Maskinen er død, Power eller hovedkort?
Det er vel en kortslutning på hovedkortet. Du kan teste powersupply separat ved å kortslutte mellom PS_ON# og COM.
Bruk et universalinstrument til å måle spenningene.
Du kan jo også måle de brente kontaktene på hovedkortet og sjekke om de er kortsluttet til jord.
Hvis du måler det, så prøv å fjern alt som kan kobles fra av RAM etc og mål igjen.
NB: Er det en DELL PC og annet PSU du bruker?
Older Dell computers, particularly those from the Pentium II and III lines, are notable for using proprietary power wiring on their power supplies and motherboards. While the motherboard connectors appear to be standard ATX, and will actually fit a standard power supply, they are not compatible. Not only have wires been switched from one location to another, but the number of wires for a given voltage have been changed. Thus, the pins cannot simply be rearranged.[2]
The change affects not only 20-pin ATX connectors, but also auxiliary 6-pin connectors. Modern Dell systems might use standard ATX connectors.[3] Dell PC owners should be careful when attempting to change Dell motherboards and power supplies from the original setup, as it can cause damage to the power supply or other components. If the power supply color coding on the wiring does not match ATX standards, then it is probably proprietary. Wiring diagrams for Dell systems are usually available on Dell's support page.
To determine if a Dell PC has this propriety ATX (non industrial standard), view the power pin layout in the on-line dell 'SERVICE' manual (not user manual) and compare it with the ATX pin diagram above.[18] A more reliable method is to measure the voltages on the connector.
DELL motherboard ATX type power supply connector pinout
(This non-standard wiring is used in DELL Pentium II and Pentium III systems) Color Signal Pin Pin Signal Color Red +5 V 1 11 PS_On Grey Black Ground 2 12 Ground Black Red +5 V 3 13 Ground Black Black Ground 4 14 Ground Black Orange Power good 5 15 −5 V White Purple +5 VSB (standby) 6 16 +5 V Red Yellow +12 V 7 17 +5 V Red Blue −12 V 8 18 +5 V Red Black Ground 9 19 - KEY (blank) Black Ground 10 20 +5 V Red [19]
  • 18 AWG is recommended for all wires except pin 11, which should be 22 AWG. For 300 W configurations 16 AWG is recommended.
  • Note: some Dell power supplies do not have the −5 V (white wire), (2002 v1.2 made optional, 2004 v2.01 removed from specification)
Endret av Jan Skrotnes
Ikke dell, er gammal hjemme bygd. Chieftec ATX 12V Power, Asus hovedkort med pentium 4.
Dette riktig tro? fergene stemmer.
Figure 6: ATX connector diagram.
To start an ATX power supply, we need to short the PS_ON pin. This is easily done by connecting a wire between the PS_ON pin (pin 14, usually the green wire) and any black Ground pin. This is shown in figure 7:
Powere er defekt, starter ikke med å kortslutte. måler 4v mellom grønn og svart. de brente(Oransje) kontaktene på powere går til jord(svart)
Da er saken løst var powere som var deffekt og bare den. :new_woot:
Endret av Kongenjk
Man bør dog være varsom med å sette i en ny psu på et hovedkort som en har en svidd strømtilkobling da dette kan bety at noe er alvorlig
galt på hovedkortet og kan være årsaken til at Psu'en tok kvelden (spesielt eldre psu'er).
Man bør også ta en ordentlig sjekk av Caps (kondensatorer) , passe på at ingenting sørger for kontakt med hovedkortet (løse metalbiter , kabler etc) og følge godt med når man prøver med ny strømforsyning.
Personlig hadde jeg ikke giddet å ta risikoen på et eldre system med mindre det var absolutt nødvendig å ha det i live.
