Minecraft-error. hs_err_pidnummer.log
Heisann.
Fetteren min fikk seg ny PC til jul, og var derfor skuffet over at Minecraft ikke synes å virke på PC-en hans. Hver gang han trykker på log in, lukkes programmet og en log-fil dukker opp på skrivebordet. Dette er det den sier:
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x6e085861, pid=4492, tid=3556
# JRE version: 6.0_30-b12
# Java VM: Java HotSpot Client VM (20.5-b03 mixed mode windows-x86 )
# Problematic frame:
# C [aticfx32.dll+0x25861]
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x4c4fe000): JavaThread "Minecraft main thread" daemon [_thread_in_native, id=3556, stack(0x4c960000,0x4c9b0000)]
siginfo: ExceptionCode=0xc0000005, reading address 0x0000013c
Registers:
EAX=0x00000008, EBX=0x4c9af40c, ECX=0x0000000a, EDX=0x00000000
ESP=0x4c9aea18, EBP=0x4c9aea24, ESI=0x4cc42898, EDI=0x4cc407d0
EIP=0x6e085861, EFLAGS=0x00010202
Top of Stack: (sp=0x4c9aea18)
0x4c9aea18: 4c9af40c 4cc407d0 00000000 4c9af3bc
0x4c9aea28: 6e083f2c 400000c0 4c9af40c 00604a8c
0x4c9aea38: 0039ede8 400000c0 00000000 4c9aea50
0x4c9aea48: 00000960 400000c0 00000001 088d0000
0x4c9aea58: 0000000a 00000000 00000008 00000007
0x4c9aea68: 0000027c 0000073b 00000001 00000001
0x4c9aea78: 00008bc3 00000001 00001f9d 000007fc
0x4c9aea88: 00000001 e2f32107 000001ba 00f7ff3f
Instructions: (pc=0x6e085861)
0x6e085841: 6e 68 88 00 00 00 6a 08 52 8b f8 ff 15 b0 a0 0a
0x6e085851: 6e 8b f0 85 f6 74 1b 8b 47 20 8b 4f 14 83 c0 08
0x6e085861: 8b 80 34 01 00 00 50 8b c7 e8 21 ff ff ff 8b f0
0x6e085871: eb 02 33 f6 8b fe e8 54 24 01 00 85 c0 7c 1d 53
Register to memory mapping:
EAX=0x00000008 is an unknown value
EBX=0x4c9af40c is pointing into the stack for thread: 0x4c4fe000
ECX=0x0000000a is an unknown value
EDX=0x00000000 is an unknown value
ESP=0x4c9aea18 is pointing into the stack for thread: 0x4c4fe000
EBP=0x4c9aea24 is pointing into the stack for thread: 0x4c4fe000
ESI=0x4cc42898 is an unknown value
EDI=0x4cc407d0 is an unknown value
Stack: [0x4c960000,0x4c9b0000], sp=0x4c9aea18, free space=314k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C [aticfx32.dll+0x25861] gslCfxExit+0xe1
C [aticfx32.dll+0x23f2c] OpenAdapter+0x6edc
C [atigktxx.dll+0x1daf] GetD3DKMTProcAddress+0xbfd
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j org.lwjgl.opengl.WindowsPeerInfo.nChoosePixelFormat(JIILorg/lwjgl/opengl/PixelFormat;Ljava/nio/IntBuffer;ZZZZ)I+0
j org.lwjgl.opengl.WindowsPeerInfo.choosePixelFormat(JIILorg/lwjgl/opengl/PixelFormat;Ljava/nio/IntBuffer;ZZZZ)I+15
j org.lwjgl.opengl.WindowsDisplay.createWindow(Lorg/lwjgl/opengl/DisplayMode;Ljava/awt/Canvas;II)V+176
j org.lwjgl.opengl.Display.createWindow()V+68
j org.lwjgl.opengl.Display.create(Lorg/lwjgl/opengl/PixelFormat;Lorg/lwjgl/opengl/Drawable;Lorg/lwjgl/opengl/ContextAttribs;)V+63
