Systemkrav til Quake 1 (GL Quake) og Quake 2
Tar du en kikk på readme filene finner du dette:
Quake System Requirements
IBM PC and Compatibles
Pentium processor HIGHLY recommended, 486DX4/100 Minimally required
VGA Compatible Display or better
8MB RAM minimum, 16MB recommended (16 MB required for running under Win95)
CD-ROM drive Required
MS-DOS 5.0 or better or Windows 95 (does NOT run under Windows NT)
Hard Drive (30MB for Shareware, 80 MB for Registered)
Quake II General Requirements
* English Language Version of Windows 95 or NT 4.0 with 100% compatible
computer
system
* Pentium 90 MHz processor (133 MHz recommended)
* Memory:
Win 95: - 16 MB RAM Required (24 MB recommended)
Win NT 4.0 - 24 MB RAM Required
* 100% Sound Blaster-compatible sound card
* Joystick and mouse-supported (3-button mouse recommended)
* Supports LAN and Internet play using the TCP/IP protocol
Minimum Install Additional Requirements (Play from CD-ROM)
* Quad-Speed CD-ROM drive (600k/sec. sustained transfer rate)
* Hard disk drive with at least 25 MB of uncompressed space available
Normal Install Additional Requirements (Play from Hard Disk)
* Hard disk drive with at least 250 MB of uncompressed space available
Maximum Install Additional Requirements (Play from Hard Disk)
* Dual-Speed CD-ROM drive (300k/sec. sustained transfer rate)
* Hard disk drive with at least 400 MB of uncompressed space available
GLQuake II Additional Requirements
* 24 MB RAM for all operating systems
* GLQuake II supports some OpenGL 3D accelerator cards. Consult your
hardware manufacturer to determine compatibility. Latest version of Glide
(2.4x) drivers can be found at www.3dfx.com.
