614628 /usr/lib/i386-linux-gnu/libcairo.so.2.11000.2 062a3000-062a5000 rw-p 00000000 00:00 0 064a7000-064bf000 r-xp 00000000 08:01 18621621 /usr/lib/libdbusmenu-glib.so.4.0.5 064bf000-064c0000 r--p 00017000 08:01 18621621 /usr/lib/libdbusmenu-glib.so.4.0.5 064c0000-064c1000 rw-p 00018000 08:01 18621621 /usr/lib/libdbusmenu-glib.so.4.0.5 0664f000-0665f000 r-xp 00000000 08:01 6292445 /lib/i386-linux-gnu/libudev.so.0.12.0 0665f000-06660000 r--p 0000f000 08:01 6292445 /lib/i386-linux-gnu/libudev.so.0.12.0 06660000-06661000 rw-p 00010000 08:01 6292445 /lib/i386-linux-gnu/libudev.so.0.12.0 0693e000-06a80000 r-xp 00000000 08:01 18612747 /usr/lib/i386-linux-gnu/libgio-2.0.so.0.3000.0 06a80000-06a82000 r--p 00142000 08:01 18612747 /usr/lib/i386-linux-gnu/libgio-2.0.so.0.3000.0 06a82000-06a83000 rw-p 00144000 08:01 18612747 /usr/lib/i386-linux-gnu/libgio-2.0.so.0.3000.0 06a83000-06a84000 rw-p 00000000 00:00 0 06f3a000-06f63000 r-xp 00000000 08:01 18614787 /usr/lib/i386-linux-gnu/libvorbis.so.0.4.5 06f63000-06f64000 r--p 00028000 08:01 18614787 /usr/lib/i386-linux-gnu/libvorbis.so.0.4.5 06f64000-06f65000 rw-p 00029000 08:01 18614787 /usr/lib/i386-linux-gnu/libvorbis.so.0.4.5 07714000-077a6000 r-xp 00000000 08:01 18612938 /usr/lib/i386-linux-gnu/libfreetype.so.6.6.2 077a6000-077aa000 r--p 00091000 08:01 18612938 /usr/lib/i386-linux-gnu/libfreetype.so.6.6.2 077aa000-077ab000 rw-p 00095000 08:01 18612938 /usr/lib/i386-linux-gnu/libfreetype.so.6.6.2 07ad1000-07b0b000 r-xp 00000000 08:01 18876653 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libfontmanager.so 07b0b000-07b0c000 r--p 00039000 08:01 18876653 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libfontmanager.so 07b0c000-07b0d000 rw-p 0003a000 08:01 18876653 /usr/lib/jvm/java-6-openjdk/jre/lib/i386/libfontmanager.so 08048000-08051000 r-xp 00000000 08:01 18876748 /usr/lib/jvm/java-6-openjdk/jre/bin/java 08051000-08052000 r--p 00008000 08:01 18876748 /usr/lib/jvm/java-6-openjdk/jre/bin/java 08052000-08053000 rw-p 00009000 08:01 18876748 /usr/lib/jvm/java-6-openjdk/jre/bin/java 08bcf000-096e6000 rw-p 00000000 00:00 0 [heap] 86caf000-86cb2000 ---p 00000000 00:00 0 86cb2000-86d00000 rw-p 00000000 00:00 0 86d00000-86d5f000 rw-p 00000000 00:00 0 86d5f000-86e00000 ---p 00000000 00:00 0 86e1a000-86e1d000 ---p 00000000 00:00 0 86e1d000-86e6b000 rw-p 00000000 00:00 0 86e6b000-86e6e000 ---p 00000000 00:00 0 86e6e000-86ebc000 rw-p 00000000 00:00 0 86ebc000-86ebf000 ---p 00000000 00:00 0 86ebf000-86f0d000 rw-p 00000000 00:00 0 86f0d000-86f10000 ---p 00000000 00:00 0 86f10000-86f5e000 rw-p 00000000 00:00 0 86f5e000-86f61000 ---p 00000000 00:00 0 86f61000-86faf000 rw-p 00000000 00:00 0 86faf000-86fb2000 ---p 00000000 00:00 0 