olegunnaro Skrevet 15. mars 2012 Del Skrevet 15. mars 2012 (endret) Digital Bolex ble lansert på SXSW i går: The New Digital Bolex Once upon a time, motion picture cameras that created high-quality images were affordable for all filmmakers on any budget. Consumer 8mm and 16mm cameras like the original Bolex shot footage that could be projected on any movie theater screen. In today’s digital market, ‘affordable’ and ‘consumer’ have become synonymous with ‘low-quality’ — but it doesn’t have to be that way. Introducing the Digital Bolex D16, the first digital cinema camera to shoot RAW at a price anyone can afford. Specs Resolution 2048 x 1152 (Super 16mm mode) + 1920 x 1080 pixels (16mm mode) Format Adobe Cinema DNG, TIFF, JPEG Image sequences Colour depth 12 bit – 4:4:4 File size 2 to 3 MB per frame in RAW Sensor Kodak CCD: 12.85 mm (H) x 9.64 mm (V) – Similar to Super 16mm Pixel Size 5.5 micron (compared to the 4.3 micron size of many DSLRs) Framerate up to 32 fps at 2K, 60fps at 720p, 90 fps at 480p Sound Balanced, 2 channel, 16 bit, 48 kHz via XLR Viewfinder 320×240, 2.4” diagonal, with Focus Assist Video out 640 x 480 B&W via ⅛” video jack (HD-SDI avail in separate unit) Ports ⅛” video, headphone, USB 3.0, Audio XLR (2), 4-PIN XLR Data Storage Dual CF card slots, SSD (buffer drive) Power Internal battery, 12V External via 4 pin XLR port Body Milled steel and hard plastic Size (body) Approximately 5”H (without pistol grip) by 4”W by 8”D Size (grip) 5”H by 2”W by 5”D Lens mount C-mount comes standard; Optional PL, EF, B4 Weight 5lbs ISO Options 100, 200, 400 Also in the box pistol grip, USB 3.0 cable, internal battery, 4 pin XLR Battery, cable, video cable, transcoder/raw conversion software http://www.digitalbolex.com/products/ Kjenner at jeg nesten er mer gira på denne enn Canon og Nikons nyeste! Kan være bivirkninger av litt for mye leking med RAW->TIFF->ProRes-workflow for timelapses though... Høyoppløselig RAW-video er artig! Prosjektet er på Kickstarter - og er allerede nesten tredobbelt funda med 100 kamera forhåndssolgt: Endret 15. mars 2012 av olegunnaro Lenke til kommentar
