trenger hjelp
Hei jeg kan ikke så mye om pc men jeg lurer på om dette er et bra kjøp
Fractal Design Define R3 Black Pearl
Lian Li 750W Silent Force strømforsyning
ASUS P8Z68-V PRO/GEN3, Socket-1155
Intel Core i7 2600 Quad Prosessor
Kingston HyperX 16GB 1600MHz DDR3
OCZ 120 GB SSD 2,5" Vertex 3
Seagate Barracuda® Green 2TB, 3,5"
ASUS GeForce GTX 560Ti 1GB PhysX CUDA
Sony DVD Recorder 24x SATA
Microsoft Windows 7 Home Premium 64bit
pris 11 487
http://www.netshop.no/Avdelinger/Datautstyr/Kabinetter/Midi-tower/Fractal-Design/Fractal-Design-Define-R3-Black-Pearl-USB3,-ATX,-mITX-m-st%C3%B8ydemp-49773-p0000176292.aspx
http://www.netshop.no/Avdelinger/Datautstyr/Str%C3%B8mforsyninger/ATX/700W-999W/Lian-Li-750W-Silent-Force-str%C3%B8mforsyning-Avtagbare-kabler,-5-%C3%A5rs-garanti-48314-p0000169788.aspx
http://www.netshop.no/Avdelinger/Datautstyr/Hovedkort/Intel-Socket-1155/ASUS/ASUS-P8Z68-V-PRO-GEN3,-Socket-1155-ATX,-Z68,-DDR3,-3xPCIe20x16,-CFX-and-SLI-51464-p0000181398.aspx
http://www.netshop.no/Avdelinger/Datautstyr/Prosessor/CPU/Intel-Socket-1155/Intel/Intel-Core-i7-2600-Quad-Prosessor-34GHz,-8MB,-BOXED-Sandybridge,-1155-45540-p0000159450.aspx
http://www.netshop.no/Avdelinger/Datautstyr/Minne/DDR3-1600Mhz/Kingston/Kingston-HyperX-16GB-1600MHz-DDR3-kit-4-stk-4-GB,-Non-ECC-CL9-46412-p0000162696.aspx
http://www.netshop.no/Avdelinger/Datautstyr/Harddisk/SSD/OCZ/OCZ-120-GB-SSD-2,5-Vertex-3-SATA-III,-Read-Write-550-500MB-sec-46497-p0000162984.aspx
http://www.netshop.no/Avdelinger/Datautstyr/Harddisk/3,5--S-ATA-%28stasjon%C3%A6r%29/Seagate/Seagate-Barracuda-Green-2TB,-3,5-SATA-6Gb-s,-SATA-30,-64MB,-5900-RPM-46357-p0000162518.aspx
http://www.netshop.no/Avdelinger/Datautstyr/Skjermkort/PCI-Express/ASUS/ASUS-GeForce-GTX-560Ti-1GB-PhysX-CUDA-PCI-Express-20,DirectCU-II-TOP,-GDDR5-47768-p0000167639.aspx
http://www.netshop.no/Avdelinger/Datautstyr/CD/DVD/Blu-ray/DVD-brenner/Sony/Sony-DVD-Recorder-24x-SATA-Internal-Sort-Bulk-38852-p0000133114.aspx
http://www.netshop.no/Avdelinger/Datautstyr/Programvare/Operativssytem/Microsoft/Microsoft-Windows-7-Home-Premium-64bit-Norsk,-OEM,64bit-DVD-m-SP1-46979-p0000164776.aspx
Hva skal du bruke pcen til?
Hvis det er til gaming så bytt til Intel Core i5 2500(2500K hvis du har tenkt til å overklokke). 16gb RAM er overkill, du trenger bare 8gb.
Dette er det jeg kan hjelpe med :)
ja det er til gaming ok 8gb
