Hvilken basskasse for min bil?
Tenker å bruke rundt 4000 for noe som kan dunke maks for penga ;)
JL Audio 10W3v3
( View Full Gallery )
Pros
JL Audio's car subwoofers sound incredible.
Cons
This sub could use a few extra help and support features.
The VerdictThis is, without a doubt, the best car subwoofer available.
ReviewSpecificationsImagesSide By Side ComparisonLearning CenterLIKE OUR REVIEWS? SUPPORT OUR SITE ON FACEBOOK OR GOOGLE PLUS
Overall Rating
Car subwoofers are some of the most important components in a high-quality car stereo system. These speakers can be configured to quietly and accurately reproduce low frequencies to enhance your music or to blast out powerful bass notes that rattle your car, and the JL Audio 10W3v3 subs do this better than anyone else. Even their 10 in subwoofers put out incredible levels of sound with amazing fidelity. JL Audio’s subs demonstrated their incredible power and accuracy at every turn, passing every one of our tests with ease and earning them the TopTenREVIEWS Gold Award. JL’s model is by far the best car subwoofer we reviewed. With great power handling, exceptional sound quality and impressive scores in the Help & Support category, these subs far outpace the competition.
JL Audio began in 1975 as a home speaker system manufacturer. The initial startup proved to be unsuccessful and the owners invested in a retail store called “Speaker Warehouse.” While this store primarily focused on speaker repair and the sale of speaker sets, they eventually became the main retailer for JL Audio when they began selling custom speakers during the “car audio revolution” of the early 80s. Since then, this company has come to dominate multiple car audio competitions with their exceptional tweeters, speakers and car subwoofers. They are known today for their efforts as pioneers in the car subwoofer industry, producing some of the most respected and high-powered products available.
Through our testing, the JL Audio subwoofer reproduced the bass notes of our songs with immaculate fidelity. We were able to hear the minute changes in the low-frequency notes. The sub reacted quickly, producing crisp, clean sounds that made every song we tested sound better. In short, this woofer’s power and beautiful sound quality pushed it above the competition. JL Audio’s car subwoofer is clearly at the top of the heap.
Send SMS og MMS fra nett www.sveve.no
SMS og MMS fra din PC. Enkel og rimelig tjeneste. Gode referanser
Ads by Google
Specs/Performance
JL Audio’s 10 in car subwoofers can be ordered in both two- and four-ohm impedance configurations. The sub with lower impedance can produce a larger volume of sound with similar wattage input when compared to a woofer with higher impedance. For all practical purposes, however, there will be little discernible difference between a two-ohm and a four-ohm subwoofer to the ears of most consumers. Whichever impedance rating you decide to go with, however, be sure to match the amp accordingly. Since JL Audio’s subs are only component subwoofers, you will need to purchase an amplifier separately to power your speaker.
These car subwoofers reproduce sounds from 25Hz to 200Hz, measured on our matrix as the “Frequency Response.” The lowest frequency that the average human ear can perceive is 20Hz; therefore, this woofer will be pumping out sound deep enough to approach the threshold of hearing. Its efficiency, however, is only average in terms of our comparison.
JL’s car subwoofer is capable of handling 1000 watts of power at its peak. While you should not run your sub at this level of power continuously, it will be more than enough to add an extra level of power to your music. The RMS continuous power, or the power at which this sub can be most safely run, is 500 watts. At this level, your subwoofer will crank out the optimal level of sound balance with the greatest speaker longevity. In short, you will want to keep your sub cranking at 500W over a long period of time.
Sound Quality
JL Audio’s car subwoofers, as noted above, are capable of reproducing very low-frequency sounds that will broaden the scope of your listening experience and bring incredible depth to your music. While these subs do not reach the subsonic frequencies produced by some of the other products on our lineup, they will do wonders with your current system. When we listened to JL Audio’s car subwoofers, we were floored by the cleanliness and accuracy of the bass notes. In every song we tested, from hard rock and hip hop to classical, the bass was impressively clean and accurate.
If you’re looking for powerful, thudding bass, JL’s sub will not leave you disappointed. The power this woofer is capable of producing is incredible; when we tested this sub, the sheer volume of the sound it produced made our hair vibrate. Of course, this does not come without a warning; these car subwoofers are certainly capable of producing levels of sound that can permanently damage your hearing. The power is impressive, but dangerous. Be cautious when cranking out the bass; if you play your music too loud, you may never hear your favorite tunes again.
Help & Support
The customer support that JL Audio offers is impressive. A standard one-year warranty is included, protecting your subwoofer from damage incurred through standard use. There are several parameters in place to be sure that you will not damage your car subwoofer through improper use, so don’t try to pump 1000 watts into these continuously and expect to get them replaced under warranty. The warranty is not overly limiting, though; we saw similar restrictions on almost all of the subwoofers that we reviewed.
If you need help installing or configuring your JL Audio car subwoofer, customer service representatives are available via telephone and email support. They also provide a FAQs section and a user manual to help resolve basic questions.
Summary
If you’re looking for the best in car audio, you can’t go wrong with the JL Audio 10W3v3 car subwoofers. These 10 in subwoofers can produce a massive amount of sound while still maintaining high fidelity. We were impressed with every aspect of these subs through our testing, so we unhesitatingly gave them the top spot in our comparison of the best car subwoofers.
JL Audio lager suber som låter fint, og har bra med trøkk, så det der er ikke noe dårlige saker. Men så kommer det ann på hva du er ute etter, mest mulig trøkk, mest mulig lykvalitet, eller litt av begge deler osc osv... Også kommer det jo ann på hvilken forsterker du skal bruke til dette også ;)
