[Løst] oppdatere firmware Corsair force sata 3 problemer
Enten fordi kontrolleren ikke er Intel eller AMD eller fordi den ikke står i rikrig modus.
* This update tool is intended to be run with the drive controller in AHCI mode. If your drive controller is not AHCI enabled and your update fails, you will need to change it to AHCI mode and also enable AHCI in your OS registry. Here is page with a guide for ENABLING AHCI.
* Our latest testing is only with Intel and AMD drive controllers. The update may not work with 3rd party drive controllers. The update will not work on a controller that is in RAID mode. This applies to SATA2 and SATA3 controllers.
