PC ca. 60 000
Hei
Har satt sammen en PC på komplett.no til ca 60 000.. Det jeg lurer på er om noen har noen tips til forbedringer i dette oppsettet. Vil primært bli brukt til gaming.
http://www.komplett.no/k/shoplist.aspx?mode=receive&si=1035557&su=B3FB2B88-9E9F-4626-9AB4-5AD7DCDEA1CD
2x ASUS GeForce GTX 590 3072MB PhysX CUDA PCI-Express 2.0, GDDR5, 3xDVI, native-HDMI
1x ASUS P9X79 Deluxe, Socket-2011 ATX, X79, 8xDDR3, 4xPCIe(3.0)x16, CFX&SLI, 2xGbLAN, SATA 6Gb/s, USB3.0, WiFi,EFI
1x ASUS Xonar HDAV1.3 Slim PCI, HDMI 1.3, Full HD, Dolby TrueHD and DTS-HD Master Audio bitstreaming
3x BenQ 23,6" LED XL2420T 1920x1080, 10m:1, 2ms,120Hz
1x Bose Companion 5 Høyttalere, 2.1 Grafitt
1x Cooler Master HAF X Big Tower Sort Vifter: 1x 230mm Front, 1x 200mm Topp, 1x 200mm Side, 1x 140mm Bak, Rød LEDs
1x Cooler Master Silent Pro Hybrid 1300W ATX 12V V2.3, 80 Plus Gold, Modular, 6x 6+2pin PCIe, 12x SATA, Kontrollpanel
2x Corsair Dominator GT DDR3 2000MHz 12GB Kit w/3x 4GB XMS3 DHX, CL9-10-9-27, for Core i7, w/Fan& Connector, 1.65v
1x Intel® Core i7-3930K Processor Socket-LGA2011, Six Core, 3.2Ghz, 12MB, Boxed, no fan included
1x Kingston Datatraveler Ultimate G2 16GB USB3.0
2x Kingston HyperX SSD 240GB 2.5" SATA 6 Gb/s (SATA3.0), 555MB/510MB/s read/write, SandForce®
1x Logitech G35 Gaming headset 7.1 surround sound powered by dolby
1x Microsoft Windows 7 Ultimate Norsk, Full, DVD
1x Noctua NH-C14 CPU Kjøler Socket 775/1155/1156/1366, AM2/AM2+/AM3, 1200 RPM, 110,3 m³/h, 19,6 dBA
1x Noctua NM-I2011 Mounting-Kit Socket compatibility LGA2011, Supported CPU series Intel Core i7 39xx & 38xx
1x Razer BlackWidow Ultimate Mechanical USB, Nordic layout
1x Razer Mamba 4G Wireless Gaming Mouse 6400dpi 4G Dual Sensor System, 1000Hz Ultrapolling /1ms response time
3x Skjermkabel DVI M/M 5m high quality cable, dual link DVI-D
1x Sony Optiarc Blu-Ray Writer, BD-5300S SATA, BD-R DL: 8x, BD-RE: 2x, DVD±R: 16x, DVD±RW: 8x, Bulk, BLACK
1x Symantec Norton 360 v5 Nordisk Retail CD, 3 bruker
1x XFX Triple Monitor Stand Supports up to 3x 24" screens - VESA 75/100
Det eneste jeg lurer på er om du trenger 5meter lange DVI kabler? Hvis du kun trenger nomale kabler så følger disse med skjermene.
Hva skal du bruke pc'en til utenom gaming?
-OEH
Endret av OEH
Må si meg enig med resten. Sorry, TS, men dette er som å holde en lighter under tusenlappene dine.
Dersom du likevel er seriøs, hva mener du ditt oppsett vil tilføre spillopplevelsen som ikke en PC til under halve prisen vil kunne gjøre? Dersom du kjøper dette for bling-faktoren så vil du uansett bli forbigått av en PC til 10-15k innen et år er omme.
Endret av Pseudopod
Om du kun skal spille, så er det ikke nødvendig å bruke 60k. Det er heller ikke nødvendig med 6-kjerners CPU og ikke 4 GPUer. Dette fordi det ikke vil utnyttes, og du sitter med masse utstyr som nesten bare tvinner tomler fordi det har for lite å gjøre.
Kan godt hver at pcen din havner rett over 20k kroner, tenker da på alt ekstrautstyr og tilbehør.
Du kan fort svi av 10k kroner på bare skjermer, viss du har tenkt å feks kjøre 3 skjermer. Tenker da på veldige gode skjermer med ips panel.
Kabinett til 14-1500kr.
PSU til en 14-1500kr.
