N o r e n g Skrevet 24. august 2012 Rapporter Del Skrevet 24. august 2012 HD7970 eller GTX670? BF3. 670, med mindre du skal kjøre 7680x1600 Lenke til kommentar
Nizzen Skrevet 28. august 2012 Rapporter Del Skrevet 28. august 2012 (endret) http://www.guru3d.co...-beta-download/ GeForce ForceWare driver 306.02 Beta New & Updated SLI Profiles Alan Wake's American Nightmare Borderlands 2 Darksiders 2 F1 2012 Orcs Must Die! 2 PlanetSide 2 (Updated) Shogun 2: Total War (Updated) Sleeping Dogs (Please note that we are currently evaluating SLI bit 0x0C4010F5, which may result in higher performance for users) The Secret World (Updated) New & Updated 3D Vision Profiles A New Dawn – Rated Fair Alan Wake's American Nightmare – Rated Not Recommended All Zombies Must Die! Scorepocalypse – Rated Good ARMA 2: Operation Arrowhead – Rated Fair Bang Bang Racing – Rated Excellent Brave – Rated 3D Vision Ready Devil May Cry 4 - Rated Fair Dishonored – Rated Good End of Nations – Rated Good London 2012 The Official Video Game – Rated Fair Mad Doc Jr.'s Doom Rails – Rated Excellent Raiderz – Rated Fair Roller Coaster Rampage – Rated 3D Vision Ready SCANIA Truck Driving Simulator – Rated Fair Test Drive: Ferrari Racing Legends – Rated Good The Secret World – Rated Good NVIDIA Surround Surround settings now persist after new driver install. Fixed Single-GPU Issues Windows Vista & Windows 7 3D Surround, 4-way SLI: The NVIDIA Control Panel -&--#62; Configure Displays for Surround user-assistance screen does not show the correct GPUs to connect the displays on a 4-way SLI system. GeForce 400 series: After installing the VGA driver and then choosing the ‘restart later’ option, the display goes blank when subsequently installing the NVIDIA driver. GeForce GT 650M: "No compatible hardware found" error occurs when installing the driver. GeForce GTS 400 series: Rendering is not visible with some DirectX 9 applications when Shader model 3.0 is used. GeForce GTX 200 series: Mount & Blade Warband - Stuttering occurs during game-play. GeForce GTX 500 series, 3D Vision: Crysis 2 & DiRT Showdown - Residual images appear throughout the game if 3D Vision is enabled. GeForce GTX 600 series: Titan Quest - Gameplay is jerky and stutters with V-Sync enabled. Windows 8 GeForce GTX 500 series, 3D Vision: Crysis 2 & Dirt Showdown - Residual images appear throughout the game if 3D Vision is enabled. Optimus Notebook: Blue-screen crash occurs pointing to dxgkrnl.sys when attempting to uninstall the driver using the Windows Device manager. SLI, Surround: Intel x59 or x79 - With Surround enabled, a blue-screen crash (0xA: IRQL_NOT_LESS_OR_EQUAL) may occur when enabling or disabling SLI or Surround modes. When re-installing the NVIDIA driver after uninstalling it, the driver may fail to install. Endret 28. august 2012 av Nizzen Lenke til kommentar
efikkan Skrevet 30. august 2012 Rapporter Del Skrevet 30. august 2012 Nvidia GK110 på väg till Geforce och konsumentmarknaden (rykte fra Sweclockers) At det kommer er vel ganske sikkert, spørsmålet er vel heller når og til hvilken pris? Lenke til kommentar
N o r e n g Skrevet 30. august 2012 Rapporter Del Skrevet 30. august 2012 Med tanke på hva man kan forvente av ytelsesøkning burde det ikke bli alt for mye mer enn 4K egentlig, 4.5K maks. Lenke til kommentar
Lami Skrevet 30. august 2012 Rapporter Del Skrevet 30. august 2012 Hva burde jeg kjøpe? Gainward GeForce GTX 660Ti 2GB PhysX til 2.195,- ELLER ZOTAC GeForce GTX 670 2GB PhysX CUDA til 2.695,-? Skal på LAN om en måned, og synes dette var gode tilbud. Skal jeg kjøpe nå for å være sikker, eller tror dere det kommer noen gode tilbud på 670 elns i løpet av måneden videre? 660Ti frister veldig siden det er så sinnsykt billig, men det hjelper lite hvis jeg ikke klarer å spille BF3 på høyeste :/ Lenke til kommentar