86fb2000-87000000 rw-p 00000000 00:00 0 87000000-87100000 rw-p 00000000 00:00 0 87121000-87e54000 r--p 00000000 08:01 20579929 /usr/share/icons/hicolor/icon-theme.cache 87e54000-88075000 r--p 00000000 08:01 20580145 /usr/share/icons/gnome/icon-theme.cache 88075000-8815e000 r--p 00000000 08:01 20581463 /usr/share/icons/Humanity/icon-theme.cache 8815e000-88161000 ---p 00000000 00:00 0 88161000-881af000 rw-p 00000000 00:00 0 881af000-881b2000 ---p 00000000 00:00 0 881b2000-88200000 rw-p 00000000 00:00 0 88200000-882fe000 rw-p 00000000 00:00 0 882fe000-88300000 ---p 00000000 00:00 0 88334000-88337000 ---p 00000000 00:00 0 88337000-88385000 rw-p 00000000 00:00 0 88385000-88388000 ---p 00000000 00:00 0 88388000-883d6000 rw-p 00000000 00:00 0 883d6000-883d9000 ---p 00000000 00:00 0 883d9000-88427000 rw-p 00000000 00:00 0 88427000-8842a000 ---p 00000000 00:00 0 8842a000-88478000 rw-p 00000000 00:00 0 88478000-8847b000 ---p 00000000 00:00 0 8847b000-884c9000 rw-p 00000000 00:00 0 884c9000-884cc000 ---p 00000000 00:00 0 884cc000-8851a000 rw-p 00000000 00:00 0 8851a000-8851d000 ---p 00000000 00:00 0 8851d000-8856b000 rw-p 00000000 00:00 0 8856b000-8856e000 ---p 00000000 00:00 0 8856e000-885bc000 rw-p 00000000 00:00 0 885bc000-885bf000 ---p 00000000 00:00 0 885bf000-8860d000 rw-p 00000000 00:00 0 8860d000-88610000 ---p 00000000 00:00 0 88610000-8865e000 rw-p 00000000 00:00 0 8865e000-88661000 ---p 00000000 00:00 0 88661000-886af000 rw-p 00000000 00:00 0 886af000-886b2000 ---p 00000000 00:00 0 886b2000-88700000 rw-p 00000000 00:00 0 88700000-887c5000 rw-p 00000000 00:00 0 887c5000-88800000 ---p 00000000 00:00 0 8880d000-88810000 ---p 00000000 00:00 0 88810000-8885e000 rw-p 00000000 00:00 0 8885e000-88861000 ---p 00000000 00:00 0 88861000-888af000 rw-p 00000000 00:00 0 888af000-888b2000 ---p 00000000 00:00 0 888b2000-88900000 rw-p 00000000 00:00 0 88900000-889f8000 rw-p 00000000 00:00 0 889f8000-88a00000 ---p 00000000 00:00 0 88a00000-88af7000 rw-p 00000000 00:00 0 88af7000-88b00000 ---p 00000000 00:00 0 88b00000-88bf5000 rw-p 00000000 00:00 0 88bf5000-88c00000 ---p 00000000 00:00 0 88c00000-88cf6000 rw-p 00000000 00:00 0 88cf6000-88d00000 ---p 00000000 00:00 0 88d00000-88dfd000 rw-p 00000000 00:00 0 88dfd000-88e00000 ---p 00000000 00:00 0 88e00000-88efa000 rw-p 00000000 00:00 0 88efa000-88f00000 ---p 00000000 00:00 0 88f00000-88ff7000 rw-p 00000000 00:00 0 88ff7000-89000000 ---p 00000000 00:00 0 89000000-890f1000 rw-p 00000000 00:00 0 890f1000-89100000 ---p 00000000 00:00 0 89100000-89300000 rw-p 00000000 00:00 0 89300000-893fe000 rw-p 00000000 00:00 0 893fe000-89400000 ---p 00000000 00:00 0 8940d000-89410000 ---p 00000000 00:00 0 89410000-8945e000 rw-p 00000000 00:00 0 8945e000-89461000 ---p 00000000 00:00 0 89461000-894af000 rw-p 00000000 00:00 0 894af000-894b2000 ---p 00000000 00:00 0 894b2000-89500000 rw-p 00000000 00:00 0 89500000-89600000 rw-p 00000000 00:00 0 8960c000-8960f000 ---p 00000000 00:00 0 8960f000-8965d000 rw-p 00000000 00:00 0 8965d000-89660000 ---p 00000000 00:00 0 89660000-896ae000 rw-p 00000000 00:00 0 896ae000-896b1000 ---p 00000000 00:00 0 896b1000-896ff000 rw-p 00000000 00:00 0 896ff000-89702000 ---p 00000000 00:00 0 89702000-89750000 rw-p 00000000 00:00 0 89750000-89800000 r--p 00000000 08:01 19662691 /usr/share/fonts/truetype/ttf-dejavu/DejaVuSans.ttf 89800000-898ff000 rw-p 00000000 00:00 0 898ff000-89900000 ---p 00000000 00:00 0 89920000-89932000 r--p 00000000 08:01 19007587 /usr/share/locale-langpack/nb/LC_MESSAGES/gedit.mo 89932000-8994f000 r--s 00000000 08:01 19006120 /usr/share/mime/mime.cache 8994f000-89952000 ---p 00000000 00:00 0 89952000-899a0000 rw-p 00000000 00:00 0 899a0000-89a00000 rw-s 00000000 00:04 98307 /SYSV00000000 (deleted) 89a00000-89aff000 rw-p 00000000 00:00 0 89aff000-89b00000 ---p 00000000 00:00 0 89b00000-89b08000 r--s 00000000 08:01 7871400 /home/dagarne/.local/share/gvfs-metadata/root-a64bd5c7.log 89b08000-89b5a000 r--p 00000000 08:01 19662202 /usr/share/fonts/truetype/ubuntu-font-family/Ubuntu-B.ttf 89b5a000-89b5b000 ---p 00000000 00:00 0 89b5b000-8a35b000 rw-p 00000000 00:00 0 8a35b000-8a35c000 ---p 00000000 00:00 0 8a35c000-8ab5c000 rw-p 00000000 00:00 0 8ab5c000-8ab5f000 ---p 00000000 00:00 0 8ab5f000-8abad000 rw-p 00000000 00:00 0 8abad000-8ac0d000 rw-s 00000000 00:04 65538 /SYSV00000000 (deleted) 8ac0d000-8ac10000 ---p 00000000 00:00 0 8ac10000-8ac5e000 rw-p 00000000 00:00 0 8ac5e000-8ac61000 ---p 00000000 00:00 0 8ac61000-8acaf000 rw-p 00000000 00:00 0 8acaf000-8acb2000 ---p 00000000 00:00 0 8acb2000-8ad00000 rw-p 00000000 00:00 0 8ad00000-8ae00000 rw-p 00000000 00:00 0 8ae01000-8ae02000 r--s 00000000 08:01 7871306 /home/dagarne/.local/share/gvfs-metadata/root 8ae02000-8ae09000 r--s 000fb000 08:01 18747013 /usr/lib/jvm/java-6-openjdk/jre/lib/resources.jar 8ae09000-8ae0b000 r--s 00001000 08:01 18743420 /usr/lib/jvm/java-6-openjdk/jre/lib/ext/dnsns.jar 8ae0b000-8ae16000 r--p 00000000 08:01 20581464 /usr/share/icons/Humanity-Dark/icon-theme.cache 8ae16000-8ae39000 r--p 00000000 08:01 20581465 /usr/share/icons/ubuntu-mono-dark/icon-theme.cache 8ae39000-8ae3c000 rw-s 00000000 00:04 131076 /SYSV00000000 (deleted) 8ae3c000-8ae4a000 r--s 00351000 08:01 18743411 /usr/lib/jvm/java-6-openjdk/jre/lib/charsets.jar 8ae4a000-8ae50000 r--p 00000000 08:01 19007699 /usr/share/locale-langpack/nb/LC_MESSAGES/gdk-pixbuf.mo 8ae50000-8aea2000 r--p 00000000 08:01 19662694 /usr/share/fonts/truetype/ttf-dejavu/DejaVuSansMono.ttf 