Hjelp med Partition Magic
Ohord
Heisann! :D
Skal partisjonere hden min, men så står dette i readme filen:
- Error 183: Init Failed. If you attempt to run PartitionMagic on
a Windows 2000/XP Professional machine where the boot partition
(the partition where Windows 2000/XP Professional is installed)
is on a dynamic disk, you will receive the following error message:
"Init failed: Error 183. Unable to identify the Windows partition."
To solve this problem, Windows 2000/XP must be installed on a
basic disk.
Betyr dette at jeg ikke kan partisjonere hden min som Windows ligger på elller?
Takk for alle svar :)