j org.lwjgl.opengl.Display.create(Lorg/lwjgl/opengl/PixelFormat;)V+9
j net.minecraft.client.Minecraft.a()V+151
j net.minecraft.client.Minecraft.run()V+6
j java.lang.Thread.run()V+11
v ~StubRoutines::call_stub
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
=>0x4c4fe000 JavaThread "Minecraft main thread" daemon [_thread_in_native, id=3556, stack(0x4c960000,0x4c9b0000)]
0x4c4fd800 JavaThread "Timer hack thread" daemon [_thread_blocked, id=2644, stack(0x4c840000,0x4c890000)]
0x4c415000 JavaThread "TimerQueue" daemon [_thread_blocked, id=3940, stack(0x4b770000,0x4b7c0000)]
0x4a94c000 JavaThread "Keep-Alive-Timer" daemon [_thread_blocked, id=4976, stack(0x4b850000,0x4b8a0000)]
0x4a94f800 JavaThread "Image Fetcher 0" daemon [_thread_blocked, id=1876, stack(0x4b220000,0x4b270000)]
0x001f9800 JavaThread "DestroyJavaVM" [_thread_blocked, id=1780, stack(0x002a0000,0x002f0000)]
0x4a7d6c00 JavaThread "AWT-EventQueue-0" [_thread_blocked, id=5008, stack(0x4b4b0000,0x4b500000)]
0x4a800400 JavaThread "AWT-Windows" daemon [_thread_in_native, id=1076, stack(0x4acd0000,0x4ad20000)]
0x4a7ffc00 JavaThread "AWT-Shutdown" [_thread_blocked, id=4040, stack(0x4ac40000,0x4ac90000)]
0x4a7fd400 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=4800, stack(0x4ab40000,0x4ab90000)]
0x01e32000 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=4004, stack(0x4a670000,0x4a6c0000)]
0x01e2ac00 JavaThread "C1 CompilerThread0" daemon [_thread_blocked, id=3704, stack(0x4a5e0000,0x4a630000)]
0x01e29c00 JavaThread "Attach Listener" daemon [_thread_blocked, id=3076, stack(0x4a550000,0x4a5a0000)]
0x01e26c00 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=3244, stack(0x4a4c0000,0x4a510000)]
0x01dfc400 JavaThread "Finalizer" daemon [_thread_blocked, id=128, stack(0x4a430000,0x4a480000)]
0x01df7800 JavaThread "Reference Handler" daemon [_thread_blocked, id=3700, stack(0x4a3a0000,0x4a3f0000)]
Other Threads:
0x01df3800 VMThread [stack: 0x01ea0000,0x01ef0000] [id=4988]
0x01e3b000 WatcherThread [stack: 0x4a700000,0x4a750000] [id=4536]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation total 157248K, used 81901K [0x04210000, 0x0ecb0000, 0x19760000)
eden space 139776K, 58% used [0x04210000, 0x0920b418, 0x0ca90000)
from space 17472K, 0% used [0x0ca90000, 0x0ca90000, 0x0dba0000)
to space 17472K, 0% used [0x0dba0000, 0x0dba0000, 0x0ecb0000)
tenured generation total 349568K, used 0K [0x19760000, 0x2ecc0000, 0x44210000)
the space 349568K, 0% used [0x19760000, 0x19760000, 0x19760200, 0x2ecc0000)
compacting perm gen total 13312K, used 13218K [0x44210000, 0x44f10000, 0x48210000)
the space 13312K, 99% used [0x44210000, 0x44ef88e8, 0x44ef8a00, 0x44f10000)
No shared spaces configured.
