Problemer med å installere Photoshop CS 5.1
Heisann. Får ikke installert Adobe Photoshop CS 5.1. Har prøvd uttalige ganger, men får den samme feilen.
Hva kan være feil?
Error dritten jeg får opp:
Exit Code: 6
-------------------------------------- Summary --------------------------------------
- 0 fatal error(s), 67 error(s), 62 warning(s)
WARNING: DW031: Payload:{3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer 6.0.0.0 has been updated and has been selected for repair. The patch {A189C479-C7CD-4E08-8CCF-D999B68C0C71} Camera Profiles Installer_6.3_AdobeCameraRawProfile6.0All 6.3.0.0 will be uninstalled now.
----------- Payload: {08D2E121-7F6A-43EB-97FD-629B44903403} Microsoft_VC90_CRT_x86 1.0.0.0 -----------
ERROR: Error 1935.An error occurred during the installation of assembly component {43CC1B37-B20C-3EBC-9C04-F809989E4FD3}. HRESULT: 0x80073712.
ERROR: Install MSI payload failed with error: 1603 - Alvorlig feil under installasjonen.
MSI Error message: Error 1935.An error occurred during the installation of assembly component {43CC1B37-B20C-3EBC-9C04-F809989E4FD3}. HRESULT: 0x80073712.
WARNING: DW036: Payload cannot be installed due to dependent operation failure
----------- Payload: {D1B83970-7269-48BE-8B0E-5120D9327E52} Adobe Player for Embedding 3.1 3.101.0.0 -----------
----------- Payload: {E5DD149F-8370-48F9-A32C-2E3DC776CFFB} AdobeJRE 1.6.0.0 -----------
----------- Payload: {A189C479-C7CD-4E08-8CCF-D999B68C0C71} Camera Profiles Installer_6.3_AdobeCameraRawProfile6.0All 6.3.0.0 -----------
----------- Payload: {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26} Microsoft_VC90_CRT_x86_x64 1.0.0.0 -----------
ERROR: Error 1935.An error occurred during the installation of assembly component {9718BF1D-6A9F-3406-A992-630F7EF2F164}. HRESULT: 0x80073712.
MSI Error message: Error 1935.An error occurred during the installation of assembly component {9718BF1D-6A9F-3406-A992-630F7EF2F164}. HRESULT: 0x80073712.
----------- Payload: {7EABC54B-02C3-4DA1-9EB4-974CE7414066} AdobeHelp 3.4.0.0 -----------
----------- Payload: {9158FF30-78D7-40EF-B83E-451AC5334640} Adobe Photoshop CS5.1 Driver 12.1.0.0 -----------
ERROR: DW050: The following payload errors were found during install:
ERROR: DW050: - Adobe ExtendScript Toolkit CS5.5: Install failed
ERROR: DW050: - Microsoft_VC90_ATL_x86: Install failed
ERROR: DW050: - Adobe Linguistics CS5 x64: Install failed
ERROR: DW050: - Microsoft_VC90_CRT_x86: Install failed
ERROR: DW050: - Adobe Photoshop CS5.1 Core: Failed due to Language Pack installation failure
ERROR: DW050: - Microsoft_VC80_ATL_x86: Install failed
ERROR: DW050: - Adobe Photoshop CS5.1 Core_x64: Failed due to Language Pack installation failure
ERROR: DW050: - Recommended Common Fonts Installation x64: Install failed
ERROR: DW050: - AdobePDFL x64 CS5: Install failed
ERROR: DW050: - Microsoft_VC80_MFCLOC_x86_x64: Install failed
ERROR: DW050: - Adobe Photoshop CS5.1 International English Language Pack_AdobePhotoshop12-en_GB: Install failed
ERROR: DW050: - Adobe XMP Panels CS5: Install failed
ERROR: DW050: - Photoshop Camera Raw (64 bit)_6.3_AdobeCameraRaw6.0All-x64: Install failed
ERROR: DW050: - Photoshop Camera Raw: Install failed
ERROR: DW050: - Adobe Extension Manager CS5.5: Install failed
ERROR: DW050: - Adobe XMP Panels CS5_3.1_AdobeXMPPanelsAll: Install failed
ERROR: DW050: - AdobeColorCommonSetRGB: Install failed
ERROR: DW050: - Microsoft_VC80_CRT_x86_x64: Install failed
