haakkern Skrevet 2. desember 2011 Del Skrevet 2. desember 2011 Hei. har en gammel server sak her en hp proliant dl380 G2 ! denne har xeon cpuer to styk og socet 604 denne kjører xeon 3 ghz. det jeg luret på støtter hovedkortet 64 bit xeon ? det hadde løst en del ting her hos meg.. legger ved et 2 bilder og hva faen er serverworks ? og vilken side har de? er det kjøpt opp av broadcom ? har googlet litt om dette.. mvh Lenke til kommentar
haakkern Skrevet 3. desember 2011 Forfatter Del Skrevet 3. desember 2011 anyone ? Lenke til kommentar
rufs Skrevet 3. desember 2011 Del Skrevet 3. desember 2011 Wikipedia: Xeon (DP) & Xeon MP (32-bit) [edit] Foster List: List of Intel Xeon microprocessors#"Foster" (180 nm) List: List of Intel Xeon microprocessors#"Foster MP" (180 nm) In mid-2001, the Xeon brand was introduced ("Pentium" was dropped from the name). The initial variant that used the new NetBurst microarchitecture, "Foster", was slightly different from the desktop Pentium 4 ("Willamette"). It was a decent chip for workstations, but for server applications it was almost always outperformed by the older Cascades cores with a 2 MB L2 cache and AMD's Athlon MP. Combined with the need to use expensive Rambus Dynamic RAM, the Foster's sales were somewhat unimpressive. At most two Foster processors could be accommodated in a symmetric multiprocessing (SMP) system built with a mainstream chipset, so a second version (Foster MP) was introduced with a 1 MB L3 cache and the Jackson Hyper-Threading capacity. This improved performance slightly, but not enough to lift it out of third place. It was also priced much higher than the dual-processor (DP) versions. The Foster shared the 80528 product code with Willamette. [edit] Prestonia List: List of Intel Xeon microprocessors#"Prestonia" (130 nm) In 2002 Intel released a 130 nm version of Xeon branded CPU, codenamed "Prestonia". It supported Intel's new Hyper-Threading technology and had a 512 KB L2 cache. This was based on the "Northwood" Pentium 4 core. A new server chipset, E7500 (which allowed the use of dual-channel DDR SDRAM), was released to support this processor in servers, and soon the bus speed was boosted to 533 MT/s (accompanied by new chipsets: the E7501 for servers and the E7505 for workstations). The Prestonia performed much better than its predecessor and noticeably better than Athlon MP. The support of new features in the E75xx series also gave it a key advantage over the Pentium III Xeon and Athlon MP branded CPUs (both stuck with rather old chipsets), and it quickly became the top-selling server/workstation processor. Så nei, kun 32bits. Generasjonen Xeon etter den du har støtter 64bits med EM64T. Lenke til kommentar
cruzader Skrevet 3. desember 2011 Del Skrevet 3. desember 2011 serverworks er hp/intel. For 64bit må du opp på G4 modeller, som fortsatt ikke altid shipped med 64bit cpu så du må gjerne bytte den. Brukte dl380 g4 får du til en ca 1000-1200kr på norske sider med 64bit ettersom om 1 eller 2 cpus. Noe lavere på ebay etc men da spiser frakten+moms raskt opp igjen det du sparer. Lenke til kommentar
haakkern Skrevet 3. desember 2011 Forfatter Del Skrevet 3. desember 2011 serverworks er hp/intel. For 64bit må du opp på G4 modeller, som fortsatt ikke altid shipped med 64bit cpu så du må gjerne bytte den. Brukte dl380 g4 får du til en ca 1000-1200kr på norske sider med 64bit ettersom om 1 eller 2 cpus. Noe lavere på ebay etc men da spiser frakten+moms raskt opp igjen det du sparer. takk jeg hadde et hunch om det. da spørs det om denne blir søppel.. Lenke til kommentar
StoltHD Skrevet 15. desember 2011 Del Skrevet 15. desember 2011 (endret) hvis hovedkortet er socket 604 og ikke 603 så skal dette i teorien støtte 64 bit, men du må finne de rette xeon cpu'ene og du bør også sørge for at disse har samme "stepping" da det ellers kan bli problemer med installasjon av OS om du bruker 2 cpu'er. gå inn på intel sine sider og sjekk hvilken socket 604 xeon som støtter amd64. Vær klar over at fysisk så er 603 og 604 like, ingen 603 cpu'er støtter 64-bit... og ikke alle 604 støtter heller . derimot støtter socket 604 "Nocona" (90 nm), 2.8, 3.0, 3.2, 3.4, 3.6, 3.8 Ghz med 800Mhz frontside bus 64-bit hvis de er merket med "E" i listen jeg har linket til... http://en.wikipedia.org/wiki/List_of_Intel_Xeon_microprocessors#.22Prestonia.22_.28130_nm.29 Endret 15. desember 2011 av StoltHD Lenke til kommentar
cruzader Skrevet 15. desember 2011 Del Skrevet 15. desember 2011 g2 så snakker vi 478, standard spec er pentium 3 1,4ghz. Lenke til kommentar
