forskjellen på tco95 og tco99
http://www.vstu.vinnica.ua/rom/www/med/tco2.htm <- TCO-99
http://press.nokia.com/PR/199810/778362_5.html <- Litt av hvert
http://www.datordesign.se/servsupo/Philips...n_TCO_99_03.pdf <- Sammenligning mellom TCO-99 og 03 i PDF format.
http://www.nemkokorea.com/htm/file/downloa...and%20TCO03.pdf <- Enda en 99 og 03 sammenligning.
Environmental standards Top
Screen radiation is a pollutant. There is no concrete evidence that screen radiation can cause illness. However, artificially generated radiation must be unwelcome in our environment. Consequently, industry standards have been developed for acceptable radiation levels.
Since the early nineties, the Swedish MPR-2 standard established limits for monitor electrostatic radiation.
Since then came the stricter TCO-92. It limits the permitted amount of low level radiation and establishes standards for electrical and fire safety. Usually TCO means Total Cost of Ownership but here it refers to the Swedish Confederation of Professional Employees (Tjänstmännens Central Organisation). They defined strong standards for emissions.
Finally, we have TCO-95, which is the strictest standard. Similar to TCO-92, it also includes regulations on ergonomics (including refresh rates), maximum energy consumption, environmentally friendly production and recycling facilities. The best screens comply with this standard. Screens adhering to the TCO standards are more expensive. Obviously since they are better screens.
The flat TFT screens do not emit any radiation at all and they consume considerably less energy than the radiating screens. This is another indication that TFT may be the standard screen of the future.
Sistnevnte er litt utdatert, men beskriver ganske godt hva TCO er fordèt. ;)
(Pssst, neste gang , søk på google, dette tok meg fem minutter å finne ved å søke "TCO screen"...)
