Flashet xbox360? ADVARSEL!
cossiemk1
http://www.ixtreme.net/open-forum/18745-warning-do-not-connect-live-do-not-play-xgd3-do-not-play-ap25-games-%3D-banned.html
Microsoft har i alle hemmelighet sendt en oppdatering til alle xbox360-er i løpet av de siste 48 timene som endrer på en fil som kalles dae.bin, hovedsaklig en fil som brukes i xbox sitt system mot spillene du putter i den, for å sjekke om de er 100% autentiske.
Fra c4evaspeaks.com:
Sitat:
Warning! Dae.bin Being Silently Updated Through LIVE
Posted on 2011-11-17 by admin
First and foremost, a warning — at this current time it is advised that you stay offline and avoid playing any AP2.5/XGD3 backups. It has been confirmed by the team that the dae.bin is now being silently updated on all LIVE-connected boxes.
This update is not being deployed via a SystemUpdate or TitleUpdate, but rather occurs in the background without any visual indication or prompt to the user. As such, there is no means by which it can be cancelled or avoided, other than not connecting to LIVE. If you’ve connected to LIVE in the past 24 hours, your system has likely already been updated with a changed dae.bin.
All AP2.5/XGD3 backups that contain the now older AP25 replay data will fail the system’s AP2.5 challenges and indeed flag your system (the flagging has also been confirmed by the team).
Like our news a few days ago, the dae.bin is now being changed by way of an appended challenge table in the same manner on current retail dashes (13604) as it is on the preview dash (14686), however the content of the challenge tables differ. The team has determined that the appended challenge table appears to be unique per console and contains indentifying information. This means that everyone’s dae.bin is different, and can potentially be traced back to your specific console. Therefore, sharing your dae.bin with others is not advisable.
More info to come.
Mao, har noen av dere med flashet xbox vært på LIVE i løpet av de siste 48 timene, kan xboxen din være flagget for ban.
En måte å sjekke om xboxen er "OK" på, er å bruke programmet Xval (kan lastes ned her.
Last ned programmet, kjør på PC-en, gå til settings - console settings - system info på xboxen din, og klin inn Console Serial + alt etter "X:" nederst i vinduet inn i Xval. Den bør gi deg "secdata clean" Om xboxen din enda ikke er flagget.
Hold dere offline inntil videre, for om dere blir flagget, vil ALLE XGD3-backups dere har brent ut hittil gi dere en error og svart skjerm, og når MS har en banhammer, blir xboxen din tatt.
Sitat:
More info to come.
Glad jeg ikke bruker XBOX 360.
Lol, what? Jeg er sikker på alle som ikke har gjort noe muffens med sin Xbox 360 fremdeles er like glad mens de bruker den.
Har man derimot tuklet med sin Xbox 360, vel, you take your chances, alle vet (eller burde vite) at de gjør det på egen risiko. Er man smart så følger man med som best kan og holder seg oppdatert på hva som foregår, og tar forbehold mot Live og alt det der.
Jeg har både modifiserte 360'er og xk3y og hele pakken, men siden det var innlysende noe lå i emne fra MS de siste ukene, har jeg ikke hatt den på Live og ei heller oppdatert til nyeste dash (som strengt tatt ikke en gang er nødvendig, selv nyeste spill krever kun forrige dash versjon).
Life is still good.
nyeste dash har ikke noe med dette å gjøre, denne oppdateringen merker du ikke at du får ;)
Jo, nyeste dash (13604) har noe med dette å gjøre, siden det er i denne at den "skjulte" snikoppgraderingen av dae.bin er innført. Og har man villet være på Live, så har man jo selvsagt måtte installere denne dash versjonen. Kjører fremdeles 13599 siden jeg har holdt meg unna Live i det siste.
forklar dette kort, banner denne oppdateringen uskyldige brukere?
Det er konsollen som blir bannet, ikke brukeren.
Foreløpig nyeste dash (13604) som blir lagt inn når man knytter seg til Live, har nå innført muligheter for MS til å oppgradere et sikkerhetsaspekt i konsollen, som kan skje når som helst, uten noe varsel for bruker og ei heller godkjenning av bruker. Dette umuliggjør spilling av de nyere spill på kopierte DVD-plater, og når dette oppdages av konsollen blir man altså "merket" og Microsoft vil banne konsollen neste gang man kobler til Live.
åja, da er ikke jeg i faresonen.
Og uskyldige brukere, dvs de som ikke har modifisert sin Xbox 360 på noen måte, blir selvsagt ikke rammet. Men det har vært enkelte episoder hvor MS har trukket tilbake utestengelser av "uskyldige" konsoller, men sjansene er nok små for at man blir feilaktig utestengt.
Endret av JerkenovDecoq
håper ikke det skjer meg, min er ikke modifisert på noen som helst måte.
Det er raportert flere tilfeller av at umodifiserte konsoller har blitt flagget, så man skal ikke se bort i fra at noen av disse også blir bannet, HVIS noen i det hele tatt blir bannet, men det tviler jeg på. MS har prøvd seg med dette før, og da ble det mye bråk med folk som ikke hadde modifisert konsollene, og hele greia ble tilbakestillt og folk fikk erstatning i for av gratis live osv.
Har du en umodifisert konsoll, så sørg for at spillene dine er rene og ripefrie, så går det nok bra skal du se ;)
Da er en løsning på vei :D
iXtreme LT+ v3.0 is on the way! Yesterday, having revealed to the team an idea for countering the recent dae.bin/AP2.5 update, c4eva has today confirmed that he has in fact completely done away with the need for dae.bin/AP2.5 data. Although it’s early stages, c4eva has successfully completed several tests which validate this new method and classified his solution as the “silver bullet” for AP2.5. Rather than using captured challenge results each time the dae.bin changes, the new method builds a complete set of profile data for each disc and works for all AP2.5 challenges, regardless of how the dae.bin is changed. As a result, the format of backup ISOs will be changing as the AP25 replay sector will no longer be included and the profile data will instead take its place. Though c4eva noted that it will take some development time as it’s not a quick fix, both he and the team will now be putting their full efforts behind bringing this solution to life in the form of new versions of iXtreme LT+, Xbox Backup Creator, and abgx360.
*UPDATE* [2011-11-20 04:10AM UTC]
To answer the deluge of questions we received immediately after the initial post — Hitachi LT+ v2.0 is still on schedule for release. Testing is being completed and an annoucement of when to expect the release will come shortly thereafter.
