feil melding i nero
Etter et raskt søk fant jeg dette som kanskje kan hjelpe:
Fejlmeddelelsen „Fejl i strømkalibreringsområdet“/ “Power Calibration Failure“
Din strømforsyning er for lille, vi anbefaler at du bruger en 250 til 300W strømforsyning.
What does "Power calibration failure" mean?
Older writers do not recognise the CD-R type (maybe because it is too new) and attempts to set its laser in the area designated. If it then does not find an appropriate setting, perhaps because it cannot set its laser low enough for the High Speed CD-R, it breaks off. Updating the firmware will generally help. Normally, the CD-R can still be used afterwards or on other writers.