8aea2000-8aef9000 r--p 00000000 08:01 19662203 /usr/share/fonts/truetype/ubuntu-font-family/Ubuntu-R.ttf 8aef9000-8aefa000 r--s 00000000 08:01 6686733 /var/cache/fontconfig/c05880de57d1f5e948fdfacc138775d9-le32d4.cache-3 8aefa000-8af00000 r--s 00000000 08:01 6684760 /var/cache/fontconfig/945677eb7aeaf62f1d50efc3fb3ec7d8-le32d4.cache-3 8af00000-8affd000 rw-p 00000000 00:00 0 8affd000-8b000000 ---p 00000000 00:00 0 8b000000-8b100000 rw-p 00000000 00:00 0 8b100000-8b1df000 rw-p 00000000 00:00 0 8b1df000-8b200000 ---p 00000000 00:00 0 8b200000-8b201000 r--p 00000000 00:00 0 8b201000-8b204000 r--s 00000000 08:01 6686705 /var/cache/fontconfig/e383d7ea5fbe662a33d9b44caf393297-le32d4.cache-3 8b204000-8b207000 r--s 00000000 08:01 6686703 /var/cache/fontconfig/2cd17615ca594fa2959ae173292e504c-le32d4.cache-3 8b207000-8b208000 r--s 00000000 08:01 6686701 /var/cache/fontconfig/e7071f4a29fa870f4323321c154eba04-le32d4.cache-3 8b208000-8b20c000 r--s 00000000 08:01 6686700 /var/cache/fontconfig/6eb3985aa4124903f6ff08ba781cd364-le32d4.cache-3 8b20c000-8b210000 r--s 00000000 08:01 6686663 /var/cache/fontconfig/a755afe4a08bf5b97852ceb7400b47bc-le32d4.cache-3 8b210000-8b217000 r--s 00000000 08:01 6687109 /var/cache/fontconfig/6d41288fd70b0be22e8c3a91e032eec0-le32d4.cache-3 8b217000-8b222000 r--s 00000000 08:01 6686628 /var/cache/fontconfig/0f34bcd4b6ee430af32735b75db7f02b-le32d4.cache-3 8b222000-8b22f000 r--s 00000000 08:01 6686585 /var/cache/fontconfig/d52a8644073d54c13679302ca1180695-le32d4.cache-3 8b22f000-8b23d000 r--s 00000000 08:01 6688152 /var/cache/fontconfig/865f88548240fee46819705c6468c165-le32d4.cache-3 8b23d000-8b25e000 r--p 00000000 08:01 19007611 /usr/share/locale-langpack/nb/LC_MESSAGES/gtk20-properties.mo 8b25e000-8b261000 ---p 00000000 00:00 0 8b261000-8b2af000 rw-p 00000000 00:00 0 8b2af000-8b2b2000 ---p 00000000 00:00 0 8b2b2000-8b300000 rw-p 00000000 00:00 0 8b300000-8b400000 rw-p 00000000 00:00 0 8b400000-8b401000 r--s 00000000 08:01 7871469 /home/dagarne/.azureus/plugins/azupdater/azupdaterpatcher_1.8.10.jar 8b401000-8b403000 r--s 00000000 08:01 6686571 /var/cache/fontconfig/99e8ed0e538f840c565b6ed5dad60d56-le32d4.cache-3 8b403000-8b417000 r--p 00000000 08:01 19007575 /usr/share/locale-langpack/nb/LC_MESSAGES/glib20.mo 8b417000-8b427000 r--p 00000000 08:01 19007446 /usr/share/locale-langpack/nb/LC_MESSAGES/libc.mo 8b427000-8b42a000 ---p 00000000 00:00 0 8b42a000-8b478000 rw-p 00000000 00:00 0 8b478000-8b47b000 ---p 00000000 00:00 0 8b47b000-8b4c9000 rw-p 00000000 00:00 0 8b4c9000-8b4cc000 ---p 00000000 00:00 0 8b4cc000-8b51a000 rw-p 00000000 00:00 0 8b51a000-8b51d000 ---p 00000000 00:00 0 8b51d000-8b56b000 rw-p 00000000 00:00 0 8b56b000-8b56e000 ---p 00000000 00:00 0 8b56e000-8b5bc000 rw-p 00000000 00:00 0 8b5bc000-8b5bf000 ---p 00000000 00:00 0 8b5bf000-8b60d000 rw-p 00000000 00:00 0 8b60d000-8b610000 ---p 00000000 00:00 0 8b610000-8b65e000 rw-p 00000000 00:00 0 8b65e000-8b661000 ---p 00000000 00:00 0 8b661000-8b6af000 rw-p 00000000 00:00 0 8b6af000-8b6b2000 ---p 00000000 00:00 0 8b6b2000-8b700000 rw-p 00000000 00:00 0 8b700000-8b800000 rw-p 00000000 00:00 0 8b800000-8b801000 r--s 00000000 08:01 6686697 /var/cache/fontconfig/4c73fe0c47614734b17d736dbde7580a-le32d4.cache-3 8b801000-8b802000 r--s 00000000 08:01 6686681 /var/cache/fontconfig/0d8c3b2ac0904cb8a57a757ad11a4a08-le32d4.cache-3 8b802000-8b80a000 r--s 00000000 08:01 6688150 /var/cache/fontconfig/e13b20fdb08344e0e664864cc2ede53d-le32d4.cache-3 8b80a000-8b811000 r--s 00000000 08:01 18614103 /usr/lib/i386-linux-gnu/gconv/gconv-modules.cache 8b811000-8b81f000 r--p 00000000 08:01 19007615 /usr/share/locale-langpack/nb/LC_MESSAGES/gtk20.mo 8b81f000-8b822000 ---p 00000000 00:00 0 8b822000-8b870000 rw-p 00000000 00:00 0 8b870000-8b884000 r--s 0018b000 08:01 19399702 /usr/lib/java/swt-gtk-3.7.jar 8b884000-8b887000 ---p 00000000 00:00 0 8b887000-8b8d5000 rw-p 00000000 00:00 0 8b8d5000-8b9ad000 r--s 00ba1000 08:01 19009153 /usr/share/java/Azureus2.jar 8b9ad000-8b9ae000 ---p 00000000 00:00 0 8b9ae000-8ba2e000 rw-p 00000000 00:00 0 8ba2e000-8ba31000 ---p 00000000 00:00 0 8ba31000-8ba7f000 rw-p 00000000 00:00 0 8ba7f000-8ba82000 ---p 00000000 00:00 0 8ba82000-8bb00000 rw-p 00000000 00:00 0 8bb00000-8bbfe000 rw-p 00000000 00:00 0 8bbfe000-8bc00000 ---p 00000000 00:00 0 8bc00000-8bc03000 r--s 00000000 08:01 6686624 /var/cache/fontconfig/d60319d88cac85ba9e1a07bd06cfbb8c-le32d4.cache-3 8bc03000-8bc06000 r--s 00000000 08:01 6684888 /var/cache/fontconfig/7ef2298fde41cc6eeb7af42e48b7d293-le32d4.cache-3 8bc06000-8bc0a000 r--s 00038000 08:01 18743419 /usr/lib/jvm/java-6-openjdk/jre/lib/ext/sunpkcs11.jar 8bc0a000-8bc0c000 r--s 00013000 08:01 18747008 /usr/lib/jvm/java-6-openjdk/jre/lib/jce.jar 8bc0c000-8bc0f000 r--s 00031000 08:01 18743422 /usr/lib/jvm/java-6-openjdk/jre/lib/ext/sunjce_provider.jar 8bc0f000-8bc17000 r--s 00053000 08:01 19009025 /usr/share/java/log4j-1.2-1.2.15.jar 8bc17000-8bc2b000 r--s 0018b000 08:01 19399702 /usr/lib/java/swt-gtk-3.7.jar 8bc2b000-8bc33000 r--s 00053000 08:01 19009025 /usr/share/java/log4j-1.2-1.2.15.jar 8bc33000-8bc35000 r--s 00007000 08:01 19009020 /usr/share/java/commons-cli-1.2.jar 8bc35000-8bc38000 r--s 0007d000 08:01 18747009 /usr/lib/jvm/java-6-openjdk/jre/lib/jsse.jar 8bc38000-8bc3b000 ---p 00000000 00:00 0 8bc3b000-8bcb9000 rw-p 00000000 00:00 0 8bcb9000-8bcbc000 ---p 00000000 00:00 0 8bcbc000-8bd0a000 rw-p 00000000 00:00 0 