Flashe Popcorn Hour A-110 firmware inn på Syvio 200A
Tar dette på engelsk, siden jeg har forsøkt meg i et utenlandsk forum også. Bare svar på norsk hvis dere vil.
I see several posts and HOWTOs around regarding cross-flashing the Popcorn Hour firmwares onto various players, but have found none mentioning the CMI Syvio 200A.
This is a Popcorn A-110 clone, probably very, very similar.
I tried this.
Short story: I couldn't get it to work.
Long story:
Originally, I was running the last (and final) firmware from Syvio, 091202.
When trying to cross-flash to Syabas Popcorn Hour A-110 firmware the usual way (from USB, via the on-screen menu), I get:
"Cross-customer update is not allowed, please reboot."
Then I tried to "recover" the firmware by setting a jumper on uart0 etc. This did not work with Popcorn recovery firmware either (note that this DOES work with CMI/Syvio recovery firmware).
Well, I googled a bit, and found this:
http://olivier.cochard.me/bidouillag...ix-on-hdx-1000
also mirrored here:
http://www.2shared.com/file/11589798...nhour_a-1.html
It basically pushes some files to the internal hard drive, allows the user to start a telnetd using the remote control, and then do a manual firmware flash using the command line.
Well, I followed the guide, but took care to replace the file "mtd2" with a Popcorn Hour firmware, 01-17-100317-15-POP-403-000.bin.
Well, the processed at first seemed to work just fine, it erased the flash partition on /dev/mtd2, then wrote the new fw using dd.
However, it doesn't work (can't boot, at least no signal on any outputs).
Recovery to original latest (and final) CMI/Syvio firmware worked, though. So at least my device is not bricked.
But still no cross-flash... Any ideas?
  • 1 år senere...
Hei,
Jeg ser at dette inlegget er over ett år gammelt, men jeg bestemte meg nylig for å børste bort støvet av min gamle syvio for å bruke den sammen med TV'en på soverommet. Har boxee box i stuen og dette fungerer utmerket.
Den største feilen med syvio'en slik som jeg opplevde det er at den ikke støttet DTS audio. Dette problemet ellimineres ved å flashe popcorn firmware på den og gjør at denne spilleren fremdeles klarer å spille det meste av nedlastede filmer og serier.
Jeg fulgte guiden i denne tråden og det fungerte utmerket for meg:
http://www.mpcclub.com/forum/showthread.php?t=25034
Den første av nedlastningslinkene (megaupload) er død, men du finner denne filen ved å google på PCH-HDX.zip
Husk å ta backup av originalfirmwaren før du flasher den nye. Hvis ikke får du aldri restoret til Syvio firmware.
Håper dette er til hjelp for andre :)
