brukar2341 Skrevet 8. november 2011 Del Skrevet 8. november 2011 Hallais! Satt her en dag å lagde en ny YouTube, lagde meg en background og det shittet. Jeg ville ut hvor lang en video kunne være og hvor mange minutter/gb kanalen kunne maks inneholde.. Noen som har peiling? -DahPain Lenke til kommentar
PHCTF Skrevet 9. november 2011 Del Skrevet 9. november 2011 Det er ingen limits for hvor mange minutter/GB du kan ha på kanalen din totalt. Derimot, hver film kan ikke være lengre 15 minutter eller 20 GB så fremt du ikke er YouTube-partner. Lenke til kommentar
rvenes Skrevet 9. november 2011 Del Skrevet 9. november 2011 (endret) Øh! Eg er da ingen youtube partner trur eg, men når eg skal laste opp filer står det: Congratulations! Your account is now enabled for uploads longer than 15 minutes. Så går ut i frå at eg kan laste opp lengre filmer? Trur du må bruke ein alternativ opplaster om filmer er over 2 gb, bruke java greia, men ser no at dei har gjort om på kordan opplastingen fungerer. Edit: Les her Uploading large files and resumable uploading Using the most up to date version of Google Chrome, Firefox 4 or higher, or Internet Explorer (with Silverlight enabled) grants you access to powerful new uploading features: Ability to upload large files, of up to 20GB in size Ability to resume or recover stalled or cancelled uploads If you have the ability to upload longer length video, the most effective way to upload large files is to simply use an up to date version of one of these browsers, visit the upload page, and upload your file as usual. There is no need to use the Java uploader for larger files or resumability. The processes outlined below are the best way to ensure your upload is successful. Og da her: All users have the ability to upload videos up to 15 minutes in length. You can attain the ability to upload longer length videos if: Your account is in good standing, as determined by the YouTube Community Guidelines. You verify your account with a mobile phone. Your account has no worldwide Content ID blocks on any content On the upload page, click the link to Increase your limit to be prompted to verify your account. Endret 9. november 2011 av rvenes Lenke til kommentar
PHCTF Skrevet 9. november 2011 Del Skrevet 9. november 2011 Det står vel klart og tydelig at fila ikke kan være større enn 20 GB? Kan ikke se for meg at en helt tilfeldig bruker skulle få laste opp filmer lengre enn alle andre sine, så prøv å last opp en film på 17 minutter og sjekk om det funker. Lenke til kommentar
brukar2341 Skrevet 9. november 2011 Forfatter Del Skrevet 9. november 2011 Skal gjøre det idag, takk for svar Men noen som har peiling på det "membership" greiene ? -DahPain Lenke til kommentar
