Høy FPS, hakker uansett
Hvis du åpner opp resource monitor og går på "disk"-fanen, er det mye IO som foregår på skrivebordet (mer enn 1MB/s)?
Det varierer. Det hender at den havner over 1 mb/s
Her ser du et bilde før og etter at jeg har avsluttet Dirt 3.
Endret av Crouser
Vet du om OS-disken din er i god stand?
SMART-verdier?
Hvordan blir resultatet i HDTune?
HD Tune Pro: SAMSUNG HD501LJ Benchmark
Test capacity: full
Read transfer rate
Transfer Rate Minimum : 20.2 MB/s
Transfer Rate Maximum : 82.8 MB/s
Transfer Rate Average : 59.2 MB/s
Access Time : 14.7 ms
Burst Rate : 152.6 MB/s
CPU Usage : 1.3%
HD Tune Pro: SAMSUNG HD501LJ Health
ID Current Worst Threshold Data Status
(01) Raw Read Error Rate 100 100 51 0 ok
(03) Spin Up Time 100 100 15 7360 ok
(04) Start/Stop Count 99 99 0 1377 ok
(05) Reallocated Sector Count 253 253 10 0 ok
(07) Seek Error Rate 253 253 51 0 ok
(08) Seek Time Performance 253 253 15 0 ok
(09) Power On Hours Count 100 100 0 10421 ok
(0A) Spin Retry Count 253 253 51 0 ok
(0B) Calibration Retry Count 253 100 0 0 ok
(0C) Power Cycle Count 100 100 0 926 ok
(0D) Soft Read Error Rate 100 100 0 18559420 ok
(BB) Reported Uncorrectable Errors 91 91 0 10 ok
(BC) Command Timeout 100 100 0 4 ok
(BE) Airflow Temperature 84 72 0 16 ok
(C2) Temperature 190 154 0 16 ok
(C3) Hardware ECC Recovered 100 100 0 18559420 ok
(C4) Reallocated Event Count 253 253 0 0 ok
(C5) Current Pending Sector 253 100 0 0 ok
(C6) Offline Uncorrectable 253 253 0 0 ok
(C7) Ultra DMA CRC Error Count 200 200 0 0 ok
(C8) Write Error Rate 100 100 0 0 ok
(C9) Soft Read Error Rate 100 100 0 0 ok
(CA) Data Address Marker errors 253 253 0 0 ok
Health Status : ok
HD Tune Pro: SAMSUNG HD501LJ Error Scan
Scanned data : 499 gB
Damaged Blocks : 0.0 %
Elapsed Time : 2:19:26
HD Tune Pro: SAMSUNG HD501LJ Information
Firmware version : CR100-12
Serial number : S0MUJFWQ295909
Capacity : 500.1 gB (465.8 GB)
Buffer size : 16384 KB
Sector size : 512 bytes
Standard : ATA8-ACS - SATA II
Supported mode : UDMA Mode 6
Current mode : UDMA Mode 5
Avergae speed : 47 MB/s
Rotation speed : -
S.M.A.R.T : yes
48-bit Address : yes
Read Look-Ahead : yes
Write Cache : yes
Host Protected Area : yes
Device Configuration Overlay : yes
Firmware Upgradable : yes
Automatic Acoustic Management: yes
Power Management : yes
Advanced Power Management : no
Interface Power Management : yes
Power-up in Standby : no
Security Mode : yes
SCT Tables : yes
Native Command Queuing (NCQ) : yes
Trim : no
Volume : (C:)
Capacity : 476937 MB
Free : 391879 MB
Usage : 18%
File system : NTFS
Serial : 0CA6-A115
Alignment : 1 MB
Som du ser tok jeg en benchmark, health og error scan. Etter hva jeg selv kan se så skal det vel ikke være noen problemer med harddisken? Kan ta de resterende testene også, dersom disse ikke viser nok eller annen viktig info.
Skudd i blinde, men med dette verktøyet kan du sjekke om det er noen drivere som ikke oppfører seg:
http://www.thesycon....ncy_check.shtml
Har testet, denne teksten står i nederste rute: This machine should be able to handle real-time streaming of audio and/or video data without drop-outs.
På venstre side av ruten står det:
Test interval: 1000 us
Current latency: 112 us
Absolute maximum: 216 us
(Kan laste opp et bilde om ønskelig.)
Så her ser det jo også ut til at alt er bra. Eller hva?
Endret av Crouser
Ingen problemer med disken nei, da er den teorien ute...
Jeg sitter her og klør meg i hodet, for jeg har ingen anelse om hva som kan forårsake dette når du ikke kjører Vsync eller SLI.
Samme her. Et problem der det kan være forårsaket av så mye, egentlig. Tror faktisk det å teste en ny skjerm, beregnet for pc kunne vært et forsøk. For øyeblikket sitter jeg med en 42" Toshiba av635dn. Og til annen testskjerm har jeg bare et noe gamlere LG TV der samme problemet oppstår.
Kan det være et forsøk å prøve å kjøre stresstest for CPU, GPU og i tillegg en memtest for RAM? Har testet RAM'men en gang før, for ikke så veldig lenge siden, men bare en kort stund.
Isåfall hvilke programmer anbefaler du til CPU og GPU testing med logg?
Du kan prøve OCCT for grafikkort
IntelBurnTest, 10 runder, 2GB RAM.
memtest86+ fra USB.
Hvilke settings vil du at jeg skal bruke i OCCT for skjermkort? Skal det bare stå på standard, slik det står når jeg åpner programmet?
Edit:
Prøvde med standard innstillinger og egendefinerte, men testene stopper alle etter 3 sekunder: I "meldingsfeltet" kommer det opp "CPUTIN over maximum value ! Value reached: 127,5, Max Value: 85
Endret av Crouser
Du får prøve å finne en override/deaktivering av temperaturovervåkning.
-127 er en standardverdi når det er målefeil.
Kan det slå's av i BIOS?
Nei, tror du må leke litt i innstillingene til OCCT her.
http://imageshack.us/g/205/2012042013h383vcc.png/
Da har jeg testet skjermkortet i OCCT i litt over en halv time. Resultatene kan du se gjennom linken. Utifra hva jeg selv kan se så skal det vel ikke være noen problemer? Eller må jeg kanskje kjøre testen enda lengre for bedre resultat?
Har også testet RAM i memtest helt til testen sa seg ferdig, 0 errors.
Endret av Crouser
Prøv 10 minutter med error test, shader complexity 8
Der har du bilder fra error test. Ifølge testen, 0 errors.
(Fikk ikke til å legge i spoiler..)
For å finne ut om det er skjermen det er problemer/feil med, kan jeg ikke prøve å recorde via Fraps mens jeg spiller? For da skal vel igrunn videoen være helt fin uten små-hakk/lag?
Den skal det ja?
Den skal det ja?
Ikke sikker, rett og slett. Men skal prøve, så får jeg da se..
Dersom jeg ikke ser noen lag i videoen etterpå så må det jo være skjermen. Leste at det kunne være støv i HDMI inngangen som lå å forstyrra på skjermbildet, hva tror du om det?
Endret av Crouser