Kanskje 2 stk SSDer i raid? går fort 4000kr viss du vil ha litt plass. (men dem fleste trenger ikke å kjøre raid med ssder viss det er fart du er ute etter, da det er mer en nok fart på en enkel ssd).
Men som sakt over fra andre, 60 000 kroner er vås fra din side. Tipper dette bare er bullshit hele posten fra deg.
ok, hvis denne tråden ikke er bullshit, så er det dette noe å tenke over:
hvis du skal ha en PC til 60K, så kjøp heller en PC til 20K eller mindre
kjøp kabinett, SSD, HDD og strømforsyning av god kvalitet slik at du kan bruke det om igjen
og bruk da heller 10-15K om 2-3 år for å fornye den
forslag til deler er:
prosessor: intel i5 2500K
Grafikkort: AMD HD 7970
Hovedkort: Asus P8Z68-V PRO/Gen3
RAM: Corsair Vengeance 8GB (2x4GB
skikkelig vankjøling
HDD: samsung spinpoint f3 1TB eller Western Digital Caviar black 2TB/3TB
SSD: samsung 830 128GB/256GB
PSU: Seasonic X serien eller platinum serien på 850 watt
ett eller annet kabinett med plass til vannkjøling, som for eksempel Corsair Obsidian 800D, i det kan du putte en 120x360 radiator + 2 stk. 140x140 radiatorer, og så vifter til push pull på radiatorene
Kjøp to av disse å sett de i Raid 0 .... Done deal!
Happy Gaming!
http://www.komplett.no/k/ci.aspx?sku=10499
Thanks and bye
forklar meg hvordan man setter to datamaskiner i RAID...
Dette er det dummeste jeg noengang har sett.
Om du planlegger å bruke 60K på en stasjonær er det to krav som må oppfylles:
  1.
  2. Du vet nøyaktig hva du trenger
  3. Du kommer til å vannkjøle alt sammen
Begge disse må være oppfylt for at det skal være noen vits, du har feilet på begge to. At du vurderer å stappe alt dette i et HAF X er vannvidd.
  • Liker 7
for 978 dager siden lagde du en tråd om en PC til 25k, tror nok at du aldri endte opp med å kjøpe noe maskin den gangen. Denne gangen skal du ha en PC til 60k! huh.gif
Vis du slår sammen maskinene til alle som har svart deg i tråden her, så er kanskje verdien til sammen 60k, og samtlige av disse maskinene drar det meste av spill på maks.
Lag heller en seriøs tråd og gjør litt research, enn å kaste bort tia på komplett.no for å sette sammen det dyreste og kuleste.
Slutt å kast bort tia til oss som faktisk prøver å hjelpe folk her på forumet. grumpy.gif
Ser det er en del som ikke tror helt på oppsettet her pga prisen. Det er bevist valgt komponenter av høy kvalitet for å slippe å oppgradere pc'en hvert år.
For å forsvare prisen litt: Skjermene som er valgt kommer på 9.885,- sammen med stativ for oppheng av skjermene til 3.495,-. Dette er 13.380,-
Win7 Ultimate 2.495,- og antivirus 699,-
Det er også med et Bose lydanlegg til 3.995,-
Logitech G35 headsett 799,-
Dette er ca 21 500 kr som ikke direkte har noe med pc'en å gjøre, bortsett fra operativsystem, men det trenger man jo uansett.
Komponenter som tower, strømforsyning, mus, tastatur og blu ray brenner/spiller er av høy kvalitet og vil ha lang levetid. (Om det ikke under en uheldig omstendighet skulle bli ødelagt)
Greit nok det er jeg som har sett feil ang 5m DVI kabel. Takk for tips.
Grunnen til at de dyre komponentene er valgt er at jeg tror at med dette oppsettet vil jeg kunne fint spille de nyeste spillene om også 3 år uten problemer.
Men det jeg egentlig lurer på er om det er noe dere ville byttet ut i oppsettet med bedre komponenter? Takker for alle svar! :)
PCer holder seg ikke. Om 1 år kommer du til å kunne kjøpe en PC til under 15k som vil dra akkurat det samme som denne du nå vurderer å kjøpe.
Det er billigere, mer fornuftig og du får mer igjen for å bruke ~15k nå, så oppgradere til neste generasjon skjermkort når det kommer til neste år etc. Da har du brukt under halvparten og sitter igjen med LANGT bedre PC enn det du her har satt opp..
  • Liker 3
Alle som bestemmer seg for å bruke over 10k på datakomponenter burde etter min mening skaffe seg vannkjøling.
For min egen del brukte jeg knapt 8k på PC inklusiv skjerm for 2-3 år siden. Har kjøpt oppgraderingsdeler til rundt 2k og holder seg fin som juling... Men selvsagt.. Om du har ræva full av penger, værsegod.