N o r e n g Skrevet 30. august 2012 Rapporter Del Skrevet 30. august 2012 Med mindre man sparer 30% på å kjøpe et 660 Ti er 670 en like grei deal. Ingen av de to kortene klarer vel strengt tatt å kjøre BF3 på Ultra >60fps konstant. Lenke til kommentar
Nizzen Skrevet 31. august 2012 Rapporter Del Skrevet 31. august 2012 PowerColor is asking $999 for their card, which is the same as NVIDIA's GTX 690. I find it hard to recommend the PowerColor card at that price-point. NVIDIA's card provides the better overall experience, less power, noise, heat, better max OC performance, in a dual slot form factor, and better drivers. Lenke til kommentar
samye83 Skrevet 31. august 2012 Rapporter Del Skrevet 31. august 2012 Har lest par tester, og strømforbruket til 7990 er ikke så ille egentlig, maks load ca 525watt. Sammenlignet med 690 er det nok litt mye. Jeg har klart å dra over 700w fra veggen med 2x7950. Folk har blitt litt bortskjemt med de strømgjerrige kortene til nvidia. Et blodklokket 580 passerte også 500w da jeg testa det. Hadde jeg hatt de ekstra pengene, hadde jeg nok kjøpt det og testa det for moro skyld, hehe. 1 Lenke til kommentar
**dp** Skrevet 1. september 2012 Rapporter Del Skrevet 1. september 2012 da er jeg på VGA Hotwire mission med Kepler GTX680 Vanilla kort.. begge to vannkjølte.. 1.35 as we speak.. VM i svingninger på spenningen tho. H 1 Lenke til kommentar
samye83 Skrevet 1. september 2012 Rapporter Del Skrevet 1. september 2012 Det her blir spennende, får se hvor langt du kan presse kortene Lenke til kommentar
N o r e n g Skrevet 1. september 2012 Rapporter Del Skrevet 1. september 2012 Har lest par tester, og strømforbruket til 7990 er ikke så ille egentlig, maks load ca 525watt. Sammenlignet med 690 er det nok litt mye. Jeg har klart å dra over 700w fra veggen med 2x7950. Folk har blitt litt bortskjemt med de strømgjerrige kortene til nvidia. Et blodklokket 580 passerte også 500w da jeg testa det. Hadde jeg hatt de ekstra pengene, hadde jeg nok kjøpt det og testa det for moro skyld, hehe. Bare 700W? Lenke til kommentar
samye83 Skrevet 1. september 2012 Rapporter Del Skrevet 1. september 2012 Er 1000w med kun 2x7950 også? Hotwirering også eller? Lenke til kommentar
Drunkenvalley Skrevet 1. september 2012 Rapporter Del Skrevet 1. september 2012 I alle dager er det eg ser på arni... Lenke til kommentar
N o r e n g Skrevet 1. september 2012 Rapporter Del Skrevet 1. september 2012 Er 1000w med kun 2x7950 også? Hotwirering også eller? Det er 2x 7970 med en 2600k som kjører OCCTs Power Supply Test :!: Passerer sjelden 700W vanligvis. Lenke til kommentar
samye83 Skrevet 1. september 2012 Rapporter Del Skrevet 1. september 2012 Jeg klarte ca 735w under 3dmark11 test med 2x7950 og i7 920. Jeg syns at det er ganske mye, hehe. Lenke til kommentar
N o r e n g Skrevet 1. september 2012 Rapporter Del Skrevet 1. september 2012 Jeg klarte ca 735w under 3dmark11 test med 2x7950 og i7 920. Jeg syns at det er ganske mye, hehe. Jeg passerer ikke 700W i 3DMark11, om det gir en indikasjon på akkurat hvor latterlig OCCTs Power Supply-test er. Fortsatt småmorsomt å se. Lenke til kommentar
samye83 Skrevet 1. september 2012 Rapporter Del Skrevet 1. september 2012 Aha, nå skjønner jeg poenget ditt. Lenke til kommentar
**dp** Skrevet 1. september 2012 Rapporter Del Skrevet 1. september 2012 Det her blir spennende, får se hvor langt du kan presse kortene ser hittil ikke så bra ut.. hmmm.. kjører 1374Mhz, men får ikke høyere score i bencher - ENDA. Lenke til kommentar
samye83 Skrevet 1. september 2012 Rapporter Del Skrevet 1. september 2012 Hva var max oc på gpu'ene før hotwirering? Lenke til kommentar
Nizzen Skrevet 1. september 2012 Rapporter Del Skrevet 1. september 2012 Synn jeg er fullt opptatt med å montere inn 2 stk strømforsyninger i LD cooling kabinettet 2300w burde holde for litt benching. Haakon! har du et 680 til overs? Lenke til kommentar