8bd0a000-8be3b000 r--p 00bad000 08:01 18619815 /usr/lib/locale/locale-archive 8be3b000-8be7c000 r--p 0090a000 08:01 18619815 /usr/lib/locale/locale-archive 8be7c000-8c07c000 r--p 00000000 08:01 18619815 /usr/lib/locale/locale-archive 8c07c000-8c07f000 ---p 00000000 00:00 0 8c07f000-8c0cd000 rw-p 00000000 00:00 0 8c0cd000-8c0d0000 ---p 00000000 00:00 0 8c0d0000-8c11e000 rw-p 00000000 00:00 0 8c11e000-8c11f000 ---p 00000000 00:00 0 8c11f000-8c1d2000 rw-p 00000000 00:00 0 8c1d2000-8c362000 r--s 037ba000 08:01 18746784 /usr/lib/jvm/java-6-openjdk/jre/lib/rt.jar 8c362000-8c363000 ---p 00000000 00:00 0 8c363000-8c3e3000 rw-p 00000000 00:00 0 8c3e3000-8c3e4000 ---p 00000000 00:00 0 8c3e4000-8c471000 rw-p 00000000 00:00 0 8c471000-8c4a4000 rw-p 00000000 00:00 0 8c4a4000-8c4af000 rw-p 00000000 00:00 0 8c4af000-8c54f000 rw-p 00000000 00:00 0 8c54f000-8c55c000 rw-p 00000000 00:00 0 8c55c000-8c58f000 rw-p 00000000 00:00 0 8c58f000-8c59a000 rw-p 00000000 00:00 0 8c59a000-8c639000 rw-p 00000000 00:00 0 8c639000-8c65d000 rw-p 00000000 00:00 0 8c65d000-8c68f000 rw-p 00000000 00:00 0 8c68f000-8df10000 rw-p 00000000 00:00 0 8df10000-94690000 rw-p 00000000 00:00 0 94690000-95b30000 rw-p 00000000 00:00 0 95b30000-a9bf0000 rw-p 00000000 00:00 0 a9bf0000-ae1f0000 rw-p 00000000 00:00 0 ae1f0000-b4690000 rw-p 00000000 00:00 0 b4690000-b4691000 r--s 00000000 08:01 6686678 /var/cache/fontconfig/6a53c69dea097a2d716e069445527da8-le32d4.cache-3 b4691000-b4692000 r--s 00000000 08:01 6686611 /var/cache/fontconfig/4794a0821666d79190d59a36cb4f44b5-le32d4.cache-3 b4692000-b469b000 rw-p 00000000 00:00 0 b469b000-b4752000 rw-p 00000000 00:00 0 b4752000-b4992000 rwxp 00000000 00:00 0 b4992000-b7752000 rw-p 00000000 00:00 0 b7752000-b7755000 ---p 00000000 00:00 0 b7755000-b77a6000 rw-p 00000000 00:00 0 b77a6000-b77a8000 r--s 00007000 08:01 19009020 /usr/share/java/commons-cli-1.2.jar b77a8000-b77aa000 r--s 0000f000 08:01 18743426 /usr/lib/jvm/java-6-openjdk/jre/lib/ext/pulse-java.jar b77aa000-b77b2000 r--s 00066000 08:01 19005969 /usr/share/java/gnome-java-bridge.jar b77b2000-b77ba000 rw-s 00000000 08:01 23724066 /tmp/hsperfdata_dagarne/2996 b77ba000-b77bb000 rw-p 00000000 00:00 0 b77bb000-b77bc000 ---p 00000000 00:00 0 b77bc000-b77be000 rw-p 00000000 00:00 0 bff86000-bffa7000 rw-p 00000000 00:00 0 [stack] VM Arguments: jvm_args: -Dazureus.install.path=/home/dagarne/.azureus java_command: org.gudy.azureus2.ui.common.Main Launcher Type: SUN_STANDARD Environment Variables: JAVA_HOME=/usr/lib/jvm/java-6-openjdk PATH=/usr/lib/lightdm/lightdm:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games USERNAME=dagarne LD_LIBRARY_PATH=/usr/lib/jvm/java-6-openjdk/jre/lib/i386/server:/usr/lib/jvm/java-6-openjdk/jre/lib/i386:/usr/lib/jvm/java-6-openjdk/jre/../lib/i386 