frankhaugen Skrevet 30. mars 2012 Del Skrevet 30. mars 2012 (endret) Jeg har skrevet en funksjon for å lage 200 linjer i et canvas objekt, objektet skrevet manuelt inn i XAML er ikke et problem men når det jeg skal gjøre dette i kode kresjer compileren, (VS2010), og gir meg feilmelding. vennligst se på koden å feilmeldingen og fortell meg hva jeg gjør galt: public void createGrid() { int Ypositions = -1000; //int Xpositions = -1000; while (Ypositions &--#60; 1001) { // Create a white Brush SolidColorBrush whiteBrush = new SolidColorBrush(); whiteBrush.Color = Colors.White; Line gridLine = new Line(); gridLine.X1 = 1; gridLine.Y1 = 1; gridLine.X2 = 1; gridLine.Y2 = 2000; gridLine.SetValue(Canvas.LeftProperty, 1); gridLine.SetValue(Canvas.TopProperty, Ypositions); gridLine.Stroke = whiteBrush; gridLine.StrokeThickness = 1; gridLine.SetValue(Panel.ZIndexProperty, -900); Ypositions +=10; starfield.Children.Add(gridLine); } } Feilmelding: System.Windows.Markup.XamlParseException was unhandled Message='The invocation of the constructor on type 'WpfApplication1.MainWindow' that matches the specified binding constraints threw an exception.' Line number '3' and line position '9'. Source=PresentationFramework LineNumber=3 LinePosition=9 StackTrace: at System.Windows.Markup.XamlReader.RewrapException(Exception e, IXamlLineInfo lineInfo, Uri baseUri) at System.Windows.Markup.WpfXamlLoader.Load(XamlReader xamlReader, IXamlObjectWriterFactory writerFactory, Boolean skipJournaledProperties, Object rootObject, XamlObjectWriterSettings settings, Uri baseUri) at System.Windows.Markup.WpfXamlLoader.LoadBaml(XamlReader xamlReader, Boolean skipJournaledProperties, Object rootObject, XamlAccessLevel accessLevel, Uri baseUri) at System.Windows.Markup.XamlReader.LoadBaml(Stream stream, ParserContext parserContext, Object parent, Boolean closeStream) at System.Windows.Application.LoadBamlStreamWithSyncInfo(Stream stream, ParserContext pc) at System.Windows.Application.LoadComponent(Uri resourceLocator, Boolean bSkipJournaledProperties) at System.Windows.Application.DoStartup() at System.Windows.Application.&--#60;.ctor&--#62;b__1(Object unused) at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs) at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler) at System.Windows.Threading.DispatcherOperation.InvokeImpl() at System.Windows.Threading.DispatcherOperation.InvokeInSecurityContext(Object state) at System.Threading.ExecutionContext.runTryCode(Object userData) at System.Runtime.CompilerServices.RuntimeHelpers.ExecuteCodeWithGuaranteedCleanup(TryCode code, CleanupCode backoutCode, Object userData) at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean ignoreSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Windows.Threading.DispatcherOperation.Invoke() at System.Windows.Threading.Dispatcher.ProcessQueue() at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled) at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o) at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs) at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler) at System.Windows.Threading.Dispatcher.InvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs) at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam) at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg) at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame) at System.Windows.Threading.Dispatcher.PushFrame(DispatcherFrame frame) at System.Windows.Application.RunDispatcher(Object ignore) at System.Windows.Application.RunInternal(Window window) at System.Windows.Application.Run(Window window) at System.Windows.Application.Run() at WpfApplication1.App.Main() in C:\Users\Frank Haugen\Documents\Visual Studio 2010\Projects\WpfApplication1\WpfApplication1\obj\x86\Debug\App.g.cs:line 0 at System.AppDomain._nExecuteAssembly(RuntimeAssembly assembly, String[] args) at System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[] args) at Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssembly() at System.Threading.ThreadHelper.ThreadStart_Context(Object state) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean ignoreSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Threading.ThreadHelper.ThreadStart() InnerException: System.ArgumentException Message='0' is not a valid value for property 'Left'. Source=WindowsBase StackTrace: at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType, Boolean isInternal) at System.Windows.DependencyObject.SetValue(DependencyProperty dp, Object value) at WpfApplication1.MainWindow.createGrid() in C:\Users\Frank Haugen\Documents\Visual Studio 2010\Projects\WpfApplication1\WpfApplication1\MainWindow.xaml.cs:line 107 at WpfApplication1.MainWindow..ctor() in C:\Users\Frank Haugen\Documents\Visual Studio 2010\Projects\WpfApplication1\WpfApplication1\MainWindow.xaml.cs:line 27 InnerException: takk for all hjelp!!! -frank Endret 30. mars 2012 av frankhaugen Lenke til kommentar
GeirGrusom Skrevet 31. mars 2012 Del Skrevet 31. mars 2012 Message='0' is not a valid value for property 'Left'. Lenke til kommentar
frankhaugen Skrevet 1. april 2012 Forfatter Del Skrevet 1. april 2012 Message='0' is not a valid value for property 'Left'. Takk, jeg fant dog en bedre måte å gjøre dette på -frank PS: Det er visst bare du GeirGrusom som er til noe hjelp i C# underforumet, og du gjør en god jobb, kansje du burde blir moderator/forumveileder XD Lenke til kommentar
