Ingen hardware fungerer?
Hovedkortet.
Produsenten , din modell og der ligger manual som PDF
I følge det jeg fant/så på pakken som inneholdt hovedkortet, så vil jeg tro dette er det:
asus motherboard p8p67
Er det noen.. mulighet du kan finne memok manualen for meg? Er dessverre forferdelig i dette..
Tror det tok meg 30 sek. Og det er inkludert tiden det tok å laste ned manualen :p
MemOK! switch
Installing DIMMs that are incompatible with the motherboard may cause system boot failure, and the DRAM_LED near the MemOK! switch lights continuously. Press and hold the MemOK! switch until the DRAM_LED starts blinking to begin automatic memory compatibility tuning for successful boot.
• The DRAM_LED also lights when the DIMM is not properly installed. Turn off the system and reinstall the DIMM before using the MemOK! function.
• The MemOK! switch does not function under Windows™ OS environment.
• During the tuning process, the system loads and tests failsafe memory settings. It takes about 30 seconds for the system to test one set of failsafe settings. If the test fails, the system reboots and test the next set of failsafe settings. The blinking speed of the DRAM_LED increases, indicating different test processes.
• Due to memory tuning requirement, the system automatically reboots when each timing set is tested. If the installed DIMMs still fail to boot after the whole tuning process, the DRAM_LED lights continuously. Replace the DIMMs with ones recommended in the Memory QVL (Qualified Vendors Lists) in this user manual or on the ASUS website at www.asus.com.
• If you turn off the computer and replace DIMMs during the tuning process, the system continues memory tuning after turning on the computer. To stop memory tuning, turn off the computer and unplug the power cord for about 5–10 seconds.
• If your system fail to boot due to BIOS overclocking, press the MemOK! switch to boot and load BIOS default settings. A messgae will appear during POST reminding you that the BIOS has been restored to its default settings.
• We recommend that you download and update to the latest BIOS version from the ASUS website at www.asus.com after using the MemOK! function.
Tatt fra 2.2.5 Onboard switches.
Endret av Bibow
MemOK! switch
Okay... Skal jeg ha i begge da jeg gjør denne feilsøkningen?
Og hvordan vil eventuelle resultater være, i og med at jeg ikke kan bruke skjermen i allefall!
Så det jeg generelt skal gjøre er å trykke på knappen og la maskinen reboote da den vil..
Blir også vanskelig å installere BIOS da jeg ikke får logget på en gang, vil det ikke?
Ok!
Det viser seg nå at jeg ikke hadde minnebrikkene hardt nok, så de funker som de skal.
Så nå har jeg gått tilbake til det gamle problemet mitt, nemlig bluescreens og appcrashes etter å ha logget på en bruker.
Da jeg får en bluescreen, etter å ha gått inn på en bruker får jeg ikke en gang sett desktopen.
Når jeg får alle de appcrasha (explorer, alle program som skal funke fungerer ikke) så er skjermen svart, med den hvite musa.
Hva kan være galt? (Dette er det gamle problemet)
Edit: Mange rare og forskjellige bluescreen problemer...
Legger ut bilder etterhvert
Endret av JimmyGrudgie