ERROR: DW050: - AdobeColorPhotoshop CS5.5: Install failed
ERROR: DW050: - Adobe Device Central CS5.5: Failed due to Language Pack installation failure
ERROR: DW050: - Adobe Mini Bridge CS5.1: Install failed
ERROR: DW050: - Adobe Photoshop CS5.1 International English Language Pack_x64_AdobePhotoshop12-en_GB_x64: Install failed
ERROR: DW050: - AdobeColorCommonSetCMYK: Install failed
ERROR: DW050: - Photoshop Camera Raw (64 bit): Install failed
ERROR: DW050: - Microsoft_VC90_MFC_x86: Install failed
ERROR: DW050: - Adobe Linguistics CS5: Install failed
ERROR: DW050: - PDF Settings CS5: Install failed
ERROR: DW050: - AdobeTypeSupport CS5: Install failed
ERROR: DW050: - Adobe CSXS Infrastructure CS5.5: Install failed
ERROR: DW050: - AdobeColorEU CS5.5: Install failed
ERROR: DW050: - Required Common Fonts Installation x64: Install failed
ERROR: DW050: - Microsoft_VC90_ATL_x86_x64: Install failed
ERROR: DW050: - Microsoft_VC90_MFCLOC_x86_x64: Install failed
ERROR: DW050: - Microsoft_VC80_ATL_x86_x64: Install failed
ERROR: DW050: - Microsoft_VC90_CRT_x86_x64: Install failed
ERROR: DW050: - Microsoft_VC80_CRT_x86: Install failed
ERROR: DW050: - Adobe Device Central CS5.5_DeviceCentral3.5LP-en_GB: Install failed
ERROR: DW050: - AdobeCMaps x64 CS5: Install failed
ERROR: DW050: - AdobeTypeSupport x64 CS5: Install failed
ERROR: DW050: - Microsoft_VC90_MFC_x86_x64: Install failed
ERROR: DW050: - AdobeColorJA CS5.5: Install failed
ERROR: DW050: - AdobeOutputModule: Install failed
ERROR: DW050: - Adobe WinSoft Linguistics Plugin CS5: Install failed
ERROR: DW050: - Adobe WinSoft Linguistics Plugin CS5 x64: Install failed
ERROR: DW050: - Microsoft_VC90_MFCLOC_x86: Install failed
ERROR: DW050: - AdobePDFL CS5: Install failed
ERROR: DW050: - AdobeCMaps CS5: Install failed
ERROR: DW050: - Adobe CSXS Extensions CS5.5: Install failed
ERROR: DW050: - Microsoft_VC80_MFC_x86_x64: Install failed
ERROR: DW050: - Adobe ReviewPanel CS5.5: Install failed
ERROR: DW050: - Required Common Fonts Installation: Install failed
ERROR: DW050: - Adobe Player for Embedding x64 3.1: Install failed
ERROR: DW050: - Adobe SwitchBoard 2.0: Install failed
ERROR: DW050: - Microsoft_VC80_MFC_x86: Install failed
ERROR: DW050: - Microsoft_VC80_MFCLOC_x86: Install failed
ERROR: DW050: - Recommended Common Fonts Installation: Install failed
ERROR: DW050: - AdobeColorNA CS5.5: Install failed
ERROR: DW050: - AdobeColorVideoProfilesCS CS5.5: Install failed
ERROR: DW050: - Suite Shared Configuration CS5.5: Install failed
ERROR: DW050: - Adobe Bridge CS5.1: Install failed
ERROR: DW050: - Adobe Photoshop CS5.1 Support: Install failed
ERROR: DW050: - Photoshop Camera Raw_6.3_AdobeCameraRaw6.0All: Install failed
Satt først omkring 20 minutter og diskuterte med en fra Support på live chat, og når vi først kom til remote control kunne han ikke gå videre fordi windows ikke var på Engelsk, selv om jeg tilbydde meg å oversette osv. Han videresendte meg til norsk telefonhjelp, og han konkluderte med at det var best om jeg gikk gjennom feilsøking steg for steg fra nettsiden deres. Gjorde det, men det hjalp ikke.
Så fuck it!
Hvis du har lastet den ned fra Adobe, prøv å laste den ned igjen. Det er ofte småfeil i nedlastingen som gjør at den ikke vil installere. Mang har dette problemet og funnet at det fikser seg å laste ned om igjen til en ny folder på skrivebordet.
Har gjort det. Omrking 6-7 ganger.
  • 3 uker senere...