Code Cache [0x02210000, 0x023c8000, 0x04210000)
total_blobs=1069 nmethods=829 adapters=174 free_code_cache=31757760 largest_free_block=0
Dynamic libraries:
0x00400000 - 0x00425000 C:\Program Files (x86)\Java\jre6\bin\javaw.exe
0x77a80000 - 0x77c00000 C:\Windows\SysWOW64\ntdll.dll
0x75e30000 - 0x75f40000 C:\Windows\syswow64\kernel32.dll
0x76320000 - 0x76366000 C:\Windows\syswow64\KERNELBASE.dll
0x75a50000 - 0x75af0000 C:\Windows\syswow64\ADVAPI32.dll
0x760c0000 - 0x7616c000 C:\Windows\syswow64\msvcrt.dll
0x75cf0000 - 0x75d09000 C:\Windows\SysWOW64\sechost.dll
0x75400000 - 0x754f0000 C:\Windows\syswow64\RPCRT4.dll
0x75160000 - 0x751c0000 C:\Windows\syswow64\SspiCli.dll
0x75150000 - 0x7515c000 C:\Windows\syswow64\CRYPTBASE.dll
0x75580000 - 0x75680000 C:\Windows\syswow64\USER32.dll
0x76290000 - 0x76320000 C:\Windows\syswow64\GDI32.dll
0x75a40000 - 0x75a4a000 C:\Windows\syswow64\LPK.dll
0x75860000 - 0x758fd000 C:\Windows\syswow64\USP10.dll
0x75680000 - 0x756e0000 C:\Windows\system32\IMM32.DLL
0x75970000 - 0x75a3c000 C:\Windows\syswow64\MSCTF.dll
0x7c340000 - 0x7c396000 C:\Program Files (x86)\Java\jre6\bin\msvcr71.dll
0x6d7f0000 - 0x6da9f000 C:\Program Files (x86)\Java\jre6\bin\client\jvm.dll
0x72e30000 - 0x72e62000 C:\Windows\system32\WINMM.dll
0x72930000 - 0x7297c000 C:\Windows\system32\apphelp.dll
0x6d7a0000 - 0x6d7ac000 C:\Program Files (x86)\Java\jre6\bin\verify.dll
0x6d320000 - 0x6d33f000 C:\Program Files (x86)\Java\jre6\bin\java.dll
0x6d7e0000 - 0x6d7ef000 C:\Program Files (x86)\Java\jre6\bin\zip.dll
0x6d000000 - 0x6d14c000 C:\Program Files (x86)\Java\jre6\bin\awt.dll
0x70030000 - 0x70081000 C:\Windows\system32\WINSPOOL.DRV
0x75f40000 - 0x7609c000 C:\Windows\syswow64\ole32.dll
0x722b0000 - 0x7244e000 C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.17514_none_41e6975e2bd6f2b2\COMCTL32.dll
0x756e0000 - 0x75737000 C:\Windows\syswow64\SHLWAPI.dll
0x6fe40000 - 0x6fe53000 C:\Windows\system32\DWMAPI.DLL
0x72db0000 - 0x72e30000 C:\Windows\system32\uxtheme.dll
0x76370000 - 0x76fba000 C:\Windows\system32\shell32.dll
0x6d230000 - 0x6d27f000 C:\Program Files (x86)\Java\jre6\bin\fontmanager.dll
0x6d600000 - 0x6d613000 C:\Program Files (x86)\Java\jre6\bin\net.dll
0x75930000 - 0x75965000 C:\Windows\syswow64\WS2_32.dll
0x76fc0000 - 0x76fc6000 C:\Windows\syswow64\NSI.dll
0x6f040000 - 0x6f07c000 C:\Windows\system32\mswsock.dll
0x72110000 - 0x72116000 C:\Windows\System32\wship6.dll
0x6d620000 - 0x6d629000 C:\Program Files (x86)\Java\jre6\bin\nio.dll
0x6f030000 - 0x6f035000 C:\Windows\System32\wshtcpip.dll
0x6ef30000 - 0x6ef74000 C:\Windows\system32\DNSAPI.dll
0x726b0000 - 0x726d7000 C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live\WLIDNSP.DLL
0x753f0000 - 0x753f5000 C:\Windows\syswow64\PSAPI.DLL
