3R4 Skrevet 14. desember 2011 Rapporter Del Skrevet 14. desember 2011 Hva synes dere om denne PC-en? SSD 630674 Crucial m4 SSD 2,5" 64GB SATA 6 Gb/s (SATA3.0), 415MB/95MB/s read/write 869,00 http://www.komplett.no/k/ki.aspx?sku=630674 HOVEDKORT 626386 ASUS P8P67 B3, Socket-1155 ATX, P67, DDR3, 2xPCIe(2.0)x16, Crossfire, SATA 6G 1.039,00 http://www.komplett.no/k/ki.aspx?sku=626386 KABINETT 579816 Cooler Master CM 690 II Advanced Sort Vifter: 1x 140mm Front, 1x 140mm Topp, 1x 120mm Ba 785,00 http://www.komplett.no/k/ki.aspx?sku=579816 PROSESSOR 619274 Intel® Core i5-2500K Processor Socket-LGA1155, Quad Core, 3.3Ghz, 6MB, 95W, Boxed 1.549,00 http://www.komplett.no/k/ki.aspx?sku=619274 MINNE (2x4GB) 599037 Corsair XMS3 DDR3 1333MHz 8GB CL9 Kit w/2x 4GB XMS3, CL9-9-9-24, for Phenom II and C 299,00 http://www.komplett.no/k/ki.aspx?sku=559037 MINNE (1x4GB) 605846 Corsair XMS3 DDR3 1333MHz 4GB CL9 XMS3, CL9-9-9-24, for Phenom II and Core i3/i5/i7, 149,00 http://www.komplett.no/k/ki.aspx?sku=605846 (NB: Kjøper 2-pakke for at de skal være fra samme batch) SKJERMKORT 647286 HIS Radeon HD 6570 2GB DDR3 PCI-Express 2.1, "Silence", DVI, native-HDMI, VGA 629,00 http://www.komplett.no/k/ki.aspx?sku=647286 SKJERM 635503 BenQ 24" LED GL2450HM 1920x1080, 40000:1, 2ms, speaker, VGA/DVI/HDMI 1250,00 http://www.komplett.no/k/ki.aspx?sku=635503 VIFTE (CPU) 657120 Cooler Master GeminII M4 CPU Kjøler 755/1155/1156/1366, AM2/AM2+/AM3/AM3+/FM1, 500~160 239,00 http://www.komplett.no/k/ki.aspx?sku=657120 STRØMFORSYNING 632009 Silver Power SP-SS850 850W PSU ATX 12V V2.3, 80 Plus Bronze, Standard, 2× 6pin PC 1.099,00 http://www.komplett.no/k/ki.aspx?sku=632009 Burde jeg heller kjøpe http://www.komplett.no/k/ki.aspx?sku=623449 eller http://www.komplett.no/k/ki.aspx?sku=635837 ? DVD-LESER/SKRIVER 494479 Lite-On DVD±RW Writer IHAS124-19 SATA, DVD±R: 24x, DVD+RW: 8x, DVD-RW: 6x, DVD-RAM: 149,00 http://www.komplett.no/k/ki.aspx?sku=494479 Er skjermkortet bra nok? Hvilken strømforsyning bør jeg gå for? Er prosessoren bra nok, eller bør jeg gå for i7? Er det overkill med 24" skjerm? Skal brukes til nettsurfing, spilling, skriving, osv. Takk for all hjelp! Lenke til kommentar
Drunkenvalley Skrevet 14. desember 2011 Rapporter Del Skrevet 14. desember 2011 (endret) Er dette forhåndskonstruert? Det virker svakt med 64GB SSD. Og hvorfor er minne nevnt to ganger? Skjermkortet er litt daffe egentlig, og strømforsyning er langt over mål av kva ein trenger. Prosessoren er mer enn god nok; det er det store vippepunktet der hardware-messig er det ikkjer forbedringer. Endret 14. desember 2011 av Drunkenvalley Lenke til kommentar
3R4 Skrevet 14. desember 2011 Forfatter Rapporter Del Skrevet 14. desember 2011 Nei, jeg har satt den sammen. Tror ikke jeg trenger mer enn 64gb SSD; kjøper heller mer når det blir billig. Minne kjøpes i to ganger slik at jeg i alle fall får to som garantert er fra samme batch, altså likere hverandre. Har du noen forslag til forbedringer? Lenke til kommentar
Pungrotta Crash Skrevet 14. desember 2011 Rapporter Del Skrevet 14. desember 2011 Grafikkortet er ikke egnet til spillbruk. Ville heller gått for dette: http://www.komplett.no/k/ki.aspx?sku=623543 Mvh Quattro123 Lenke til kommentar
