Skyrim: Raser & Stats
Gjest Slettet-Pqy3rC
Siden spillet snart er her kan jo folk planlegge hva de har lyst å starte som.
Argonian
+10 Lockpicking, +5 Restoration, Alteration, Light Armor, Sneak, Pickpocket
Histskin : Invoke the power of the Hist to recover health ten times faster for 60 seconds.
Resist Disease : Your Argonian blood is 50% resistant to disease.
Water Breathing : Your Argonian Lungs can breath underwater.
Breton
+10 Conjuration, +5 Alchemy, Illusion, Restoration, Alteration, Speech
Dragonskin : Absorb 50% of magicka from hostile spells for 60 seconds.
Magic Resistance : Breton blood grants a 25% resistance to magic.
Dunmer (Dark Elf)
+10 Destruction, +5 Alchemy, Illusion, Alteration, Light Armor, Sneak
Ancestor’s Wrath : For 60 seconds, opponents that get too close take 8 points per second of fire damage.
Resist Fire – Your Dunmer blood gives you 50% resistance to fire.
Altmer (High Elf)
+10 Illusion, +5 Conjuration, Destruction, Restoration, Alteration, Enchanting
Highborn : Regenerate magicka faster for 60 seconds.
Highborn : High Elves are born with 50 extra magicka.
Imperial
+10 Restoration, +5 Destruction, Enchanting, Heavy Armor, Block, One-Handed
Voice of the Emperor : Calms nearby people for 60 seconds.
Imperial Luck : Anywhere gold coins might be found, Imperials always seem to find a few more.
Khajiit
+10 Sneak, +5 Alchemy, One-Handed, Archery, Lockpicking, Pickpocket
Night Eye : Improved night vision for 60 seconds.
Claws : Khajiit claws do 15 points of damage.
Nord
+10 Two-Handed, +5 Smithing, Block, One-Handed, Light Armor, Speech
Battle Cry : Target flees for 30 seconds.
Resist Frost: Your Nord blood gives you 50% resistance to frost.
Orsimer (Orc)
+10 Heavy Armor, +5 Enchanting, Smithing, Block, Two-Handed, One-Handed
Berserker Rage : You take half damage and do double damage for 60 seconds.
Redguard
+10 One-Handed, +5 Destruction, Alteration, Smithing, Block, Archery
Adrenaline Rush : Stamina regenerates 10x faster for 60 seconds.
Resist Poison : Your Redguard blood gives you 50% resistance to poison.
Bosmer (Wood Elf)
+10 Archery, +5 Alchemy, Light Armor, Sneak, Lockpicking, Pickpocket
Command Animal : Make an animal an ally for 60 seconds.
Resist Disease and Poison : Your Bosmer blood gives you 50% resistance to poison and disease.
Starting spells
Flames : A gout of fire that does 8 points per second. Targets on fire take extra damage.
Healing : Heals the caster 10 points per second.
I tillegg enkelte raser med et ekstra spell:
Breton's
Conjure Familiar : Summons a Familiar for 60 seconds wherever the caster is pointing.
Dunmer
Sparks : Lightning that does 8 points of shock damage to health and magicka per second.
Altmer
Fury : Creatures and people up to level 6 will attack anything nearby for 30 seconds.
Jeg finner disse som de beste;
Orc: (Berserker Rage) You take half damage and do double damage for 60 seconds.
og i starten er spillet er nok denne nyttig;
Siden jeg alltid går for OP i disse spillene blir det nok Breton igjen. Magi resistent sverdsvinger med lokkedue er lei å hanskes med.
Det vites ikke. Det var 1 dag på et par av dem i Oblivion, men jeg husker ikke om det gjaldt alle.
Dette gjelder altså rase egenskaper med en oppgitt varighet (... for 60 seconds), spørsmålet er altså hvor ofte du kan benytte dem.
I Morrowind var jeg melee i ca. 30 minutter før jeg laget en magiker.
I Oblivion forsøkte jeg en Dunmer 1h sverd/magiker (i nye ca. 30 minutter), men gikk tilbake til ren magiker før jeg havnet på en wood elf snikende bueskytter.
Så for Skyrim har jeg tenkt å gi melee en ny sjanse (denne gangen skal det vare lengre enn 30 minutter).
Og siden det tross alt er Skyrim blir det en Nord med 2h sverd, light armor og bue som mitt første valg.
Men ut november må jeg fokusere helt og holdent på studier, noe som kommer til å bli kjedelig så fort anmeldelser begynner å dukke opp.
-Deluze
Vanskelig å bestemme seg. Jeg har, tradisjonelt i de tidliger TES-spillene, vært en med heavy armor, med one-handed og skjold. Jeg har i tillegg brukt pil-og-bue, og ikke brukt spesielt mye annet magi enn health.
Kanskje det blir Imperial.
Endret av Quote
Problemet er vekta på Heavy Armour siden karakterer som går for magi gjerne er puslete reint fysisk. Det blir lite du kan ta med dersomom du i det hele tatt klarer å unngå overvekt dressa opp i heavy. I Oblivion måtte jeg bruke "feather" spells kontinuerlig for å gjøre meg lettere (typisk; Satsa egentlig på light, men kom stadig over god heavy armour).
Det ikke vært satt noen tekniske hindringer i tidligere spill.
Pussig at Nords nå plutselig er mer veltalende enn Imperials (5 ekstra ferdighetspoeng i speech), mens Imperials nå er blitt voldsomt flinke i restoration (+10 ferdighetspoeng). I tidligere ES spill pleide Nords å ha en liten boost i restoration, mens dette nå er fjernet. Litt skuffet må jeg si.
Hvilke feller kan man risikere å gå i hvis man, som i mitt tilfelle, har valgt Nord, men faller for fristelsen til å gjøre hva man vil hele tiden uten tanke på opprinnelige stats?
Tror ikke du faller i noen spesielle feller annet enn at du blir en okey all-round karakter, mens de som fokuserer på enkelte ting blir skikkelig gode i det, f.eks en utrolig sterk kriger, fremfor en som er okey kriger og okey magiker. Snakker ikke av erfaring, men vil tro det er den eneste "fellen" du kan gå i ved å gjøre litt av hvert.
Hmm okei. Men vil det være skillnivåer som vil bli uoppnåelige for meg? Eller må bare ekstra grinding til for å gjøre alt mulig?
