Ny Logitech-mus, gammelt Logitech-tastatur.
Hei. Denne er på Engelsk. Eg har skrevet så mykje på eit dårleg tastatur. til Logitech-support at eg blir gal. Kan oversette det om det er mot reglementet. :) Logitech er lite hjelpsomme..
Her er saken;
Hello
I just bought the new Logitech MX Performance Mouse. Very satisfied with this product from use on other computers.
From before i used an MX1000 with a DiNovo wireless keyboard. Both working on the old bluetooth stick. 2.0 EDR
These worked perfectly, and both registered in Set-point. But with this new bluetooth-stick, the "Infinity Dongle" and with updated Set-point software. Set-point now recognices my new mouse, but not my old keyboard.
If I unplug the infinity-dongle and power down my mouse, it does not work with set-point either. The old version of set-point that i had, did not recognice my new mouse.
The mouse and keyboard worked together fine when i plugged in the infinity-dongle, and did not update set-point. I could use the basic functions, though I could not configure my new mouse as it did not show up in set-point.'
The mouse can not connect with the old bluetooth stick, the keyboard can not connect to the new infinity stick.
Set-point seems to be able to use two different bluetooth sticks at the same time, eventhough Windows 7 64bit had no problems doing that.
I can not afford a new keyboard, so Im wondering. Is there a way for set-point to be able to recognice both devices through both bluetooth-devices, or am i forced to return the mouse? I hope somebody can help me with this issue.
I have a fully updated windows 7 64bit OS.
Logitech MX performance mouse
Logitech DiNovo bluetooth keyboard.