Drunkenvalley Skrevet 14. desember 2011 Rapporter Del Skrevet 14. desember 2011 Først av alt trenger skjermkort med 2x6pin ikkje 300w strøm en gang. Dei drar opp til ca 20 amper på 12v rail. Resten av systemet skal være veldig spesielt for å dra heila 200w også egentlig. Derfor er du trygg med det meste av kvalitets-strømforsyninger på 600w fram til du velger skjermkort over GTX 560 ti / HD 6950. Har du ein harddisk på siden? Sist, men ikkje minst, er det noen grunn til at det haster? Lenke til kommentar
Lacim Skrevet 14. desember 2011 Rapporter Del Skrevet 14. desember 2011 (endret) Noen spesiell grunn til at du kjøper 2x4 + 1x4 GB RAM? MINNE (2x4GB) 599037 Corsair XMS3 DDR3 1333MHz 8GB CL9 Kit w/2x 4GB XMS3, CL9-9-9-24, for Phenom II and C 299,00 http://www.komplett....aspx?sku=559037 MINNE (1x4GB) 605846 Corsair XMS3 DDR3 1333MHz 4GB CL9 XMS3, CL9-9-9-24, for Phenom II and Core i3/i5/i7, 149,00 http://www.komplett....aspx?sku=605846 (NB: Kjøper 2-pakke for at de skal være fra samme batch) 64GB SSD holder så vidt, men jeg vil anbefale deg 100+GB når du først er i gang. Da får du plass til litt mer enn absolutt minimum. Du har absolutt ikke bruk for 850W strømforsyning. Samtidig kan det være kjekt å ha en kraftig enhet dersom du skulle finne på SLI/CFX ved en senere anledning. Skjermkortet du har valgt stiller jeg spørsmålstegn ved. Tilsynelatende er du interessert i en spillemaskin, så hvorfor du velger et så svakt skjermkort begriper jeg ikke. CPU-kjøleren vet jeg lite om, men fra bildene jeg har sett kan det kanskje bli et plassproblem. Jeg hadde valgt noe annet. Ang. hovedkort så er det helt greit, personlig hadde jeg gått for z68-chipset. Har du så lave krav til skjermkort kan du like greit bruke det integrerte i Sandy Bridge. Hvilke spill tenker du å spille? Kan iallfall si at noen i7 har du absolutt ikke behov for. 24" skjerm er ikke overkill. Ikke kjøp noe mindre så fremt du ikke har veldig dårlig plass på skrivebordet. Endret 14. desember 2011 av Lacim Lenke til kommentar
3R4 Skrevet 14. desember 2011 Forfatter Rapporter Del Skrevet 14. desember 2011 Tenker jeg kan ta ned strømforsyningen noe, men tenker også at i en eventuell maskin jeg bygger senere kan jeg bare bruke denne strømforsyningen om igjen. Skjermkortet kunne godt vært sterkere, men det tøyer fryktelig på budsjettet hvis jeg skal øke prisen med 1000kr. Budsjettet tøyes allerede når den koster 8000kr. Venter til prisene synker på HDD, koster jo syyykt for tiden. Lenke til kommentar
Drunkenvalley Skrevet 14. desember 2011 Rapporter Del Skrevet 14. desember 2011 Eg var på vei til å poste dette i ei anna tråd, men kan godt ta det her også: Hvis du trenger å få ned prisen er det da skjerm og harddisk som er relevant å nedgradere for deg trur eg. Lenke til kommentar
Lacim Skrevet 14. desember 2011 Rapporter Del Skrevet 14. desember 2011 SSD: http://www.komplett.no/k/ki.aspx?sku=630674 Skjermkort: http://www.komplett.no/k/ki.aspx?sku=623543 Skjerm: http://www.komplett.no/k/ki.aspx?sku=635503 Hovedkort: http://www.komplett.no/k/ki.aspx?sku=645915 CPU: http://www.komplett.no/k/ki.aspx?sku=619274 Kabinett: http://www.komplett.no/k/ki.aspx?sku=631849 PSU: http://www.komplett.no/k/ki.aspx?sku=623449 CD/DVD: http://www.komplett.no/k/ki.aspx?sku=494479 (trenger du dette?) RAM: http://www.komplett.no/k/ki.aspx?sku=650285 Byttet skjermkort til et vesentlig bedre (og er på tilbud), billigere kabinett, billigere strømforsyning, litt billigere hovedkort. Lenke til kommentar
