fat32 til ntfs uten formatering??
Jeg vill gjør min disk om til ntfs fra fat32, har prøvd denne comandoen i cmd: convert C: /fs:ntfs
Men det gikk ikke :grumpy:
Du har skrevet rett komando, restart å prøv igjen data er ofte slik at det ikke alltid funker slik det skal..
Sitat fra en Microsoft side
Converting FAT volumes to NTFS
To convert a volume to NTFS from the command prompt
Open Command Prompt. Click Start, point to All Programs, point to Accessories, and then click Command Prompt.
In the command prompt window, type: convert drive_letter: /fs:ntfs
For example, typing convert D: /fs:ntfs would format drive D: with the ntfs format. You can convert FAT or FAT32 volumes to NTFS with this command.
Important Once you convert a drive or partition to NTFS, you cannot simply convert it back to FAT or FAT32. You will need to reformat the drive or partition which will erase all data, including programs and personal files, on the partition.