0x72680000 - 0x726a1000 C:\Program Files (x86)\Bonjour\mdnsNSP.dll
0x724c0000 - 0x724dc000 C:\Windows\system32\Iphlpapi.DLL
0x724b0000 - 0x724b7000 C:\Windows\system32\WINNSI.DLL
0x72630000 - 0x72636000 C:\Windows\system32\rasadhlp.dll
0x72640000 - 0x72678000 C:\Windows\System32\fwpuclnt.dll
0x730b0000 - 0x730c6000 C:\Windows\system32\CRYPTSP.dll
0x73070000 - 0x730ab000 C:\Windows\system32\rsaenh.dll
0x71e80000 - 0x71e97000 C:\Windows\system32\USERENV.dll
0x731b0000 - 0x731bb000 C:\Windows\system32\profapi.dll
0x72720000 - 0x72730000 C:\Windows\system32\NLAapi.dll
0x72710000 - 0x72720000 C:\Windows\system32\napinsp.dll
0x726f0000 - 0x72702000 C:\Windows\system32\pnrpnsp.dll
0x726e0000 - 0x726e8000 C:\Windows\System32\winrnr.dll
0x75740000 - 0x757cf000 C:\Windows\syswow64\OLEAUT32.DLL
0x6d780000 - 0x6d788000 C:\Program Files (x86)\Java\jre6\bin\sunmscapi.dll
0x75d10000 - 0x75e2d000 C:\Windows\syswow64\CRYPT32.dll
0x77a50000 - 0x77a5c000 C:\Windows\syswow64\MSASN1.dll
0x4c890000 - 0x4c8fb000 C:\Users\Bruker\AppData\Roaming\.minecraft\bin\natives\lwjgl.dll
0x6e1e0000 - 0x6e2a8000 C:\Windows\system32\OPENGL32.dll
0x6ecf0000 - 0x6ed12000 C:\Windows\system32\GLU32.dll
0x6e0f0000 - 0x6e1d7000 C:\Windows\system32\DDRAW.dll
0x6ece0000 - 0x6ece6000 C:\Windows\system32\DCIMAN32.dll
0x75250000 - 0x753ed000 C:\Windows\syswow64\SETUPAPI.dll
0x75900000 - 0x75927000 C:\Windows\syswow64\CFGMGR32.dll
0x760a0000 - 0x760b2000 C:\Windows\syswow64\DEVOBJ.dll
0x72060000 - 0x72069000 C:\Windows\system32\VERSION.dll
0x6d350000 - 0x6d356000 C:\Program Files (x86)\Java\jre6\bin\jawt.dll
0x4cd30000 - 0x4d7d5000 C:\Windows\system32\ig4icd32.dll
0x6ecd0000 - 0x6ecd8000 C:\Windows\system32\atigktxx.dll
0x6e060000 - 0x6e0e8000 C:\Windows\system32\aticfx32.dll
VM Arguments:
jvm_args: -Xms512m -Xmx1024m
java_command: C:\Users\Bruker\Desktop\Minecraft.exe
Launcher Type: SUN_STANDARD
Environment Variables:
PATH=C:\Program Files\Common Files\Microsoft Shared\Windows Live;C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\Windows Live\Shared;C:\Program Files (x86)\Java\jre6\bin
USERNAME=Bruker
OS=Windows_NT
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 37 Stepping 5, GenuineIntel
--------------- S Y S T E M ---------------
OS: Windows 7 , 64 bit Build 7601 Service Pack 1
CPU:total 4 (2 cores per cpu, 2 threads per core) family 6 model 37 stepping 5, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, sse4.1, sse4.2, popcnt, ht
Memory: 4k page, physical 3984048k(2345276k free), swap 7966248k(5603524k free)
vm_info: Java HotSpot Client VM (20.5-b03) for windows-x86 JRE (1.6.0_30-b12), built on Nov 10 2011 01:51:00 by "java_re" with MS VC++ 7.1 (VS2003)
time: Sun Dec 25 12:44:32 2011
elapsed time: 3 seconds
Dette skjer hver gang. Noen som kan hjelpe?
  • 4 uker senere...