3R4 Skrevet 14. desember 2011 Forfatter Rapporter Del Skrevet 14. desember 2011 Takker for listen, kommer til å basere PC-en på den. http://www.komplett.no/k/kcp.aspx?sku=623543&sku=627370 Er det verdt 500kr ekstra? Lenke til kommentar
Pungrotta Crash Skrevet 14. desember 2011 Rapporter Del Skrevet 14. desember 2011 Takker for listen, kommer til å basere PC-en på den. http://www.komplett.no/k/kcp.aspx?sku=623543&sku=627370 Er det verdt 500kr ekstra? Det er verdt det UTEN tvil! Lenke til kommentar
Drunkenvalley Skrevet 14. desember 2011 Rapporter Del Skrevet 14. desember 2011 (endret) I praksis ser du på ein 460 vs 560 ti. Endret 14. desember 2011 av Drunkenvalley Lenke til kommentar
3R4 Skrevet 14. desember 2011 Forfatter Rapporter Del Skrevet 14. desember 2011 SSD: http://www.komplett.no/k/ki.aspx?sku=630674 Skjermkort: http://www.komplett.no/k/ki.aspx?sku=623543 Skjerm: http://www.komplett.no/k/ki.aspx?sku=635503 Hovedkort: http://www.komplett.no/k/ki.aspx?sku=645915 CPU: http://www.komplett.no/k/ki.aspx?sku=619274 Kabinett: http://www.komplett.no/k/ki.aspx?sku=631849 PSU: http://www.komplett.no/k/ki.aspx?sku=623449 CD/DVD: http://www.komplett.no/k/ki.aspx?sku=494479 (trenger du dette?) RAM: http://www.komplett.no/k/ki.aspx?sku=650285 Byttet skjermkort til et vesentlig bedre (og er på tilbud), billigere kabinett, billigere strømforsyning, litt billigere hovedkort. Huff, ble dyrt! Har du noen forslag til vifter? Setter virkelig pris på hjelpen! Lenke til kommentar
N o r e n g Skrevet 14. desember 2011 Rapporter Del Skrevet 14. desember 2011 I praksis ser du på ein 460 vs 560 ti. 550 Ti er ikke i nærheten av et 460. 550 Ti har 192 CUDA-kjerner, mot 560 Tis 384. Det er omtrent en dobling i ytelse. Lenke til kommentar
Drunkenvalley Skrevet 14. desember 2011 Rapporter Del Skrevet 14. desember 2011 550 Ti er ikke i nærheten av et 460. 550 Ti har 192 CUDA-kjerner, mot 560 Tis 384. Det er omtrent en dobling i ytelse. Har alltid blitt fortalt at det er mer eller mindre rebranda 460, men det er jo ikkje benchmarks som vil utdypa ka kortå er i stand til, så då følgte eg bare husken. Beklager at det ikkje stemte. Lenke til kommentar
N o r e n g Skrevet 14. desember 2011 Rapporter Del Skrevet 14. desember 2011 550 Ti er ikke i nærheten av et 460. 550 Ti har 192 CUDA-kjerner, mot 560 Tis 384. Det er omtrent en dobling i ytelse. Har alltid blitt fortalt at det er mer eller mindre rebranda 460, men det er jo ikkje benchmarks som vil utdypa ka kortå er i stand til, så då følgte eg bare husken. Beklager at det ikkje stemte. GTX 550 Ti Techpowerup en forbedring av GTS 450, men ikke i nærheten av GTX 460. Lenke til kommentar
Drunkenvalley Skrevet 14. desember 2011 Rapporter Del Skrevet 14. desember 2011 GTX 550 Ti Techpowerup en forbedring av GTS 450, men ikke i nærheten av GTX 460. Det var jaggu meg ikkje imponerande gitt. Lenke til kommentar
Sebastilurio Skrevet 14. desember 2011 Rapporter Del Skrevet 14. desember 2011 Eneste som burde endres er skjermkortet, som noen nevnte over her, gå for en 560 Lenke til kommentar
Pungrotta Crash Skrevet 14. desember 2011 Rapporter Del Skrevet 14. desember 2011 Eneste som burde endres er skjermkortet, som noen nevnte over her, gå for en 560 560 Ti* Lenke til kommentar
Sebastilurio Skrevet 14. desember 2011 Rapporter Del Skrevet 14. desember 2011 (endret) Eneste som burde endres er skjermkortet, som noen nevnte over her, gå for en 560 560 Ti* Unnskyld. Endret 14. desember 2011 av sebastifuck Lenke til kommentar
