Sony Xperia S - Sonys første dual-core! Diskuter den her!
79 stemmer
  1. 1. Er du fornøyd med din Xperia S?
    • Ja, superfornøyd!
      23
    • Sånn passe...
      7
    • Nei, ikke fornøyd!
      5
    • Har ikke Xperia S, men vurderer å kjøpe den.
      26
    • Har ikke Xperia S, og vil ikke ha en heller
      18
Se, her er den fremgangen jeg brukte. Eneste negative er at landskapsmodus ikke fungerer enda! I
install CM 7.1 Android 2.3.7 Gingerbread on 68 Android Phones
Step 1 – Download the CynogenMod 7.1.zip file for your Android Phone from HERE. Ensure that the file is for your Desired Android Phone/Device y just checking your Devices Code name HERE.
Step 2 – Now Transfer the CM7.1.zip file to the Root (Parent Directory) of your Android Smartphone. You can also do this after Connecting your Phone via USB Cable.
Step 3 – When Transfered that .zip file, now Turn OFF your Device.
Step 4 – Using a specific combination of keys, you must now boot into ClockworkMod Recovery (CWM). This combination is different for different devices, so you’ll need to look it up on Google.
Step 5 – Using the volume up/down, home and back keys, navigate to backup and storage > backup. CWM will now take what is called a nandroid backup of your device which you can use later on if you wish to revert to current setup.
Step 6 – Once Backup Completyes, Scroll Down to mounts and Storage and Format/System and also Format/data and Format/Cache too.
“Similarly, go back to main menu and wipe data / factory reset.”
Step 7 – Here is the Step to Flash CM7.1 on Android Device/Phone.
* From the Main Mnu: Install zip from SDcard=>Choose Zip from SD Card=>(Name of the file you Downoaded in Step 1).
* Now CM7.1 Flashing will Continue Process
Step 8 – Once CyanogenMod 7.1 Flashing Completes, Reboot your Phone/Device from the Reboot System Option on CWM’s Main Menu.
Jeg beklager dette forumtrollet "mobilfil".
Hvor er selve ROM? Link?
Kan ikke ha lest/hørt verken med DoomLord eller noen andre at CM7 har blitt portet til Xperia S?
Men forresten, fikk dere med bil lader, lær pouch og 2 sett med USB kabler? Hva skjer med at noen har fått det med? Ville gjerne ha bil lader og lær "sokk" til telefonen min for FAEN! *sende mail til sony asap*
Gjest Harley Quinn
Det fikk ikke jeg med! Bare det som lå i esken, enkelt og greit! Vet andre land har andre ting, men var bare den typen som var tilgjengelig hos de jeg spurte hos!
Dette har jeg akkurat funnet ut på min Desire HD! Når jeg kobler mobilen til PC-en, får jeg opp en meny som lar meg velge tilkoblingsmodus. Hvis jeg i denne listen velger "Internett gjennomgang", bruker telefonen Internett via PC-en.
Grunnen til at jeg kom over denne funksjonen, var at jeg ikke har tilgang til wifi på jobben og har dårlig 3G-dekning. Kom så på at jeg hadde lest om dette valget før :thumbup:
