Problemer med å aktivere W7, 0x80070005 ingen tilgang
Tror jeg fant noe som kan løse det:
Your problem is the ‘permission denied’ error above
usually it is caused by a corrupted Licensing Store.
try the following.
Recreate the Licensing Store
1) Click Start button.
2) Type: CMD.exe into the 'Search programs and files' field
3) Right-Click on CMD.exe and select Run as Administrator
4) Type: net stop sppsvc (It may ask you if you are sure, select yes)
Note: the Software Protection service may not be running, this is ok.
5) Type: cd %windir%\ServiceProfiles\NetworkService\AppData\Roaming\Microsoft\SoftwareProtectionPlatform
6) Type: rename tokens.dat tokens.bar
7) Type: cd %windir%\system32
8) Type: net start sppsvc
9) Type: slui.exe
10) After a couple of seconds Windows Activation dialog will appear. You may be asked to re-activate and/or re-enter your product key or Activation may occur automatically.
http://social.microsoft.com/Forums/eu/genuinewindows7/thread/c2cf6084-36db-4fc8-90e2-0ee71cb2b14d
Gjest Slettet-t8fn5F
Vel nå er det gått 2 timer. en reinstall tar bare en time.... he he.
Om du kan boote opp platen, så finnes det alternativer for å reparere installasjonen.
Eventuelt i et elevert cmd vindu kjøre sfc /scannow
Står faktisk om dette hos Microsoft
UAC eleveringen er visstnok "broken"
Quote:
Error code 0x80070005
Symptom
You may receive the following error message:
0x80070005
Access denied the requested action requires elevated privileges.
Cause
This issue occurs if User Access Control (UAC) does not let the activation processes run in a non-elevated command prompt.
Workaround
To work around this issue, follow these steps:
Click Start, click All Programs, click Accessories, right-click Command Prompt, and then click Run as.
Click The following user, and then select Administrator in the User name list.
Click OK.
At a command prompt, type the following command, and then press ENTER:
slmgr.vbs
Flott at det løste seg .
Får håpe det ikke henger igjen noe muffins lenger i win installasjonen din da :whistle:
Set at denne fix stiller om rettigheter blandt annet.
Sikkert noe av det som fikset biffen
WAT Fix will:
Uninstall RemoveWAT (or similar)
Uninstall HAL7600
Uninstall Chew7
Uninstall uODIN
Correct file permissions
Correct important system files
Correct services required for activation
Correct VBS file associations
Remove Microsoft entries from the HOSTS file
Endret av syar2003
Tydeligvis problemer med rettigheter på filene. Det er veldig vanskelig å rette opp i om systemfiler har fått feile eiere og sånt...
  • 2 måneder senere...
Det viste seg at problemet ikke ble løst. Meldingen om aktivering kom igjen etter noen dager, har nettopp kjørt en ny installasjon, men samme problemet.
Er kun på denne maskinen det skjer, fungerer fint på andre maskiner jeg nettopp har installert på.
Tips?
Er der noen AUTOUNATTEND.XML fil på instalasjonsmediaet?
Mistenker at den er satt opp til å bruke en KMS server for aktivering.
