MilKman' Skrevet 9. februar 2012 Del Skrevet 9. februar 2012 Heihei Har et stooort problem med min Traktor KOntrol S4/Traktor Pro 2 La inn en post på Native-instruments forumet, men får ingen gode svar, så jeg copy/paster det jeg skrev der inn hit. Hi! I have a somple problem I can't find a solution to. The problem is regarding the audio in Traktor Pro 2, With kontrol S4, and I'm CERTAIN that someone has had the same "problem". I've plugged everything to my computer, and to my monitor. Now, when I play a song and press CUE, nothing happens in my headset, but the sound on the speakers gets a little higher. No I change something in the output routing. The monitors, to L=Monitor Left, R=Monitor Right. Now everything happens in my headset. I press CUE, and the headsetsound is abit higher. I Changed audio setup to Kontrol S4 WDM Audio, with no luck (Before WDM, I had it checked on Traktor Kontrol S4 Audio (ASIO). I think I've explained enough for anybody here to understand, hopefully. Lenke til kommentar