SHELL=/bin/bash DISPLAY=:0 Signal Handlers: SIGSEGV: [libjvm.so+0x66a530], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004 SIGBUS: [libjvm.so+0x66a530], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004 SIGFPE: [libjvm.so+0x52e2c0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004 SIGPIPE: SIG_IGN, sa_mask[0]=0x00001000, sa_flags=0x10000000 SIGXFSZ: [libjvm.so+0x52e2c0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004 SIGILL: [libjvm.so+0x52e2c0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004 SIGUSR1: SIG_DFL, sa_mask[0]=0x00000000, sa_flags=0x00000000 SIGUSR2: [libjvm.so+0x52e150], sa_mask[0]=0x00000000, sa_flags=0x10000004 SIGHUP: [libjvm.so+0x5311f0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004 SIGINT: [libjvm.so+0x5311f0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004 SIGTERM: [libjvm.so+0x5311f0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004 SIGQUIT: [libjvm.so+0x5311f0], sa_mask[0]=0x7ffbfeff, sa_flags=0x10000004 --------------- S Y S T E M --------------- OS:Ubuntu 11.10 (oneiric) uname:Linux 3.0.0-18-generic #31-Ubuntu SMP Tue Mar 27 16:53:46 UTC 2012 i686 libc:glibc 2.13 NPTL 2.13 rlimit: STACK 8192k, CORE 0k, NPROC 15693, NOFILE 4096, AS infinity load average:0,44 0,43 0,24 /proc/meminfo: MemTotal: 2022764 kB MemFree: 795012 kB Buffers: 82008 kB Cached: 618384 kB SwapCached: 0 kB Active: 646860 kB Inactive: 493136 kB Active(anon): 440608 kB Inactive(anon): 170832 kB Active(file): 206252 kB Inactive(file): 322304 kB Unevictable: 16 kB Mlocked: 16 kB HighTotal: 1147868 kB HighFree: 80104 kB LowTotal: 874896 kB LowFree: 714908 kB SwapTotal: 0 kB SwapFree: 0 kB Dirty: 572 kB Writeback: 0 kB AnonPages: 439700 kB Mapped: 127360 kB Shmem: 171780 kB Slab: 46080 kB SReclaimable: 30228 kB SUnreclaim: 15852 kB KernelStack: 3360 kB PageTables: 6920 kB NFS_Unstable: 0 kB Bounce: 0 kB WritebackTmp: 0 kB CommitLimit: 1011380 kB Committed_AS: 2691316 kB VmallocTotal: 122880 kB VmallocUsed: 35624 kB VmallocChunk: 82440 kB HardwareCorrupted: 0 kB AnonHugePages: 0 kB HugePages_Total: 0 HugePages_Free: 0 HugePages_Rsvd: 0 HugePages_Surp: 0 Hugepagesize: 4096 kB DirectMap4k: 16376 kB DirectMap4M: 892928 kB CPU:total 2 (2 cores per cpu, 1 threads per core) family 6 model 15 stepping 13, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3 Memory: 4k page, physical 2022764k(795012k free), swap 0k(0k free) vm_info: OpenJDK Server VM (20.0-b11) for linux-x86 JRE (1.6.0_23-b23), built on Feb 23 2012 06:26:43 by "buildd" with gcc 4.6.1 time: Thu Apr 5 18:17:22 2012 elapsed time: 8 seconds Endret 6. april 2012 av Hårek Lagt storparten av liste i spoiler Lenke til kommentar
