[Løst] Får ikke installert 2tb harddisk(LØST!)
en kompis har fått bygget seg en ny pc , men finner ikke harddisken under " MiN DATAMASKIN"
men den finnes is Bios og under enhetsbehandling..
Å installere driver mislykkes hver gang i windows..
Hva skjer/må gjøres?
Er snakk om en Seagate 2tb 3,5" disk (win7 64)
Endret av Rambo82
http://www.ehow.com/how_4918155_initialize-new-hard-drive.html
Instructions
1
Press the "Windows" key and the "R" key on your keyboard simultaneously to launch the Run dialog window. Type "compmgmt.msc" into the text box and hit "Enter" to open the Computer Management window.
2
Click "Disk Management" under Storage on the left side of the screen.
3
Locate the drive in the Disk Management screen. The bar at the top of it should appear black to indicate that it is not formatted.
4
Right-click the left box of the drive, where the label is, and click "Initialize Disk."
5
Right-click the right box of the drive and click "Create New Simple Volume."
