7970's Oppløsning
Vil bare oppklare en sak ettersom det er mye feil ut og går (I tillegg for å utnytte PCI 3.0 fult ut, må cpu en også støtte denne standaren.):
Cutting-edge integrated display support
DisplayPort 1.2
Max resolution: 4096x2160 per display
Multi-Stream Transport
21.6 Gbps bandwidth
High bit-rate audio
2560x1600p60 Stereoscopic 3D
Quad HD/4k video support
HDMI® (With 4K, 3D, Deep Color and x.v.Color™)
1080p60 Stereoscopic 3D
Dual-link DVI with HDCP
Max resolution: 2560x1600
VGA
Max resolution: 2048x1536
Integrated HD audio controller
Output protected high bit rate 7.1 channel surround sound over HDMI with no additional cables required
Supports AC-3, AAC, Dolby TrueHD and DTS Master Audio formats
