Logg inn side. Hva gjør jeg feil?
Hei.
Jeg skal lage en logg inn side i php, men den funker ikke. Noen som kan hjelpe?
Her er index.php
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<?php
// Connects to your Database
mysql_connect("localhost", "root", "") or die(mysql_error());
mysql_select_db("brukere") or die(mysql_error());
//Checks if there is a login cookie
if(isset($_COOKIE['ID_my_site']))
//if there is, it logs you in and directes you to the members page
	$username = $_COOKIE['ID_my_site'];
	$pass = $_COOKIE['Key_my_site'];
	 	$check = mysql_query("SELECT * FROM users WHERE username = '$username'")or die(mysql_error());
	while($info = mysql_fetch_array( $check ))
		if ($pass != $info['password'])
		else
			header("Location: members.php");
//if the login form is submitted
if (isset($_POST['submit'])) { // if form has been submitted
// makes sure they filled it in
	if(!$_POST['username'] | !$_POST['pass']) {
		die('Du fylte ikke et eller flere felt!');
	// checks it against the database
	if (!get_magic_quotes_gpc()) {
		$_POST['email'] = addslashes($_POST['email']);
	$check = mysql_query("SELECT * FROM users WHERE username = '".$_POST['username']."'")or die(mysql_error());
//Gives error if user dosen't exist
$check2 = mysql_num_rows($check);
if ($check2 == 0) {
		die('Brukeren finnes ikke!');
$_POST['pass'] = stripslashes($_POST['pass']);
	$info['password'] = stripslashes($info['password']);
	$_POST['pass'] = md5($_POST['pass']);
//gives error if the password is wrong
	if ($_POST['pass'] != $info['password']) {
		die('Feil passord. Prøv igjen.');
else
// if login is ok then we add a cookie
	 $_POST['username'] = stripslashes($_POST['username']);
	 $hour = time() + 3600;
setcookie(ID_my_site, $_POST['username'], $hour);
setcookie(Key_my_site, $_POST['pass'], $hour);
//then redirect them to the members area
else
// if they are not logged in
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
<title>Logg inn</title>
<link href="login-box.css" rel="stylesheet" type="text/css" />
</head>
<body>
<div style="padding: 100px 0 0 250px;">
<div id="login-box">
<H2>Logg innn</H2>
Her kan du logge inn
<br />
<br />
<div id="login-box-name" style="margin-top:20px;">Brukernavn</div><div id="username" style="margin-top:20px;"><input name="q" class="form-login" title="username" value="" size="30" maxlength="2048" /></div>
<div id="login-box-name">Passord:</div><div id="pass"><input name="q" type="password" class="form-login" title="pass" value="" size="30" maxlength="2048" /></div>
<br />
<br />
<br />
<a href="#"><img src="images/login-btn.png" width="103" height="42" style="margin-left:90px;" /></a>
</div>
</div>
</body>
</html>
<?php
Her er login-box.css
#login-box {
width:333px;
height: 352px;
padding: 58px 76px 0 76px;
color: #ebebeb;
font: 12px Arial, Helvetica, sans-serif;
background: url(images/login-box-backg.png) no-repeat left top;
#login-box img {
border:none;
#login-box h2 {
padding:0;
margin:0;
color: #ebebeb;
font: bold 44px "Calibri", Arial;
#login-box-name {
float: left;
display:inline;
width:80px;
text-align: right;
padding: 14px 10px 0 0;
margin:0 0 7px 0;
#login-box-field {
float: left;
display:inline;
width:230px;
margin:0;
margin:0 0 7px 0;
.form-login  {
width: 205px;
padding: 10px 4px 6px 3px;
border: 1px solid #0d2c52;
background-color:#1e4f8a;
font-size: 16px;
color: #ebebeb;
.login-box-options  {
clear:both;
padding-left:87px;
font-size: 11px;
.login-box-options a {
color: #ebebeb;
font-size: 11px;
Mulig jeg overser noe, men mangler du ikke <form> </form> tags?
Trodde det var nødvendig for å hente ut $_POST informasjon.
<H2>Logg innn</H2>
<br />
<br />
<form name="login" action="dittlogginnscript.php" method="post">
<div id="login-box-name">Passord:</div><div id="pass"><input name="q" type="password" class="form-login" title="pass" value="" size="30" maxlength="2048" /></div></form>
<H2>Logg innn</H2>
<br />
<br />
Klarer forsatt ikke logge inn :hmm:
Får bare /# på slutten av url'en.
Det er på grunn av den kodelinjen ja. Om du skriver
<input type="submit" value="Submit" />
så vil det (forhåpentligvis) funke, men du kan også skrive
<input type="image" src="images/login-btn.png" width="103" height="42" style="margin-left:90px;" />
Det bør gjøre bildet til submit-knapp, ref denne guiden.
<?php
               else
if ($check2 == 0) {
       else
else
<head>
</head>
<body>
<H2>Logg innn</H2>
<br />
<br />
</div><div id="login-box-name">Passord:</div><div id="pass"><input name="q" type="password" class="form-login" title="pass" value="" size="30" maxlength="2048" /></div>
<br />
</form>
</div>
</div>
</body>
</html>
<?php
<?php
               else
if ($check2 == 0) {
       else
else
<head>
</head>
<body>
<H2>Logg innn</H2>
<br />
<br />
<br />
</form>
</div>
</div>
</body>
</html>
<?php
Det funker, men om man skriver feil passord så kommer man til samme side som om man skriver rett passord :hmm:
Åpenbart. Du må sjekke på den siden man redirectes til hvorvidt passordet var rett eller ei. Du bruker jo cookies.
Forresten, du har en potensiell sikkerhetssvakhet der. Scriptet genererer forskjellige feilmeldinger avhengig av om det er bruker eller passord som er feil, på den måten kan en inntrenger finne ut om et gitt brukernavn er gyldig eller ikke. Du bør ha disse unntakene i samme if-blokk og ha en mer generell feilmelding ("brukernavn eller passord er feil").
Endret av srbz
