[Løst] Excel 2007 VBA Lagre nytt ark og legge inn sideoppsett
Hei.
Jeg lager en statistikk hver dag, så lagrer jeg den som et nytt ark ved hjelp av en makro.
Men jeg vil ha sideoppsettet Liggende og at den skrives ut på en side.
Bredde 1 side
lengde 1 side
Jeg har Registrert en makro på dette, men lurer på om det finnes en kortere kode enn det her
With ActiveSheet.PageSetup
       .PrintTitleRows = ""
       .PrintTitleColumns = ""
   End With
   ActiveSheet.PageSetup.PrintArea = ""
       .LeftHeader = ""
       .CenterHeader = ""
       .RightHeader = ""
       .LeftFooter = ""
       .CenterFooter = ""
       .RightFooter = ""
       .LeftMargin = Application.InchesToPoints(0.7)
       .RightMargin = Application.InchesToPoints(0.7)
       .TopMargin = Application.InchesToPoints(0.787401575)
       .BottomMargin = Application.InchesToPoints(0.787401575)
       .HeaderMargin = Application.InchesToPoints(0.3)
       .FooterMargin = Application.InchesToPoints(0.3)
       .PrintHeadings = False
       .PrintGridlines = False
       .PrintComments = xlPrintNoComments
       .PrintQuality = 600
       .CenterHorizontally = False
       .CenterVertically = False
       .Orientation = xlLandscape
       .Draft = False
       .PaperSize = xlPaperA4
       .FirstPageNumber = xlAutomatic
       .Order = xlDownThenOver
       .BlackAndWhite = False
       .Zoom = 100
       .PrintErrors = xlPrintErrorsDisplayed
       .OddAndEvenPagesHeaderFooter = False
       .DifferentFirstPageHeaderFooter = False
       .ScaleWithDocHeaderFooter = True
       .AlignMarginsHeaderFooter = True
       .EvenPage.LeftHeader.Text = ""
       .EvenPage.CenterHeader.Text = ""
       .EvenPage.RightHeader.Text = ""
       .EvenPage.LeftFooter.Text = ""
       .EvenPage.CenterFooter.Text = ""
       .EvenPage.RightFooter.Text = ""
       .FirstPage.LeftHeader.Text = ""
       .FirstPage.CenterHeader.Text = ""
       .FirstPage.RightHeader.Text = ""
       .FirstPage.LeftFooter.Text = ""
       .FirstPage.CenterFooter.Text = ""
       .FirstPage.RightFooter.Text = ""
   End With
   End With
       .LeftHeader = ""
       .CenterHeader = ""
       .RightHeader = ""
       .LeftFooter = ""
       .CenterFooter = ""
       .RightFooter = ""
       .PrintQuality = 600
       .Draft = False
       .Zoom = False
       .FitToPagesWide = 1
       .FitToPagesTall = 0
   End With
   End With
       .LeftHeader = ""
       .CenterHeader = ""
       .RightHeader = ""
       .LeftFooter = ""
       .CenterFooter = ""
       .RightFooter = ""
       .PrintQuality = 600
       .Draft = False
       .Zoom = False
       .FitToPagesWide = 1
       .FitToPagesTall = 1
   End With
Hilsen Torbjørn
  • 2 uker senere...
Hei.
Kommet litt lengre på den her, men får fortsatt ikke til at Bredde blir 1 side og høyde blir 1 side.
Sheets(x).Activate
   .FitToPagesWide = 1
   .FitToPagesTall = 1
End With
Noen forslag?
Hilsen
Torbjørn
Hei.
Da var den løst.
Etter og leitet litt på nettet og tatt opp en makro, og fjerna linje etter linje. så kom jeg fram til en veldig kort makro.
som går kjempe fort. Men den er ikke noen mal fordi ".zoom 69" blir akkuratt 1 ark for for hvordan arket mitt ser ut
Sheets("ark1").Activate
   .Zoom = 69
Hilsen
Torbjørn
