hei, jeg lurer på hva er forskjell mellom ddr3 og ddr5 skjermkort :)?
hva er forskjell mellom ddr3 og ddr5 skjermkort? er det hastigheten :) driver med et skole prosjekt så skulle ha hat svar fort som mulig :)
GDDR5 supports higher data rates (five times that of GDDR3 and four times that of GDDR4), which enables more bandwidth over a narrower memory interface, meaning better performance from a smaller, more cost effective chip. It also means gamers will have the potential to play at higher resolutions and image quality settings, with improved load times.
http://www.tomshardware.com/news/AMD-DDR5,5443.html
Utrolig hvilke svar google spytter ut om du bare spør pent.. ;)
http://www.tomshardw...-DDR5,5443.html
tusen takk!!! :)
