M-Technic Skrevet 18. november 2011 Del Skrevet 18. november 2011 I'm Searching for power supply PC cables 750w chieftec, 6+2 pin PCI Express power cable or only 6 Pin, 8 pin! Sata cable! PLS help! I'm in oslo! Maybe some of you have cables, maybe someone knows where to buy it! OSLO Lenke til kommentar
MacNeil Skrevet 18. november 2011 Del Skrevet 18. november 2011 Just FYI, you are not limited to buying specific chieftec branded cables. You can get cables from pretty much every other powersupply brand and still use them without trouble. As long as they got the same type of conntector of course. (PCI-E, 8-pin & 6-pin) I'm pretty sure BitFenix sells seperate PSU cables, maybe you should contact them BitFenix Lenke til kommentar
M-Technic Skrevet 18. november 2011 Forfatter Del Skrevet 18. november 2011 (endret) i tryed too find in those site BitFenix, i did't find any stuff for me maybe someone knows some store in Oslo, or some guy which have a lot computer stuff, or somebody have in this forum and can sell it for me Endret 18. november 2011 av M-Technic Lenke til kommentar
MacNeil Skrevet 19. november 2011 Del Skrevet 19. november 2011 BitFenix cables Here, found them. Finding a vendor is the difficult task though. Lenke til kommentar
