perroga Skrevet 13. februar 2012 Del Skrevet 13. februar 2012 Har funnet VBA-kode som plasserer snarvei til excel-fil på skrivebordet. Den virker utmerket i excel 2007 og 2010! Skulle gjerne fått justert VBA-koden, slik at den kan lage snarvei til mappen. Håper at noen kan hjelpe: Håper at en av dere som forstår kode, kan bearbeide denne, slik at den lager snarvei til mappen.. Excel VBA: Create a Custom Desktop Shortcut Option Explicit Sub CreateDesktopShortcut() ' ================================================================= ' Create a custom icon shortcut on the users desktop ' ================================================================= ' Msgbox string variables Dim szMsg As String Dim szStyle As String Dim szTitle As String ' Change here for the icon's name Const szIconName As String = "\cvg.ico" ' Constant string values, you can replace "Desktop" ' with any Special Folders name to create the shortcut there Const szlocation As String = "Desktop" Const szLinkExt As String = ".lnk" ' Object variables Dim oWsh As Object Dim oShortcut As Object ' String variables Dim szSep As String Dim szBookName As String Dim szBookFullName As String Dim szPath As String Dim szDesktopPath As String Dim szShortcut As String ' Initialize variables szSep = Application.PathSeparator szBookName = szSep & ThisWorkbook.Name szBookFullName = ThisWorkbook.FullName szPath = ThisWorkbook.Path On Error Goto ErrHandle ' The WScript.Shell object provides functions to read system ' information and environment variables, work with the registry ' and manage shortcuts Set oWsh = CreateObject("WScript.Shell") szDesktopPath = oWsh.SpecialFolders(szlocation) ' Get the path where the shortcut will be located szShortcut = szDesktopPath & szBookName & szLinkExt ' Make it happen Set oShortcut = oWsh.CreateShortCut(szShortcut) ' Link it to this file With oShortcut .TargetPath = szBookFullName .IconLocation = szPath & szIconName .Save End With ' Explicitly clear memory Set oWsh = Nothing Set oShortcut = Nothing ' Let the user know it was created ok szMsg = "Shortcut was created successfully" szStyle = 0 szTitle = "Success!" MsgBox szMsg, szStyle, szTitle Exit Sub ' or if it wasn't ErrHandle: szMsg = "Shortcut could not be created" szStyle = 48 szTitle = "Error!" MsgBox szMsg, szStyle, szTitle End Sub Lenke til kommentar
perroga Skrevet 16. februar 2012 Forfatter Del Skrevet 16. februar 2012 Prøvde meg fram og fant løsningen. Har funnet VBA-kode som plasserer snarvei til excel-fil på skrivebordet. Den virker utmerket i excel 2007 og 2010! Skulle gjerne fått justert VBA-koden, slik at den kan lage snarvei til mappen. Håper at noen kan hjelpe: Håper at en av dere som forstår kode, kan bearbeide denne, slik at den lager snarvei til mappen.. Excel VBA: Create a Custom Desktop Shortcut Option Explicit Sub CreateDesktopShortcut() ' ================================================================= ' Create a custom icon shortcut on the users desktop ' ================================================================= ' Msgbox string variables Dim szMsg As String Dim szStyle As String Dim szTitle As String ' Change here for the icon's name Const szIconName As String = "\cvg.ico" ' Constant string values, you can replace "Desktop" ' with any Special Folders name to create the shortcut there Const szlocation As String = "Desktop" Const szLinkExt As String = ".lnk" ' Object variables Dim oWsh As Object Dim oShortcut As Object ' String variables Dim szSep As String Dim szBookName As String Dim szBookFullName As String Dim szPath As String Dim szDesktopPath As String Dim szShortcut As String ' Initialize variables szSep = Application.PathSeparator szBookName = szSep & ThisWorkbook.Name szBookFullName = ThisWorkbook.FullName szPath = ThisWorkbook.Path On Error Goto ErrHandle ' The WScript.Shell object provides functions to read system ' information and environment variables, work with the registry ' and manage shortcuts Set oWsh = CreateObject("WScript.Shell") szDesktopPath = oWsh.SpecialFolders(szlocation) ' Get the path where the shortcut will be located szShortcut = szDesktopPath & szBookName & szLinkExt ' Make it happen Set oShortcut = oWsh.CreateShortCut(szShortcut) ' Link it to this file With oShortcut .TargetPath = szBookFullName .IconLocation = szPath & szIconName .Save End With ' Explicitly clear memory Set oWsh = Nothing Set oShortcut = Nothing ' Let the user know it was created ok szMsg = "Shortcut was created successfully" szStyle = 0 szTitle = "Success!" MsgBox szMsg, szStyle, szTitle Exit Sub ' or if it wasn't ErrHandle: szMsg = "Shortcut could not be created" szStyle = 48 szTitle = "Error!" MsgBox szMsg, szStyle, szTitle End Sub Lenke til kommentar
Harald Staff Skrevet 16. februar 2012 Del Skrevet 16. februar 2012 ..og løsningen var? Lenke til kommentar
perroga Skrevet 17. februar 2012 Forfatter Del Skrevet 17. februar 2012 (endret) Jeg byttet ut setningen szBookName = szSep & ThisWorkbook.Name med szBookName = szSep & ThisWorkbook.Path Da virket det. I tillegg byttet jeg ut denne setningen: szBookName = szSep & ThisWorkbook.Name med denne szBookName = szSep & "MyFoldername" 'her skrev jeg inn navnet til mappen. I tillegg endret jeg denne "\cvg.ico" 'Her skrev jeg inn navn et eksisterende ikon som jeg fant på intranettet. Morsomt at brukerne av filen får et automatisk generert, lett gjenkjennelig ikon på skrivebordet. Og her skrev jeg inn path til ikonet: .IconLocation = "c:\Program Files\ikoner" & szIconName Endret 17. februar 2012 av perroga Lenke til kommentar
deaktivert443556 Skrevet 20. februar 2012 Del Skrevet 20. februar 2012 En eller annen person i Adobe har lurt på tilsvarende spørsmål. Han lurte på hvordan brukeren skulle få lagd en snarvei til Acrobat Reader på skrivebordet hver eneste gang programmet blir oppdatert. Det fikk han til, og pga dette håper jeg at han blir påkjørt av en buss. Lenke til kommentar
